NorthSky
- Joined
- Feb 28, 2016
- Messages
- 4,998
- Likes
- 946
These are the results I'm seeing -
setup A - Yamaha AVR RX-V675, 90dB efficient speakers
setup B - Denon AVR X2200w, 95dB efficient speakers
Ran the autocal routine for both to let AVR calibrate speakers.
With A, I watched movies at -20dB. With B, Audyssey Dynamic Volume and DEQ off, I need to watch almost at -5dB to get the same loudness, tested with SPL meter. I have never listened near reference, it was simply too loud, and I don't understand why it needs to be turned up so much now, esp with speakers that are much more efficient.
I know the standard answer is 'ignore the volume reading' but this does not add up.
________
I did not have any EQ to speak of with Yamaha, I had run its YPAO but the differences in enabling it were minimal, I only used it to set the speaker distances/levels, which I checked with SPL meter also, and ran with it off.
With all EQ off on both, I have to turn the Denon volume up a lot more.
________
The Speakers are 5dB different in sensitivity. I got that, but why the two AV receivers so far apart with their volume settings for the same volume level?
One set @ minus 20db, and the other set @ minus 5dB (a difference of 15dB on their level settings). If the difference would be around 5dB, to take consideration of the two different sensitivities of the speakers, that would be more understandable, but 15dB difference?
Any idea, anyone, scientific audio expert, or not?
________
________
