What surface roughness makes for a good diffractive side wall ?
Wes
Depth and spacing of surface elements...
Note - elements could be the peaks on a brick.
Hipper
Herts., England
I would have thought that the sonic behaviour of a wall with a rough surface would be more determined by the material from which it is made then the coarseness of its surface. Remember that the sound wavelengths are relatively large (20kHz has a wavelength of 1.7cm).
When you look at diffusor panels their relevant dimensions are much bigger then this.
Of course I could be completely wrong!
JohnPM
Height differences reaching 1/4 of the wavelength of the lowest frequency you want to diffuse, so a lot of height variation. "Roughness" doesn't quite capture it :)
