restorer-john
If they're anything like the Chinese cheapies I bought from Amazon for my dummy load, quite low.
Same with Chinese ones I bought a while back. I was really surprised. But I do have some otherwise very nice 4R ceramic ones which aren't as good in that regard.
jasonhanjk
Just finished DIY yesterday.
JRC2068 and JRC4556.
mansr
Hampshire
I'm pretty sure I've identified the problem with this Proel PRL1400 amp.
In case anyone is wondering, it was indeed those large filter capacitors. I replaced them and, just in case, the smaller electrolytics in the background. The amp has been running fine for a few days now.
Rick Sykora
Stow, Ohio USA
These are from Parts Express and would not call them inexpensive (relatively speaking the Arcol ones seem a much better deal in hindsight). They are claimed to be low inductance...
Using my impedance rig for REW (not sure how accurate it is at low inductance) , I measure 2-15 uH up to about 10kHz and then rises to about 90 uH at 20kHz. See later post as cannot repeat these measurements...
LTig
Europe
These are from Parts Express and would not call them inexpensive (relatively speaking the Arcon ones seem a much better deal in hindsight). They are claimed to be low inductance...
Strange. Does inductivity depend on frequency?
Rick Sykora
Stow, Ohio USA
The short answer for real world inductors is yes it depends (on application).
At what frequency it happens is a function of the Q of the inductor and its resonant frequency. Btw, am about 35 years past my AC circuit theory class, so had to get a online refresher. ;)
LTig
Europe
XL = 2pieFL
So... the inductive reactance is directly proportional to frequency and inductance.
This I know, I wondered about the dependency of the inductance L on frequency F.
Blumlein 88
As frequency goes up so does inductive impedance. Or are you asking if the inductance itself changes with frequency? The answer to that should be a no.
LTig
Europe
The short answer for real world inductors is yes.
The inductance of a real world resistor is constant, but there is also a stray capacitance parallel to the serial connected resistor and inductor (see Horowitz/Hill Art of Electronics - The X chapters page 20). This circuit has a resonance frequency, and knowing it helps to calculate the capacitance. I think you miscalculated the inductance when you assumed that the complex impedance of this circuit results from the inductance alone.
However, looking at the graphs on page 22 in said book the resonance frequency of all shown wirewound restores is far above the audible frequency range.
Rick Sykora
Stow, Ohio USA
Agree, and I went back and remeasured the power resistor. For most of the audio range the inductance is 15 uH for my 4 ohm power resistor. Not sure what happened with the earlier measurement, but it was early and I must have messed up as I cannot reproduce the same readings. :facepalm:
Rick Sykora
Stow, Ohio USA
Now dual resistor dummy load and twice the fun!
Rick Sykora
Stow, Ohio USA
Amending my earlier statement, apparently inductance can rise with frequency but is application dependent. It does not appear to be an issue at audio frequencies. Here is the reference...
Kenneth Lundgren
, M.S. Electrical and Electronics Engineering, Northwestern University
Answered September 8, 2017 · Author has 6.5K answers and 2.5M answer views
All the answers here except Roy MaCammon’s ignore what the OP has asked. All of the math about the reactance increasing with frequency is true. However, every inductor has a self-resonant frequency which is caused by the stray capacitance within the inductor. At the self-resonant frequency, the reactance will be much higher than predicted by X=jωL. So as the frequency approaches the resonant frequency, the equivalent value of L will actually increase. In a high Q inductor, L may appear infinite.
At frequencies above the resonant frequency, the inductance will actually appear negative, i.e. capacitive.
INDUCTOR IMPEDANCE vs FREQUENCY:
APPARENT INDUCTANCE vs FREQUENCY:
If the inductor is being used as a choke - to block high frequency AC, you can use this to advantage, by selecting an inductor with a resonant frequency close to the frequency that you want to block.
There are special inductor designs to maximize the self-resonant frequency by minimizing the self-capacitance.
There may be several self-resonant frequencies.
LTig
Europe
Don't worry too much, you're neither the first nor the last to fall into a measuring trap.
ajawamnet
Back in the day at Opus One, we had banks of Arcol or Dale non-inductive. Here's a portable one I designed. It has a transformer coupler that I can use to feed test gear or bench amps to hear what's going on.
Has a carrying case for taking to jobsites... I've run 180 watts (DC in fact) for hours as part of a test of some non-audio gear.
dfuller
Got two guitar amps in right now.
1. A Fender Twin Reverb reissue that was no-loaded by a faulty speaker cable and nuked some socket mounted resistors bad enough that I'm just replacing the sockets rather than trying to clean the carbon off.
2. A Bogner Uberschall Twin Jet with what I'm almost entirely certain is a bad plate resistor on the input stage.
jasonhanjk
Well, not right now but it's yesterday picture. TPA6120 on proto board, 1 channel complete.
Output resistor 0 ohm with non-inverting gain of X1. No oscillation detected with input shorted.
