What type of amplification do you use if you use one or more subwoofers?
What type of amplifier do you use if you use one or more subwoofers?
  • Stereo amplifier w/out xover
    Votes: 18 15.0%
  • Stereo amplifier with integral or external xover
    Votes: 39 32.5%
  • AVR with LR speakers set to small
    Votes: 35 29.2%
  • AVR with LR set to large
    Votes: 11 9.2%
  • Software crossover and decoding with multiple or multi-channel amplifiers
    Votes: 26 21.7%
sarumbear
I want trying to find out how ASR members use their subwoofers. If you have multiple systems, please answer the question for the system where you listen to music predominantly and/or treat it as your main system. Please use your vote even if you posted your the answer.
By amplifier I mean the type of amplification you use to drive the main speakers. If you use stereo active speaker please consider them as stereo amplifier. (In effect they are two mono-block amplifiers.)
By xover I mean an active crossover device (analogue or DSP) either external to the main amplifier that feeds the LR speakers or an integral HP filter that is inbuilt to the main amplifier. Please exclude the amplifier that powers the subwoofers.
By software crossover I mean a digital device that is programmable, like a DSP unit.
Thank you for your help.
PS. Maybe you will consider voting on my other poll on subwoofer xover frequency?
Kal Rubinson
Industry Insider
NYC
I do crossover in software using a multi channel DAC. Voted for option #2.
I do crossover in software using a multichannel DAC. Basically, a 5.1(3) system with 5 channels plus 3 subs. No AVR, no stereo amp.
sarumbear
sarumbear
I added another answer that I hope will cover your case.
sarumbear
sarumbear
I added an option to address your case.
anotherhobby
System1: Denon AVR-X430H w/ internal 60 Hz crossover to single sub and using Audyssey room correction
System2: miniDSP Flex internal crossover at 80 Hz feeding 2 different stereo amps (one for mains one for dual subs) and using Dirac room correction
sarumbear
sarumbear
As I said on my poll description please vote according to the value on the the system where you listen to music predominantly and treat it as your main system.
LarryRS
Backert Labs Rhumba Extreme preamp to PS Audio BHK Signature 300 monoblock amps driving Magneplanar 3.7i's and MartinLogan Dynamo 1100x's. Subs have built in crossovers and ARC room correction.
sarumbear
sarumbear
That is option 1, in case you have not voted.
sarumbear
sarumbear
sarumbear
sarumbear
SIY
Alfred, NY
Amplifier?
Plate amps and monoblocks don't get counted.
sarumbear
sarumbear
Amplifier?
By amplifier I mean the amplifier that powers the main speakers. Please exclude the amplifier that powers the subwoofers.
somebodyelse
I voted 5 as it's closest, but hardware DSP crossover and multiple amp channels in the same box.
sarumbear
sarumbear
Thank you for voting. I am intrigued. What is that device?
D
Deleted member 43441
Guest
But but but… I have three subwoofers, and I use them in different ways. For home theater and music in my preamp… speakers set the small, and the same for two channel which I usually listen to in pure direct mode. As long as speakers are set to small in pure direct mode there is subwoofer output from the pre-pro.
I also use an XLR switcher to switch between my tube preamp and my pre-pro. That way I run the single ended out to the subs and let the subs do the crossover, and the XLR outs to my amps.
Choice is good at times.
Edit;
My vote was AVR LR speakers set to small
