Why Don't High SINAD Receivers Exist?
Vincentponcet
You can easily get 8 channel DACs. Dirac can run in software upstream of the DAC as I use.
Dirac is selling multi channel software ?
On their website I only see 2.0 or 2.1, but no more.
Their website is not very clear.
Dougey_Jones
The Lexicon RV-9 touts Dirac Live, Class-G hybrid amplification and high end DAC’s. Im hoping Amir gets his hands on a sample to see if the measurements justify the hype.
Even 100db SINAD would be really impressive.
Fitzcaraldo215
I have used Dirac 7.1 Mch software since about 2016 on my PC using release 1.
It handled 196k PCM. I had no complaints about it or about or about the ExaSound E28/E38. In fact, I loved them. Really, they are absolutely the very best sound that I have had, superior to AVRs, prepros that that I have experienced.
The Release 2 or 2.1 are in Beta testing for the PC now for Mch. I am dubious as to whether in might take an another year or two in Beta. But, try release 1. I would try.
Thanks, by the way to Kal Rubinson. He help me and guided all the way, even to an “early adopter” model to Dirac and ExaSound. Beautiful.
They did when I purchased my Dirac EQ for Windows. That version has been deprecated unfortunately so don't know what is there now.
tifune
I couldn't figure it out either, so I asked their support and they sent me this:
https://live.dirac.com/content/uploads/2020/03/setupvsthostwithdlp.pdf
On PC at least it's become a VST plugin and can be used w Jriver, EqAPO, etc. But that link is their official recommendation. Presumably same for Mac but I have no footing there
I'm still not totally clear on how the new bass management option fits in to the chain, nor do I understand how the channel routing would occur. Can I buy a 2nd 9038S, for example, and use EqAPO to select which channels are subs/mains? Or does it need to be a single unit like Okto DAC8, miniDSP SHD, etc
detlev24
It seems, for PC, there is still some Beta Testing for Dirac Live Bass Management ongoing. So far, only 2.n system layouts are supported.
Dirac Live Bass Control is already available for some AVRs, if I am not mistaken.
Wouldn't the bigger challenge be (how) to decode (proprietary) multi-channel audio on an exclusive PC setup? Most DSPs/DACs - for computer audio - do only process up to 8-channel PCM.
datrumole
so, i use an HTPC at every one of my TVs. plex and yttv are my only sources of material. only have a 5.1 since my couch is against the back wall the additional rear channels never excited me
htpc (usb) --> udac8 (rca) --> 500asp/500a/500a for LCR
--> (2) inuke 3000d for subs
--> topping tp22 for surr
on all of my HTPCs i use EqualizerAPO to provide all of my room correction and channel separation. i've mucked with convolution filters (like how DIRAC works to a certain degree) however i've suck with just the standard peq as i felt the convolution filters cause a lack in dynamics, but i may revisit. also, i'm not aware of how i would generate the convolution filter for each of the speakers as a lot of software (or at least 2y ago) was only 2ch focused
after reading your udac8 review, i realize i may want to look at different options for 8ch out (really only need 7) and if i HAD to make it work with the ADA of the iNuke, i guess i could possibly get away with 6 (lord only knows how bad the inuke dsp chips really are)
so what 8ch DAC do you use or even recommend? ideally around that 3-500 dollar price range? using an AVR for preouts is an easy answer, also puts me at 1k, but unnecessary for sure
Vincentponcet
okto dac8pro, top of line 8 channels DAC for 1K
https://www.audiosciencereview.com/...d-measurements-of-okto-dac8-8ch-dac-amp.7064/
I plan to use it with Jriver, which supports all multi-channels codecs except atmos/DTS:X (through LAVFilters and related ffmpeg decoders)
datrumole
yeah, saw that, 1k is still more than i was hoping to spend considering the theme of this thread is the exception 100db+ 2ch DACs for ~100
there's got to be a way to get the 8ch I2S/ADAT/TDM out of a USB/MCHstreamer, and throw it to (4) replutable ~100ish 2ch DACs for around $500?
edit: Could you hook up (4) hifiberry DAC+ Pro's i wonder off a MCHstreamer I2S?
Vincentponcet
there's got to be a way to get the 8ch I2S/ADAT/TDM out of a USB/MCHstremer, and throw it to (4) replutable ~100ish 2ch DACs for around $500?
How are you doing volume control then ?
Adding a multi channel preamp between the dac and the amps ?
Vincentponcet
Windows volume mixer might not be that good.
As I understand, internal volume control of the DAC chips manage volume in the modulator of the delta sigma, and that it has less loss that a pcm volume control.
kaa
I have been trying to find a good DAC setup for my Stereo/Home Theatre. Here are pieces of the puzzle so far.
All sources (streamer, consoles etc.) --> TV (C9) --> eARC --> DAC (dac8 pro) --> Minidsp 88a --> AMP.
Missing pieces:
1. eARC --> DAC: I haven't found a device (DAC?) which can support this conversion. I have a 5.1 channel system so Atmos is not a requirement. Hence I could use the optical out from the TV instead of eARC. But how I get optical out to a usb in for the DAC8 pro?
2. Volume Control: I was thinking of a pre-amp like the Parasound P7 between the MiniDSP and AMP. Not sure if this would work or is optimal setup.
Appreciate any inputs or suggestions for the missing pieces or any other advice to get a good DAC setup for Stereo/Theatre use.
Kal Rubinson
Industry Insider
NYC
1. Why would you put the MiniDSP after the DAC? Doing that, its A/D/A defeats all the value of the DAC8.
2. When you figure out the eARC(HDMI) --> DAC link, you might consider finding a discontinued miniDSP nanoAVR for EQ.
kaa
Thanks. A newbie here... so some follow-up questions:
Does that mean, I have a choice of a good DAC or Dirac Room Correction but not both?
DDRC-88a Image
detlev24
Exactly. Unless, you go for the DDRC-88D, which is fully digital. // Edit: Or, you use the MacOS + Windows 10 software and a host like 'JRiver Media Center 25' or 'foobar2000' (no miniDSP hardware required).
Note, that the DDRC-88D's internal sample rate is 48 kHz in any case. In terms of audio fidelity, this is more than enough! However, higher quality external re-sampling to 48 kHz, prior to the DDRC-88D, might provide better results [on measurements].
Reactions: kaa
Vincentponcet
Dirac does not provide a pure software version of their algorithms in multi-channel configuration.
They did it some years ago, but no more today. Latest software is 2.x only
Objectivist01
Missing pieces:
Does c9 support bit perfect out ?
Kal Rubinson
Industry Insider
NYC
There is a beta out now, so public release is imminent.
