Yamaha A-S1000 measurements anywhere?
D
Deleted member 48726
Guest
Hi there
I'm searching for some THD, FR and Power measurements of the Yamaha A-S1000 but haven't had any luck finding any. Anyone who might have a link?
D
Guest
Is this not a thing? Wasn't this amplifier a popular one? And why didn't anyone test the quoted 90 w/ch in an amp weighing 22 kg. ? :)
delta76
Definitely not as popular as you might think. It is a upper mid/high end amplifier, and people probably stay with S701 or move up to S2xxx. There are way more equipment than can ever be measured.
D
Guest
Well, maybe. I am just wondering why there isn't any more serious tests of the AS series. They look almost identical in layout and specs on paper and being Yamaha, with big sales, I don't know why they haven't been more seriously tested..
delta76
You can find tests for 701 and 801, not here but reputable sites like audioholics. But i doubt that S1000 is identical to those. As always it can be arranged to send equipment to Amir to test, but it sounds like you are looking to buy.
D
Guest
The thousands series look very similar on paper.
Well, shipping from Scandinavia may be overkill and if this is the only way, I will come to terms with having no measurements.
I have an A-s1000 in the not-in-use room and the request is just because of the inherent nerd in me. And also I wonder what the heck the amps' 22 kg. is used for, if not for doing work.. ;)
