HarmonicTHD
- Joined
- Mar 18, 2022
- Messages
- 3,326
- Likes
- 4,836
As for amps. The amps in the review index with Sinads above 100dB are certainly very good especially the Purify based ones.
However if these are out of your budget maybe consider the alternative of a very good AVR. Here you get most bang for your buck and pretty much everything you need in one box. Streamer, DAC and most important RoomEQ (room correction). Next to the speaker itself, your room, the speakers positioning the RoomEQ will contribute order of magnitudes more to a good sound in your room than all the other electronics combined. Think about it as these AVRs are most likely available in your country and you might even get used ones too.
