Why DAC filter tests always use illegal square waves for impulse response?
Oklei
On time domain dac filter tests here and pretty much everywhere else the response is always shown with an squarewave that has more bandwidth than possibly could be in a real recorded digital signal. During adc or while downsampling to 44.1khz higher frequencies have to be filtered out to prevent aliasing. If this is done properly, the recorded signal does not include any frequencies higher than 22kHz anymore. So a squarewave impulse response seems senseless.
We need a low pass filter during dac to attenuate imaging and want the filter to be mostly accurate to the recorded signal in the time domain too. Mathematically unavoidable sharp filters do more harm in time response and less in frequency response and slow filters the other way around.
But why not use the steepest 'square' wave a signal can have at a given sampling rate and bandwidth and compare that to the filter response? Wouldn't that be much more a real world approach to see if the filter really does harm to the time response of actual correctly recorded music than use a square wave that couldn't ever possibly be in a correctly recorded signal at that sampling rate?
Blumlein 88
Could you give examples. Most of the time I've seen them use a single impulse response. One bit to max level also called a Dirac pulse.
I've also seen people use white noise at a rather high level to see the filter response.
As for square waves, they are a fundamental and the odd harmonics. The squarest wave possible in a bandwidth limited system will be the lowest frequency. 1 hz square waves or 5 hz square waves will have more of the harmonics than a 10 khz square wave. Giving it a more squared appearance.
Oklei
Oklei
Oklei
Oklei
I find this a bit misleading as one would compare the filter output to the entered square wave and is seeing all the ringing. But that ideal input square wave has unlimited bandwidth and could never be in a proper recorded anti aliased music file. The same argument would also apply for a Dirac pulse. To generate one properly you would also need unlimited bandwidth which cannot be in the adc filtered recorded file. So this can resolve filter problems that just wouldn't exist in real life.
Blumlein 88
The purpose of those 'illegal' signals to a DAC is to see the filter response. Overly much has been made of how they 'ring'. An ADC fed a squarewave of wide bandwidth will filter out the excessive frequencies and what it records will look much like the DAC filters with the Gibbs phenomena of 'ringing'. You then feed that to a DAC and it outputs the same shape (assuming ADC and DAC have the same filter). Using those illegal signals fed to a DAC give you the type of filter response without influence of the filter in the ADC. So it makes sense as a test signal, but not much else.
dc655321
A square wave with a suitably chosen duty cycle will encode time-domain characteristics of the filter in its output.
For the example you posted above, we can observe that the filter is minimum phase, it's length is > 500 us, etc
DVDdoug
They aren't "illegal". A CD can contain square waves (or clipped waves) and some digitally-generated music contains square and rectangular waves.
NTK
US East
To assess the characteristics of a filter, it make much much more sense to look at it in the frequency domain, i.e. look at the frequency response (including phase). How does one figure out what the cutoff frequency, slope, phase response, stop band rejection, etc. from looking at a square wave response?
Blumlein 88
Illegal in the sense that no ADC>DAC loop would contain those frequencies above the normal cut-off for the sample rate in use.
restorer-john
There's nothing "illegal" about the signals- that's a ridiculous assertion. At what arbitary point do you think a signal becomes against the law? A digital playback system is just that. Whatever signals you want to place in the data stream are perfectly valid and the D/A should reproduce them.
If you want to consider an entire chain from analogue capture to playback, clearly some signals cannot be captured, but we are talking playback systems here. If I can put it on a disc/file whatever- it is valid.
If you take an early 16/44.1 R2R CD player and tap in right after the IV converter and before the LPF, you have beautiful and perfectly square waves- no under/overshoot. Do the same with a single impulse and that's all you get- a single impulse, one sample wide. All compact disc tests discs from day one contained digitally generated impulses, squares and signals to test the system.
dc655321
Yes, for sure. Frequency domain is much more useful for filter assessment.
I know you know this, but at least for the case of sinc-function filters the corner frequency can be gleaned from the roots (zeros), and the phase response is of course trivial given the length. In theory...
NTK
US East
My point is how do you know for sure from looking at the waveform it is really a sinc function? May be the amplitudes are off or shaped by a window?
dc655321
Thus, my cryptic, "In theory..."
As you say, can't know for certain. I'm fine with guessing for back-of-the-envelope estimations.
Reactions: NTK
LTig
Europe
That's what I had thought as well until someone here showed not long ago that no digital signal is illegal[1]. Just feed the analog signal at the output of the DAC to an ADC and you will see this 'illegal' signal in the captured PCM data.
[1] Except for intersample overs which neither the DAC nor the ADC could handle.
LTig
Europe
I agree except for intersample overs. Most DAC's are unable to reproduce them properly, and @ayane has shown that they can be much higher than +3dB.
restorer-john
Intersample overs are basically the result of faulty recording practices. Basically, clipped peaks in the digital domain. Hardly the job of a DAC to re-create what was chopped off in the first place.
But the problem doesn't really rear its head in 16/44 playback with R2R DACs. The filtering was analog with significant headroom by default from the supply rails for the IVs and active LPFs. This is a 100Hz Square wave (digitally generated) into a Sony CDP-101 (word's first CD player). 16/44 NOS.
Note, we have instananeous rise (<40uS) with no pre-ringing, ~25% overshoot headroom.
JohnYang1997
China
It is illegal in the sense of sampling. Yes a CD can contain those signal but it doesn't make it not illegal.
Such files will never happen after A to D conversion with proper filter. It exists because digital processing.
JohnYang1997
China
The gain in the A to D conversion must be low enough to not have clipping. And this will pretty much guarantee DAC not to clip. It's not the shape itself but the shape + amplitude.
LTig
Europe
Yep, and you need an analog level meter to control the peak level, not a digital display behind the ADC which cannot detect intersample overs (at least not without first resampling the PCM data to a higher sampling rate with some digital headroom).
