digitalfrost
Interesting. Will give this a try.
e: I have to say I like this a lot. The bass is close to my own tuning, and I think this sounds closest to my speakers of all the targets I tried so far.
Can be with certain speaker / room combos as well. I like my speakers' in-room response flat with a low frequency shelf.Flat is a great target for DACs, ADC, amps.
You should tell them a target doesn't make a sound.I generally ignore the opinions of reviewers who don't consider the Harman target as neutral, especially those who say they don't consider it neutral because it doesn't sound neutral to them without any scientific backing, research.
A "neutral" curve would be the Harman target curve for IEMs and headphones
Does the distinction matter? If we assume, for example, that preference is imprinted in listeners by physical sound events, like speakers in living spaces and venues, what's the alternative?we don't know what would be neutral, but Harman is obviously not. at least not the bass boost. and it wasn´t developed to be neutral either. so I don't see why this myth keeps running around. it's a preference curve
Ironic, considering pretty much all of that comment is myth. Here's the reality:we don't know what would be neutral, but Harman is obviously not. at least not the bass boost. and it wasn´t developed to be neutral either. so I don't see why this myth keeps running around. it's a preference curve
I think it is well established that flat bass in a headphone or in-room response of a loudspeaker is NOT neutral. We’ve had trained listeners draw the perceived spectral balance of these targets and they are perceived as not flat.
Toole spent 10 years having listeners rate loudspeaker based on perceived fidelity/neutrality. When we switched to preference, the loudspeakers ratings didn’t suddenly change. There is a high correlation between fidelity/neutrality/ preference.
Our headphone targets do not deviate significantly above 200 Hz from a anechoically flat speaker measured in our reference room at the DRP. For the AE/OE target it’s within 2 dB of the bass of the in-room speaker target. For the IE target it’s higher, but there are data to support it needs to be higher to be perceived as equivalent
Now that is quite interesting, as I'm looking for the best IEMs to properly represent the live sound, your target could be the one to align with, since it closer to the speakers as it stated here:The only target I can advise is markanini target: https://kurin.squig.link/?share=mar..._7Hz_Salnotes_Zero,Oratory_Moondrop_Starfield
It sounds speaker-like to me. I'm a single listener so no guarantees, especially not using Resolves measurements because he uses a different type of coupler.Now that is quite interesting, as I'm looking for the best IEMs to properly represent the live sound, your target could be the one to align with, since it closer to the speakers as it stated here:
What is the flattest target curve?
Interesting. Will give this a try. e: I have to say I like this a lot. The bass is close to my own tuning, and I think this sounds closest to my speakers of all the targets I tried so far.audiosciencereview.com
S12 is almost perfectly aligned with your target, hence it should sound like a good set of speakers, correct me if I'm wrong here:
How would you compare S12 to Blessing 2, also would you recommend S12 as the best neutral (or realistic sounding) set in the price range up to $300, based on the alignment with your target?
Harman having a "bass boost" is the myth. I hate that term. Yeah on frequency response graph, the absolute value shows that there is a "bass boost". But does not necessarily mean that what is heard is "bass boost".we don't know what would be neutral, but Harman is obviously not. at least not the bass boost. and it wasn´t developed to be neutral either. so I don't see why this myth keeps running around. it's a preference curve
That's really the bottom line. Harman is a company that wants to move headphones. They aren't terribly concerned about flat, or what one outlier thinks. EQ your headphones so you're happy.there have only been preference studies, so we don't know.
can someone share a txt of IEF neutral 2023?
Wait...I thought we were talking about headphones? Anechoic response?well, there is ISO 11904-1 and ISO 11904-2 which in theory should be neutral in the sense of an "anechoic response"?
my Superlux 681 indeed sounds neutral with ISO 11904-1, but my KZ ZSN PRO sounds terribly thin with it.
thanks a lot @digitalfrost
I agree, but...what has that to do with the Harman headphone curve?I guess it depends on how you define neutral.
for ME neutral would be the response of a perfect(ly flat) speaker pair in a perfect stereo triangle in an anechoic chamber
