Yes – opamps swapping may make a measurable difference in a preamp
pma
Prague
With my new measuring setup as described in
I have decided to make some measurements of opamps swapping influence to a link preamp parameters. The circuit chosen is my SE to balanced converter, it has single ended input, Alps volume potentiometer and a balanced output with 51 ohm output impedance of each +OUT/-OUT output terminals.
The preamp/converter was driven from Topping D10s by a 75 cm long single-ended link cable (RG-59) and it was loaded by balanced input of E1DA Cosmos ADC with 500 ohm balanced input impedance (or 250 ohm each +IN and -IN vs. common ground).
The opamps were tested at positions IC2/IC3 (or IC102/IC103 in the second channel) and the opamps tested were OPA134 with a JFET input and LM6171 with a bipolar (BJT) input.
These two parts are quite considerably different, regarding input current noise, input bias current, output current, speed, and load drive capability.
I do not want to get much into details but let's note that the much higher input bias current of LM6171 creates voltage drop across R4 (R104) and thus there is a permanent DC voltage at the preamp output, in our case 260mV at balanced output. On the other hand, LM6171 has much better load drive capability.
Preamp schematics is as follows.
And this is how the sample looks like.
Measurements
1. Measurements of THD and THD+N (SINAD) at 1kHz at 2.54V output
We can see that with LM6171 we get both better THD and SINAD at 1kHz, though the differences are not very big
2. Next plots show THD and THD+N vs. output voltage with both opamps
3. Measurements of THD vs. frequency at 1.8V
We can see that the main measurable difference is in distortion at higher frequencies, LM6171 has lower HF distortion than OPA134.
Conclusion
Before any opamp swapping, we need to study the circuit where the opamps are placed, to study the datasheets and check if the opamps are suitable for the considered circuit. Here, LM6171 brings much lower HF distortion, but adds quite high DC output offset due to its high input bias current.
pma
pma
Prague
Or swapping may cause ringing or even oscillation! You need to have a high frequency O-scope and know how to use it before you start swapping.
I have it, 3 different oscilloscopes :).
Gregss
Hello,
I have used the LM6171 op amps in projects over several years. Only once had a problem and it was easy to fix. Seems this is a pretty high speed amp and it can oscillate fairly easily. Putting a COG capacitor directly soldered across the top of the chip with the leads as short as possible, decoupled the power supply and eliminated any trace of the oscillation.
Personally like the results of using this amp. FWIW.
Regards,
Greg
Reactions: pma
solderdude
The Neitherlands
A measurable difference may not not result in an audible difference, which is the usual claim made by opamp swappers and most reported differences seem to be in areas where there is no direct measurement for.
And yes, all opamps do measure differently. As output stages in headphone amps substantial differences can occur (A symmetric) current limiting and increased distortion etc.
-90dB at 15kHz, for instance as there will never be a 0dB stimulus at that frequency in practice and is not something I would ever worry about.
Also 250/500 ohm loads are unrealistically low for something that drives a power amp or pre-amp.
Does 0.0003% or 0.00015% at 1kHz make an audible difference ?
Of course, inside a power amp we don't really know what the actual load is to an opamp in a circuit. Could be anything even largely capacitive.
Power rail decoupling, feedback resistance values, Miller capacitances, load decoupling, load current, gain, offset, input reference resistance, mimimal gain all play a role in proper operation of an opamp.
In many cases there are no real problems but sometimes swapping opamps can give all sorts of problems.
But yes opamps DO make measurable differences even when correctly applied. I don't think anyone thinks otherwise.
pma
pma
Prague
However, it has not been my claim (that audible difference). One can see that opamp swapping may make the same measurable difference as is seen between 2 different DACs and I do not think that anybody has suggested that DAC measurements would be pointless. It is the same case, just another components. I am sure that average reader is not aware of the fact that changing opamps may bring same difference in distortion as changing DACs. It is just the topic that is not discussed so often here.
DVDdoug
Then, why waste time & money?
