Which two phono preamps do you want measured?
I have three phono preamps that I have bought. Pick two that you want to be compared against each other in the first round:
ART ART DJPREII Pro Audio DJPRE II Phono Turntable Preamplifier: https://smile.amazon.com/gp/product/B000AJR482/ref=od_aui_detailpages00?ie=UTF8&psc=1
BEHRINGER MICROPHONO PP400: https://smile.amazon.com/gp/product/B000H2BC4E/ref=oh_aui_search_detailpage?ie=UTF8&psc=1
U-Turn Audio - Pluto Phono Preamp: https://smile.amazon.com/gp/product/B018WK56JE/ref=oh_aui_search_detailpage?ie=UTF8&psc=1
And provide any special measurements you like to see.
RayDunzl
Central Scrutinizer
Riverview FL
Behringer and another.
Blumlein 88
Pluto and Art.
Then later, Behringer PP400 vs Behringer Uphoria using the mic pre's as phono inputs.
Are you going to use an actual test record?
No, I am using my analyzer to generate signals and then make measurements using RIAA corrected filter.
I may do some listening tests with my ancient turntable if it still works. :)
Blumlein 88
How would RIAA correction be applied in the case of latter?
You could do it with digital EQ after the fact or by using some good EQ in DAW software real time or thru other convolution software like that used for room correction.
I don't know if you have any DAW software, but Reaper has a couple plugins that could do it. You can try Reaper for free if you like for an unlimited time.
REA-EQ is a parametric EQ based upon IIR filters with as many bands as you wish. REAFIR is an FFT based EQ. Both are included. IIR would be more like analog filtering for the RIAA curve.
You can see screenshots of the controls halfway down this page.
http://reaper.fm/reaplugs/
Blumlein 88
Ah OK. I thought it had it built-in or something.
No, but a number of people have used microphone inputs for ripping LPs. The tricky part is the input impedance will not be the 47 kohm most moving magnets are looking to find.
Wombat
Australia
ART and Pluto
Then Cambridge CP2 and NAD PP4( with USB). Also ART Phono Plus( with USB) and Technolink TC Link TC 756 USB. Not budget breakers.
deniall83
Australia
If you're able to get hold of the Schiit Mani and Lounge Audio LCR MKIII I would love to see measurements on both.
Wombat
Australia
It would be nice to have a change from DACs and headphone amps. :)
SIY
Alfred, NY
If memory serves, Scott Wurcer did some measurements on the Lounge preamp and found that RIAA conformance was terrible. The whole LCR equalization thing that is the selling point seems contrived. It's a unit I'd also like to get my hands on for some detailed measurement.
restorer-john
That's back to front.
The reverse RIAA network/attentuator must go between the analyzer generator output and the input of the phono preamp. Measurements are made directly from the output of the preamplifier.
You can't feed a flat signal to the phono stage and do the reverse RIAA correction on the output- the results will be meaningless.
That is where it is:
