Wiring for internal connection between DAC and Amp
taylptrsn
Atlanta
Long story short i am trying to reproduce this
and this is the wire most readily available to me (At my local microcenter) https://www.amazon.com/Shaxon-SO18-...per+wire&qid=1566564194&s=gateway&sr=8-2&th=1 Do you think this wire is poor enough quality to affect sound between the devices?
SIY
Alfred, NY
I hope you'll do better than that dreadful hot melt assembly!
In any case, don't sweat the hookup wire, it's not even vaguely critical.
Julf
Amsterdam, The Netherlands
SIY
Alfred, NY
Zek
PVC will actually degrade performance in some cases.:cool:
SIY
Alfred, NY
Trying to confuse a newbie seeking help by feeding him false information is absolutely not cool.
Blumlein 88
The wire would be fine. I'd probably go with 22 awg if it were me, but not for sound reasons. Even stranded if working inside a small enclosure 22 awg is easier to bend around the way you want it to fit.
If I wanted to show it off I might even go with the teflon as the semi clear teflon around silver wire looks really cool. Won't sound any better. And can be tribo-electric in some instances, but likely not a problem inside a case.
