Why are preamps so expensive?
restorer-john
Although the device was developed 45 years ago, its performance, e.g. distortion factor < 0.003%, noise figures etc. have only really been surpassed in the past few years.
The power amplifier SE-A1 also set standards, real 350W class A continuous power (20 - 20,000Hz) at 4 and 8 ohms/channel, damping factor 100 at 8 ohms, 275 watts input power in idle mode, nominal distortion factor 0.003% (at nominal power, 20 Hz - 20 kHz), signal-to-noise ratio 120dB, and a total harmonic distortion of 0.01% with a power bandwidth of 5Hz-100kHz (not only at 1kHz ;o).
That was 1977!
The figures published as specifications were also extremely conservative. They were guaranteed worst case numbers, unlike the best case, single frequency numbers published by so-called SOTA manufacturers these days.
Distortion numbers have not got better in today's 'SOTA' proper preamplifiers. And proper preamplifiers have a range of controls, inputs, tone circuitry, filters and high quality RIAA stages. The single stage, op-amps-in-a-can being held up as 'preamplifiers' by the un-informed in 2022 make me laugh.
Here's an example of one of my vintage (1983) Denon preamplifier's specs:
I cannot measure the THD of my unit- it is below the residual of my test gear and much below 0.001%, at any frequency. All I can see is mains spurs which are the only factor in reducing is S/N. And they are so far down it doesn't matter.
Preamplifiers were a solved problem 45 years ago and have only got more and more stripped down, devoid of actual usefulness and basically a waste of money for anyone who actually has more than one or two pieces of HiFi gear.
restorer-john
No, Panasonic's professional audio division was Ramsa, and if you needed a signal generator, there were many less expensive ways to get one.
Actually no. Ramsa was not even thought of, letalone incorporated in 1977 when this preamplifier had already been designed, produced and marketed. Ramsa did not come into being in Japan until 1979 and nowhere else until 1980.
Steve Rogers
I understand that for someone with one source and a power amp its a waste because they can use a dac such as dx3pro+, but what does someone with multiple sources and a poweramp do?
restorer-john
They buy a decent preamplifier I guess. :)
Rotel make a few.
What you are paying for with preamplifiers such as the Rotel above, is digital sources. The specifications are average at best and don't come remotely close to analog only preamps from the past unfortunately.
Roland68
Cologne, Germany
As unlikely as it may seem, this extremely costly preamplifier was intended as a "statement" product, and I'm aware of no profession that needed it's particular set of features. Products like these were money-losers, but they brought prestige to the brand and helped to sell more ordinary products. Nakamichi, Sony and Kenwood/Trio also produced costly and exotic flagship products. In the automotive world, the 2000GT was Toyota's statement product in the 1960s, and around the same time, Mazda introduced their first Wankel-powered Cosmo sports car.
Japanese companies still produce "statement" products today, though they're generally much more modest in scope: Sony's Alpha 1 camera sells for a relatively modest 5999 USD. Some people purchase them to photograph the grandchildren.
Of course you can have your opinion.
In reality, I met a developer around 2001 who had been using this device for his developments and as a reference for over 20 years. I also know from him that most of these devices were supplied to audio manufacturers/developers and universities. Among other things, also to two well-known manufacturers in Germany and the USA.
Unfortunately, most of these developers are now deceased.
Roland68
Cologne, Germany
If you look at a company like NAD which is good for value you can buy:
NAD C 165BEE pre amp for $1200 + NAD 268 power amp for $999
NAD 368 which is basically the 268 and a pre amp combined (and with a dac and bluetooth too) for $1200
The 368 even offers a stereo RCA preamp output for connecting a separate amplifier or powered subwoofer!!
Other companies are similar - you play a real premium for a pre amp as opposed to an intergrated or power amp with DAC (that can act as a pre as pointed out). It looks to me pre amps are a real rip off.
Without wanting to offend you, but that is a definite apples-and-oranges comparison.
The NAD C 165BEE is a very complex preamplifier in which one of the most capable developers (unfortunately passed away 3 1/2 years ago) and his team invested several hundred hours of development time. The technical effort in all areas, solutions and components speak for themselves. With so-called high-end manufacturers, you pay a multiple for such complex devices.
The preamp section of the NAD C 368 consists of a simple input section with phono amp and input switching, an NJW1194Volume CONTROLLER and 2 OPAmp. The relays used in the C 165BEE alone are significantly more expensive.
This should not say anything about the performance of the two devices. The NAD C 368 is a great device with a very complete equipment.
With the C 165BEE, the developer has simply shown what is possible for this price. The components used are not exactly cheap and the costs for the development should be in the 6-digit range. Due to the smaller number of units, the profit from the C 165BEE project will certainly be lower than from the C 368 project, both overall and per unit.
