board
- Joined
- Apr 24, 2019
- Messages
- 250
- Likes
- 184
I brought this up in the Mofi StudioPhono review thread, and I'm hoping you all can help me with figuring out this issue. Sorry for the long post.
My turntable is a Rega RP3 from 2014 with a RB303 tonearm.
My cartridge is the moving coil Audio Technica AT33PTG/II. I have two of those: One I've used for a while, and one which is almost new.
So, I moved to a new house recently, and I recorded some records onto my computer that I had also previously recorded before moving, and I noticed that when I use the plugin CurveEQ, where an orange line shows the difference in EQ between two songs, the frequency response drops in the high frequencies in the new recordings compared to the older recordings. I tried this with more than one recording, and they show similar results.
First I thought my cartridge was broken, but I mounted the identical, almost new, one instead with similar results; then I thought my Mofi StudioPhono preamp was broken, but apparently it's not, because I just bought a Cambridge Audio Duo that gives almost identical results.
So, the difference between a recording from before moving and after moving looks like this, done with the same phono preamp, the Mofi (the recording after moving has less high frequency energy):
To avoid boring you with too many charts, I'll just say that comparing recordings done with the newer and older cartridges in my previous two houses (also recordings done with one cartridge in one house compared with recordings done with the other cartridge in another house) essentially shows a completely flat line. I also had a third AT33PTG/II, now a bit broken, and they all had almost identical frequency responses.
So, I figured that my Mofi phono preamp was broken, so I just bought a Cambridge Duo phono preamp today, and the difference between the Mofi and the Cambridge looks like this:
So, the Mofi has slightly more energy around 40 Hz and at the very top (or, conversely, slightly less energy between 40 Hz and 700 Hz), but it's negligible - especially compared to the difference in the first chart.
I have ruled out my A/D converter, a Focusrite Scarlet 2i2, as I did two things: One was run a cable from my DAC into the Focusrite to record a linear sweep, and the result was complely flat. The other thing was to do the same thing with a piece of music and then load "before" and "after" in CurveEQ, and I got a flat line. I used the same cables for recording from my DAC into the A/D converter as I did when recording from the phono preamp into the A/D converter, so it can't be that cable either.
The turntable is placed on top of the same rack as in my previous house, although I didn't have this rack in the first house where I lived, but comparing recordings between those two previous houses didn't show anything noteworthy. I've checked with a spirit level that the rack and the turntable are level.
On the Mofi preamp I've used 100 ohms, and I tried changing it to 1000 ohms but with no difference. The Cambridge preamp can't be adjusted.
I also tried changing the tracking weight from 2,0 grams to 1,8 grams and 2,2 grams. No noticeable difference.
As for the recordings I've made, the only difference I hear is a lack of high frequency content. I used CurveEQ to apply the reverse of the curve in my first picture to the newest recording, boosting the high end, and then the recordings from before and after moving sound identical to my ears.
I can of course send recordings to anybody interested.
So, I'm thinking that the issue could be one of a few things:
* My tonearm
* The cable that comes out of my turntable. It's fixed, so I can't replace it.
* The temperature in the room. As unlikely as this sounds, I was reading about it, but I'm very skeptical. My current room is a bit colder than previous houses, but I usually do heat it up while I'm here, but I think the difference to previous houses would at most be a few degrees celsius. Also, I haven't seen differences like these before between recordings done in different temperatures in previous houses.
* Something else that I haven't thought of (?)
Does anyone have any ideas to what the explanation could be? I don't have any measurement gear at all, which is one of the reasons why I use CurveEQ, so hopefully one of you can help me figure out what the issue is.
* My tonearm
