Will this DAC work with this DVD player?
Pacific Northwest, U.S.A.
Hi All,
I really appreciate everyone on here as you have been extremely helpful with my system.
I'm helping a friend out and what we are trying to do is have a CD player with a balanced output, but also bluetooth and other types of streaming ability. Emotiva has a balanced out CD player, but not with BT etc. Some of the other products I've seen don't have great sampling rates, etc. (Such as Denon DN-500)
So, I've landed on using the DVD Player I currently use (Sony) and the SMSL DO200 MKII DAC.
My hope is that the DVD player Audio Only HDMI Out Port will output audio to the SMSL DAC, which I can then output from the DAC to a balanced Pre-Amp.
Will it?
Thank you!
audio_tony
Leeds, UK
It won't work. The Sony player doesn't have coax or optical outputs as far as I can see.
The SMSL DAC doesn't have HDMI inputs either.
EDIT: It will work - oddly it's not mentioned in the specs, but the player does have a coax output.
EDIT (2) if only I read the specs on Amazon in more detail....
Bring your equipment together Connect your AV technology to the UBP-X700 with Ethernet, HDMI and Coaxial SPDIF
Oops, sorry OP.
347cf593e6a64915d3f0f1dc2fa6447d
DVDdoug
I don't think it can decode Dolby from a DVD. Most stand-alone DACs can't.
MajorMajorMajorMajor
Well I guess the SPDIF is a digital out I didn’t even think of that
Zek
Audio CD -> Sony -> Coax Digital Out -> Coax In on the DAC