Steve Rogers
on the contrary, Thx for explaining.
djtetei
România
@DesertHawk Why are preamplifiers so expensive? Well, because, truth be told, they can afford to be and because some people simply want them, like them or don't know better...
Whenever you want to use multiple audio sources and feed them to the same amplifier, you can insert a very well built and high quality studio controller or audio mixer, with multiple stereo channel inputs, rotary gain controls, rotary faders, balanced master outputs and independent input/ output accurate level meters, between your sources and the amplifier. The price performance ratio will beat any hi-fi high-end "audiophile" and "neatly dressed" preamplifier and you have total control on the input and output signal, not to mention other practical uses.
I never use preamplifiers, except for instruments, microphones or turntables.
Gorgonzola
Southern Ontario
And here's a very reasonably priced preamp for contrast.
For $399 you get a DAC with Bluetooth, FM Tuner, MC/MM phono stage, a trigger output, subwoofer crossover, and a remote control.
The Emotiva BasX PT1 certainly has a lot going on for US$527. How good it is is another matter -- send Amir copy to test. Not to mention it isn't balanced. Not all Emotiva products have been "golfing panther" great.
Gorgonzola
Southern Ontario
I could have and did drive my VTV amp directly from my Topping D90 DAC. But now I do so with my Sonic Frontiers Line 1 SE+. I paid US$900 for the preamp then I popped an additional $1200 for the "SE+" upgrade. Worth it? Depends how you look at it: a used McIntosh or ARC tube preamp would cost more than the US$2100, especially after a full restoration and upgrade.
One thing is for sure, there's a lot going on inside the fully balanced & differential SF Line 1 and one has to pay for it. OTOH you CAN buy a remote controlled, Bluetooth equipped preamp for US$70, (see here) that uses the very same volume control chip as the Line 1. Make your choice and pay your money ...
gi.mpl
rwortman
Exactly, so why does a consumer pre that does less cost more? And don't tell me economies of scale, theres way more preamps being sold then mixers.
I know this is an old post but you may be underestimating the market for mixers, especially the cheap ones. Every amateur and professional band has at least one. Every church and most schools have one. Fairs, sports stadiums, concert venues big and small, business conference centers, radio stations, home and pro recording studios, TV stations. I am the only person I know locally that owns a preamp. Without driving more than 5 miles I can put my hands on at least 15 mixers.
rwortman
I run a mixer once a week that costs a little more than half what my preamp costs. It can be remote controlled from my Ipad. We have a Behringer rack mixer that costs a tenth of what my preamp cost and has to be remote controlled. My home preamp is optimized for it’s job. Using a mixer would work but be a lot less convenient and I would have to buy another phono preamp. Half the cost of my preamp is probably the casework. So? Half the cost of my car is probably the bodywork and paint.
djtetei
România
mixing balanced and unbalanced sources and outputs
Key word: mixing
Password: mixer with multiple stereo channel inputs (balanced/unbalanced), individual channel gain control (mandatory), equaliser (optional) and level meter (recommended), PFL (pre-fade listen), balanced and unbalanced master output, accurate master level meter.
Angsty
North Carolina, U.S.
Probably worth sending in a couple of mixers to Amir to see what the SINAD measures to to be. Preamps and/or mixers need to have high SINAD to achieve transparency. My old cheap mixer days were anything but that.
I currently own three preamps and one integrated amplifier. I've been using my current main preamp for more than 15 years because of it's transparency.
djtetei
România
Would you consider a mixer with THD+N of 0.0025% and dynamic range of 113 dBU (unweighted) to be transparent enough?
Angsty
0.0025% THD+N is low enough that no one should tap the mixer as a problem.
djtetei
România
Then, take a look at this little baby boy:
Small, affordable, useful and good sounding, courtesy of a manufacturer who really knows how to make a good mixer.
MTZ
Germany
A few years ago i purchased a Yamaha YPC-1 passive preamp and a Yamaha MX-D1 for a bargain.
I'm using the YPC-1 since that time and i like it a lot.
One of the presumed benefits is that both of the dac's i use have been set to the correct vrms output for the power amps to create the optimal settings.
And not to forget the benefits of the source selection functionally off course.
I'm not a technical engineer so i could be completely wrong about the assumption on the vrms output.
Angsty
I found this bit of advice to be on target and useful from a Topping DAC review...
"Any DAC with an SNR of 120 dB or less should be used with a good analog volume control (using relay ladders for example) found in a high-quality preamp." Otherwise, you should use the volume control in the DAC versus that in the preamp.
Two of my three DACs are less than 120 dB SNR so using high-quality preamps makes sense in those cases, especially where both analog and digital sources are used. One of my DACs does not have a remote for volume or source control. Personally, using a mixer as a preamp doesn't work in my set-ups unless the mixer also has remote control.
