What's the best way to share one USB DAC between two PCs?
Chuu
I have a RME ADI-2 Pro that I want to share between a PC and a Laptop that are both at my desk. I don't need audio from both at the same time, and in fact was thinking I could just purchase a cheap USB "switch" like this this and the appropriate cables.
There are a surprising number of reviews though warning that they had these cheap switches damage USB ports when powering on and switching units. This is a dealbreaker.
Any suggestions for the proper way to do this? Is there a high quality version of this product I can trust? Is there some other way to do this that might be appealing?
Jimbob54
If you dont want a USB switch you're going to have to use one of the other inputs - so some form of converter. Could use a Topping D10 to bridge but thats $100 to not use the DAC in it. May be cheaper converting options
C
Chuu
I'm fine using a switch like this, just looking for a recommended one that doesn't have reports that it can damage USB ports.
mansr
Hampshire
Get a USB switch that doesn't fry stuff. Anything from a reputable brand should be fine.
Kal Rubinson
Industry Insider
NYC
I have used this exact switch without problems..
Aldoszx
I am using this switch for the same purpose and is just fine.