I could build a preamp that goes into the MHz range and it's no better (for audio) than one that just covers the audio range. And with flat frequency response in the audio range, once noise & distortion are inaudible there can be no improvement in sound quality.
Gorgonzola
Southern Ontario
People here at ASR will certainly scoff at subjective impressions, nevertheless I'll report on my trial of several different op amps in the VTV buffer of my VTV Purifi Stereo amplifier. I auditioned:
  1. Sparkos (discrete) SS3602
  2. OPA1612
  3. OPA627
  4. Burson (discrete) V6 Vivid
It seem to me that there were subtle differences in sound. FWIW I preferred the Sparkos SS3602. Again FWIW, this is the harmonic spectrum self-reported by Sparkos ...
solderdude
The Neitherlands
Blind tested with 2 amps and the only difference being the usage of different opamps or a switch of opamps and subjective evaluation knowing what opamp is in there ?
Measurements of both situations (or rather all 4 mentioned) with at least the quality of measurements PMA did.
Measurements of the entire amp incl. dummy load ?
Posting a plot made by a vendor in not similar conditions isn't real proof.
I am sure all 4 opamps are excellent. I am sure all measure differently and have stronger and weaker points.
I know... but the test fuels the ones claiming audible differences where the differences are far below any audible thresholds (as is the case with most DACs that have high SINAD and proper reconstruction filters, low noise and proper behavior.
No measurements are pointless as long as they are done correctly and the data is interpreted correctly. Even when measurements are beyond audible limits they are still worthwhile otherwise we do not know the technical performance.
That can be the case if parts around that opamp are capable of higher technical performance. When they are not its pointless. Just as pointless as changing an opamp in a totally flawed DAC design (think jitter/noise/poor design) is not going to make it a better DAC.
It also can be the other way around. One can make performance worse by changing an opamp. That may well even be audible and preferred while technical performance is worse.
Safe to say changing opamps changes performance of the device it is used in. Can be for better or for worse or of no consequence. Could be audible or not (tested blind) or even no audible in reality but as the late Peter W Belt's wife said:
It does not make technical changes but alters the perception of the listener.
MaxwellsEq
I would expect swapping op-amps to result in a measurable difference in almost any circuit that has an appreciable frequency response. Manufacturer's data sheets confirm that different op-amps perform differently.
restorer-john
Exactly. The total for each leg as laid out above is 300R (51R+250R).
The OPA-134 has a 600R drive rating and the LM6171 has a specified 100R rating. So I would expect the THD to rise for the 134, as it does, when it is driven at half its rated load.
The preamp would be driving a power amplifier with an input impedance of many k ohms in a typical scenario.
pma
pma
Prague
You are certainly right John, but many opamps do not raise distortion as long as they work inside their rated current output. Like LME49720 in my Topping D10s output buffer, which has rated output current up to +/-23mA, though OPA134 has higher rated output current up to +/-35mA. Interesting, right? It is the output stage design and loopgain plot that do define distortion at higher current. In my setup, the output current was a mere +/-7.2mA per one opamp, so nothing is exceeded.
So this is how LME49720 works when loaded by 250 ohm (+ 20ohm output resistor), at +/-9.96mA output current. Please take into account that voltage is measured across the load resistor (behind the board series resistor), not at the opamp output.
Please also take into account that LME49720 has also "only" 600 ohm drive rating. This is for the swing reason, 10Vrms output into 600 ohm makes +/-23.5mA.
You may see that it is the general design of the opamp circuit that makes the difference. BTW, LME49720 is nowhere specified to work with 250 ohm load, however it is the output current that makes the limit, you just get lower output voltage swing. We did not need a high swing here.
Another interesting point, nowhere in the LM6171 datasheet one can see what is the distortion at audio frequencies, they just show THD+N plots from 10kHz up to 15MHz, and the part below 300kHz is of course buried in noise, due to very high measurement BW.
pma
pma
Prague
I cannot see definition of measurement conditions - the load impedance. As such, the plots at the Sparkos site have mainly marketing importance. The measurement conditions must be carefully described, otherwise the plots are pointless.
restorer-john
Yes, I noticed the lack of distortion ratings.
