Kimbrough Xu
- Joined
- May 18, 2022
- Messages
- 237
- Likes
- 103
What's the difference between Tuner and Radio? Why so many people use tuner? The radio is much more cheaper and convenience, why not just use a radio?
I remember the time that it became fashionable to buy an 'all in one'.yea, but it didn't make a lot of sense to buy an amp when everybody heard radio
Thank you, the explanation is pretty clear. Radio = tuner + amp + speakers.Well simply, a "tuner"just converts radio waves to audio frequencies and pass the audio signal on to an exteranal amplifier (or preamp+amp) which in turn drives the user's speakers.
By contrast and by usual definition a "radio" incorporates the a tuner, downstream amp, and speaker(s) in one unit.
Tuners can be more expensive because ostensibly they provide a more distortion-free audio signal to the downstream amplification than does a cheaper radio to its own built-in amp.
A "receiver" incorporates a tuner and amplification but not any speakers which the user must separately supply.
With a radio, the listener is stuck with someone else's choice of amp and speaker ..... usually cheap and mediocre quality. With a tuner, the listener can use their own choice of amp and speakers ..... usually higher quality.
If you have access to a high quality signal, the tuner makes more sense. If your signal quality is poor, just use the radio.
Jim
No. It seems like "separates" used to be more popular and "audiophiles" still prefer separates. But mostly you're just paying more because every device needs a cabinet, power supply, front panel, etc. And they are "specialty items", manufactured and sold in small quantities which adds to the cost. And a higher price makes anything more desirable to "audiophiles". Analog radio is the weakest link in audio anyway.One more question, is it the separate tuner is better than the tuner in a radio so that it can provide a more distortion-free audio signal? If my radio is very good quality, can it provide the more distortion-free audio signal too?
I think I have on in a closet too, but maybe I gave it away. I don't remember the brand, maybe Technics. It wasn't too expensive in the 1970's, maybe $100 USD. Oh, it is/was FM only.This post did prompt my memory that I have a Sansui tuner from the 1980s boxed away in a closet
A receiver conclude a tuner and power amplifier?Tuner: A device that converts radio waves to audio and has line-out . requires amplifier + speakers.
Receiver: A device incorporating a tuner + power amplifier and possibly other functionality. Requires external speakers.
Radio: A complete device with tuner, amplifier and speaker all combined in one device.
Car radio ... well is more a receiver (radio + built-in amp) which requires external speakers.
Vinyl + cassette + tuner + amplifier. Large devices. Worked great until one thing broke (mostly cassette player). You had to have it repaired, not use that part or buy something new.
Then came the small 'stacks' with individual components which became 'all in ones' again... CD, tape, tuner, amplifier, alarmclock. The same problem... one thing died (CD or tape usually) and you had to have it repaired or bin it.
That right there as well as flexibility and 'upgraditis' is the reason for a tuner and amp instead of a receiver.
Of course some liked dial tuning and others liked digital and presets. A separate tuner would be a cheaper 'upgrade path'.
The receiver made more sense and was less problematic (in failure rate) than the 'all in one' thingies.
Thanks.No. It seems like "separates" used to be more popular and "audiophiles" still prefer separates. But mostly you're just paying more because every device needs a cabinet, power supply, front panel, etc. And they are "specialty items", manufactured and sold in small quantities which adds to the cost. And a higher price makes anything more desirable to "audiophiles". Analog radio is the weakest link in audio anyway.
But many AV receivers don't have tuners. So a AV receiver is not a traditional receiver?
