- Joined
- Mar 1, 2016
- Messages
- 803
- Likes
- 1,613
According to https://www.bluetooth.com/learn-about-bluetooth/bluetooth-technology/le-audio/ the answer is yes.
According to this graph:
LC3 would be able to stream 345Kbps, so nothing new if we consider codecs like Aptx (330Kbps), Aptx-HD (576Kbps) or LDAC (990Kbps). In theory, tho: BT 5.0 was announced as supposed to be able to go up to 2Mbps... And we didn't see anything like that quite a few years after...
Then, it still Huawei, who announced fall 2019, it's BT-UHD proprietary codec. This one is supposed to stream up to 2,1Mbps. To my knowledge, no one has been able to check this claim in practice.
If the world worked properly that would make this happen, but as no-one gets paid it's less likely to happen.SBC is open source and royalty-free, making the above claims easy to test.
it will be really interesting to see what sort of products companies like Audioquest start to sell
A cat's-whisker or germanium diode could be imaginatively packaged as an "RF-absorbing aether purifier".I'm imagining personal faraday cage listening booths, but then I realized that those might actually make a measurable difference and have a scientific theory supporting their utility. So you're right, it will probably be magic RF-absorbing rocks or something like that instead.
What is the y axis?According to this graph:
How does Bluetooth sound today?
It's lossy, right?
Is it worse than mp3, or ??
Glad you asked! Yes, Bluetooth audio's default Codec, SBC, is lossy. You can decide for yourself:
Go to
https://btcodecs.valdikss.org.ru/sbc-encoder/
then upload your favorite track, switch Profile 3 to "None" (i.e. no codec, so the original audio) and compare to Profile 1. Profile 1 should default to the so called SBC high-quality, but change Profile 1 to Codec=SBC, Channel Mode=Joint Stereo, Subbands=8, Allocation Mode=Loudness, and Bitpool=53.
If you hear distortion on Profile 1, try increasing the Bitpool until you cannot. Or you can decrease the Bitpool until you perceive the distortion. Although not a valid double-blind test, it should give you some intuition about what bitrates SBC needs before you determine it to be free of distortion.
As to comparing SBC to mp3, as mp3 uses psychoaccoustics (and to less extend, so does SBC), it is not a simple quantitative comparison. soundexpert.org runs a bake-off for varying codecs at various bitrates. His results are based on volunteer human tests. In general, he finds that mp3 at 320 kbps is judged superior than SBC at 328 kbps. However, it is possible to increase the bitrate of SBC so as to be preferable to mp3 at 320 kbps.
