And that room really looks like it could use some actual diffusers...I missed that PDF and commented on what the post highlighted which was soundproofing.
What is on the PDF is certainly diffuser but why use a single dimension one? How about 1st and 2nd reflections from the ceiling? The cost of a 3D diffuser is not much higher in the grand scheme of their operation.
Only at very high frequencies. I see it more as a deflector which diffuses slightly. And more importantly you can put it away when you aren't listening. I haven't bought them yet.It’s an absorber
Those diffusers made with Lego look cool.Building a diffuser with duplo has been done before. I've seen it been used in the studio of Wintergatan, designed by ID-Acoustics. You can see it in this video below at 11:30 mark.
You may see them as such but they are not.Only at very high frequencies. I see it more as a deflector which diffuses slightly. And more importantly you can put it away when you aren't listening. I haven't bought them yet.
What a beauty!I made a diffuser out of wood. You need to be confident in your fixings!View attachment 242260
Styrofoam is not a good material to build a diffuser. As I keep repeating, a diffuser is a reflector. Any type of foam is an absorber.So... where can I get one of those tools to cut Styrofoam??
However, I they covered the foam surface once it’s shaped, with a thick material, maybe the result will be satisfactory.
You can make one with nickel wire and a DC power supply. Use springs across the nickel wire to keep it tensioned and increase the DC power across the wire till it gets hot enough to melt the styrofoam.So... where can I get one of those tools to cut Styrofoam??
The requirement is for the material to be reflective within the range it is designed to operate. Most rigid materials are reflective.In post #19 you said the important is that the material is rigid, which styrofoam is.
Is there a description, in technical terms, of the properties the material must or must not have?
Foam rubber or rockwool are absorbers and have no place in a diffuser.Styrofoam seems an interesting choice to me as it can be reflective above a certain frequency and absorbing below that, isn't that true? First of all, it's pretty hard on its own, I would think it is already much more reflective at mid and high frequency than, say, foam rubber or rockwool. And it's closed cell, you don't even need to cover it.
Polystyrene is better than Styrofoam but nevertheless it is still more of an absorber than a reflector. Both are used for insulating sound not reflecting. If a plastic material must be used Melamine is an option.In fact, I doubt the absorptive properties of styrofoam, not its reflective properties. Polystyrene is much more interesting still, and painting it to close the surface cells is exactly what I had in mind.
Indeed.However, as stated a couple times already in this thread, intuition doesn't work in this field!
It's highly carcinogenic And it won't work as a reflector if sealed in a container.Melamine is an option
This source says the risk is very low in resin form. You are not expected to eat itIt's highly carcinogenic And it won't work as a reflector if sealed in a container.
I'm not advocating the use of foams or plastics, mind you, but wouldn't it be great if the same piece of treatment would absorb the bass frequencies and reflect everything else?
I don't know the answer to that, but that is how in my 10'x10' office is set up. I am listening nearfield and also sitting close to the wall. What I found is:Seeking practical rules of thumb...
Is it still generally advised to aim for live end - dead end?
I.e. Absorption at the speaker wall end of the room and diffusion at the listener end?
