Yet another A/B test of DACs
julian_hughes
When I did it, it was to compare various DAPs & phones so it was easy to use line out to PC's line in & adjust the level on each device. With DACs I guess you need to either adjust their digital output in alsamixer or similar, or run them through an amp or preamp and note the exact settings for each to be level matched. I think you could get very accurate matching. I think my limitation was that some phones and DAPs had rather coarse level adjustment.
raif71
raif71
^^^Yes, it can serve as an example to other people, how to do it, how to start.
...So you could provide information about the comparator, like where to get it and how much. ...It needs to be inexpensive. :)
I bought this locally using Malaysia's online store but I see in amazon they have the same switch here.
Count Arthur
With a test tone, would a sound meter app on a phone be good enough?
Blumlein 88
Yes this would work.
Blumlein 88
Get a cable like this one. Male on both ends. Plug it in place of your headphones. Many people have one to connect telephone to car stereos.
You can use the other end to check voltage output with a multimeter. It can be a bit fiddly, but not terribly so. Put the black lead on the sleeve or ground portion. Put the red lead on one of the other parts of the plug to check either right or left channel. If you have balanced headphone outs, then this will be different.
Find a comfortable volume for your test with one of your DACs. Without changing volume send it a test tone, 1 khz is fine, 440 hz might be better for a cheap multimeter. I'd suggest a -6 db tone. Write down the voltage. Switch to your other DAC, and sending it the same test tone, adjust volume on it to match the voltage reading with your first DAC. Get the two within 1% of each other. If you read 1.oo volts then you want something between .99 and 1.01 volts. Takes longer to read these instructions than to do it once you have done it a couple times.
Now as long as you don't change volume on either DAC you can switch back and forth with matched volumes. If you have a headphone amp you can even change volume on it as long as the DACs are putting out the same voltage/volume.
raif71
raif71
I will try this method. From what I gathered, the D10s doesn't have volume control but the smsl m400 does. So hopefully the voltage range of the m400 is more than the d10s so that I can dial down its value to match the volume of the d10s. Does that make sense?
julian_hughes
I have a D10 (not D10s) & you can definitely adjust its output level. For example here is a screenshot of alsamixer showing the level control. I assume the same control can be found in Windows or Mac audio.
raif71
raif71
I have a D10 (not D10s) & you can definitely adjust its output level. For example here is a screenshot of alsamixer showing the level control. I assume the same control can be found in Windows or Mac audio.View attachment 108436
I will be using hiby r5 and the usb volume out will be set to fixed volume
JustAnandaDourEyedDude
USA
After matching voltages while checking with a multimeter say, would it be worthwhile to switch which DAC connects to which jack and re-check that the two voltages still match? Would any contact resistance inequality at the switch or jack contacts show up in such voltage measurements, which presumably draw very little current? Or would one need to measure resistances or current draws instead? Or would any imperfections in the switch likely be so small that none of the above would be a concern, given other uncertainties such as making good contact with the MM's probes? I guess it should be easy enough to use a MM and two aux extension cords to check that the resistance of each path in the switch is negligibly small?
Blumlein 88
yes it does. Check volume with the weaker device and lower the other to match it.
Blumlein 88
I don't think Windows will let you do that with two devices. Maybe I'm thinking about it wrong. Mac probably does. If you can do it with the hardware controls in this case it is likely the better way.
Blumlein 88
You could check both if you want. If I understand rightly, he intends to feed each of the two DACs into an amp. So the headphone amp will buffer the DACs. In such a case there likely isn't a big difference. And as long as he matches at the output of the headphone amp any minor differences will have already been adjusted for.
restorer-john
The easiest and most accurate way to level match without test gear is the null method. You also can accurately null at medium to high frequencies which you cannot do with a cheap DMM.
Feed the left output only from each D/A into the left and right channels of a normal (not BTL) stereo amplifier. Connect to the L/R hot (+) speaker terminals only with a single speaker.
Play the same source at the same time on each D/A and trim the output level on one to produce a null (no sound).
This will work as long as your amplifier is decent (matched channel gain), there are not huge differences in latency between the two D/As and they both preserve absolute polarity.
