Which THD/Sinad/IMD numbers would you consider transparent enough for your room/ears/preferences ?
Gedeon
Firstly I apologise due my very limited knowledge about some technical aspects.
I've read a good bunch of threads, articles, reviews, papers...
As far as I'm able to understand one of the highest sources of THD comes from a combination of a poorly designed amplifier with a speaker setup (or headphone) which needs more "clean power" than the amp is able to deliver.
And when talking of amps to drive speakers best numbers usually aren't better than 90dbs, and, when listening at moderate to high levels, I listen at 60-70dbs in average, with some peaks.
And in a room/house is really difficult to get less than 20dbs of noise floor.
I've also more than 50… and several times I've tested myself really unable to perceive differences between Flac and +256 mp3.
So, why I should get gear/electronics/sources/material "better" than, let's say 90dbs ?
Not trying to be ironic or to criticize. I feel a bit confused. Just wondering about some kind of "quality" threshold beyond which would be virtually useless for me, looking for gear to improve numbers with high chances, won't become in better experience.
If I'm wrong in my assumptions just say it. I just want to learn.
Thanks for your patience !!
G
Gedeon
Still waiting for some opinions. Every opinion is valuable. I'd like to read yours ... !!!
Hayabusa
Abu Dhabi
I am listening via an Marantz AV8805 with 'only' a SINAD of 91dB..
Must say I am very happy with the results..... Good enough for me.
SINAD does not take into account the psychoacoustic masking of the human ear, so you could say its not the best metric to quantify transparency.
majingotan
Laguna, Philippines
I don't have an opinion myself but someone at the other forum have their own share. BTW, in my case, my room is about 30 dB SPL and I play my speakers at 85 (min) - 100 dB (peak) with about 88-90 dB SPL average near field at 40 cm away from tweeters from my Yamaha HS7.
Hayabusa
Abu Dhabi
The numbers in this table assume you cant hear the distortion as it is below the noise floor.
But in reality you can hear things below the noise floor. So an extra margin of x dB's (dont know how much) needs to be added.
majingotan
Laguna, Philippines
True when you're not playing music. But while playing at 90+ dB SPL average and a 30 dB SPL room, my ears cannot hear sounds below 30 dB room noise floor unfortunately. Then again, at these SPLs I can hear every minute nuance on the music that would be masked on average room.
pkane
North-East
Here's my suggestion. Rather than believing what others tell you is audible, just run the test for yourself. Head over to this thread and download DISTORT. Then, pick a desired level of distortion, say 0.1% THD (-60dB) and apply this to your preferred audio test track. Then, play the two files, the original, and the distorted one on your system, at your normal listening level to see if you can spot the difference. Try it at -80dB (0.01%) level and -40dB (1%) level. See what's audible to you, preferably doing it blind to eliminate possible bias.
Ultimately, it doesn't matter what someone else says they hear, it's what you can hear with your own ears, in your room, with your system and your music. I created DISTORT for myself just for this purpose
G
Gedeon
Really great idea and great tool. Granted I'll test it and post my results.
Cahudson42
What is your music source? In my case it's Amazon Music HD streaming, which is mostly 16/44.1. So, if my system can provide it's full dynamic range of 96db (plus a bit for interconnect losses and headroom - say 105db each for DAC and HP amp..) I'm happy...No need to upgrade..
pma
Prague
The question
is pointless and these parameters expressed as numbers are absolutely unable to tell about transparency and sound quality. This path, though supported here, is completely misleading and oversimplifying, reflecting inexperience of the promoters and their purely technocratic approach.
majingotan
Laguna, Philippines
The question
Do you think then that a speaker/transducer’s sound quality is governed by SINAD if this parameter is pointless per your statement?
IMO perceived SINAD (room + audio system) is a very important factor since perceived SINAD allows you to tell what you hear is transparent or inferior (micro details, punch blah blah and all that audiophile subjective jargons are absent due to poor SINAD). At least to my subjective hearing, my perceived SINAD lets me hear the finest details and all that audiophile jargon that are absent on say car radio listening due to poor perceived SINAD
G
Gedeon
The question
I'm really curious about which numbers/measures do you suggest to serve way better in the goal of objectively "value" audio gear. Honest question.
LeftCoastTim
At typical listening volumes, -75dB is below my threshold of hearing.
So -85dB is more than plenty for me.
I should post my test files so others can try out what -45, -65, -75dB sounds like on their systems.
flipflop
Measurements related to frequency response (e.g. output impedance, channel mismatch, and FR itself) give a much more comprehensible insight into audible problems IMO.
Floyd Toole has also expressed his dissatisfaction with distortion measurements on a few occasions. One example: https://www.audiosciencereview.com/.../speakers-and-im-distortion.8082/#post-198783
To anwer your original question, although I haven't done much testing on myself, I'd guess all types of distortion below -80 dBFS would be inaudible to me under any circumstances.
solderdude
The Neitherlands
Dynamic range tests I performed on myself told me 80dB difference is enough for me to not be bothered by anything as low as that.
So a signal/grass ratio in multitones below 80 dB is good enough for me. So SINAD of 85 is already sufficient for me.
Would like to see microphones and recording studios reach that as well.
Sal1950
The Chicago Crusher
Central Fl
Agreed, if held to the stake 80-85 is what I'd give
Mulder
Gothenburg, Sweden
As I have understod it, the hypotetical level of transparency on an individual level is said to be 115 db. Where do this numer come from? Is this number verified in controled tests?
BDWoody
Chief Cat Herder
Moderator
Mid-Atlantic, USA. (Maryland)
These two threads may help.
Frank Dernie
Oxfordshire
I have tested me.
I can barely hear a sound if I turn the volume down 60dB.
From this I deduce that if there were a distortion artefact at that loudness I would only just hear it without music playing, if music were playing I am quite sure it would be drowned out (for me).
I can't speak for others but I am satisfied that I wouldn't heara distortion level at -60dB.
That goes for noise too whilst music is playing but I suppose having a hifi switched on with no music playing having audible noise in the room would irritate so I guess -80dB would be fine for noise.
People get confused because the loudness range of all sound is far more than this, but music recordings don't ever use the whole dynamic range of the music if it is huge simply because 99+% of people don't possess anything which could play it and anyway there is a volume control.