I'd like to see the classic NE-5532/4AN if you get a chance.
Are you running the the Cosmos and the Topping simultaneously with one as an recording and the other as a playback device?
Mnyb
Sweden, Västerås
Yes if one is as competent as pma , go ahead choose the proper op for the application after careful study of the circuit. and do this.
This is usually not the typical context this is done in :) i would say this is very atypical .
It is right to to point out that is analog circuits after the DAC chips in most products and these to have an effect on the total results, in bad cases more effect than the DAC chip in for example AVR's
Laypersons should not be suckered into any component swapping schemes at all .
Example I'm a bit skeptical to class-D amp sales sites where one can pick the kind of bufferstage one wants ? That's a service i expect the amp designer to do for me and i expect it to perform transparently etc and i expect them to competently choose one design.
When i buy a car no one ask which compression ratio I'm interested in or ratios between the gears ?
eliash
Bavaria, near lake Ammersee
Measurements
Conclusion
Interesting, did a similar exchange in my T+A P1260R preamp, where they installed a crude video amp as output stage. This one had so much distortion (at low levels, poor open loop gain as well), I was convinced to perceive it on an absolute level. Anyway T+A had already spend some OPA211 in the first gain stage, so I installed OPA211 as well in the output stage. Being aware of the input current and 10MOhms bias resistor, I reactivated the abandoned layout traces for a DC control loop (reutilising one OPA2134 from the as well upgraded XLR output board). Dimensioning had become very slow, because of the 10M bias resistor and the coupling cap pole to maintain stability and unwanted noise suppression. Takes some 40s until the last 100uV DC-offset are gone on one of the OPA211 outputs, stabilising at around 3-4V control loop output voltage (output of one OPA2134 half). Btw. distorted impression gone...yeah I know, no measurements made...
before/original, w AD825 (~76dB openloop gain only), left piggyback boards, non populated DC/offset control loop traces below
afterwards/modified w OPA211 signal (~120dB open loop gain; left piggyback boards; pls. note brown 22pF input cap needed for stability below) , OPA2134 (dual OPA134) DC/offset control loops (left bottom)
Geert
Given the results of the measurements and the feedback about load, maybe change the tread title to "No, opamp swapping makes no audible difference in a preamp"? That they can measure differently is no surprise.
pma
pma
Prague
No, because in such case we could give the same attribute to almost any low level component test like preamps and DACs and would say there are no audible differences. But, such statement would need to be supported by facts and evidence of such statement, like statistically demonstrable results of controlled DBT listening tests - do we have it? This is the difference from my thread title, which is supported by indisputable facts. And, the opamps under test are not operated out of specs. There is no parameter like "lowest allowed minimum load" in the datasheets, there is a parameter of maximum output current, and I was at about of 1/3 of this parameter.
Geert
The evidence you provided via your measurements actually supports the statement. I think it's generally accepted at ASR that the distortion and noise numbers you came up with are below hearing thresholds, making different components audible 'transparent' as we call it. You might think some numbers are on the edge, but that doesn't warrant a title that looks like click bait to me. But you do as you please of course.
Not out of spec's, but out of common use cases. Interesting to engineers, but not to the end user.
Gorgonzola
Southern Ontario
No, because in such case we could give the same attribute to almost any low level component test like preamps and DACs and would say there are no audible differences. But, such statement would need to be supported by facts and evidence of such statement, like statistically demonstrable results of controlled DBT listening tests - do we have it? ...
Nevertheless I'm glad I can listen and choose what I prefer. Granted I won't get any 'Likes' for saying so.
The thing about real science is that it isn't deaf to what human beings report. ABX and hearing threshold tests aren't telling the whole story because they don't reflect the often very consistent subjective listening results from people who listen rather that just read papers and measure.
And part of the problem too is that so many of those on the high-horse of "science" aren't scientists but merely engineers.
Kudos by the way to Amir for more consistently reporting his subjective impressions at least of speakers.
