(yet another guy...) looking for a DAC under $300
theotherme
Hi folks, new here, first post…
I am looking for a DAC under $300. I have done my research around here but some of the DACs that seem to be highly praised have features I don’t need or care about so I’s rather spend my full budget in what I will be using and not pay for features I don’t need. This is the setup I have in mind:
To be bought:
SDD with FLAC files, 44.1 / 16 mostly ->
Raspberry Pi 4 + HiFiberry Digipro via Toslink ->
DAC via RCA ->
Already have:
Rotel 1062 Integrated Amplifier ->
B&W 603 S3 Speakers
My system is in a custom built dedicated listening room. I am very happy with it. I also have a Rotel 1072 CD player. The DAC I am looking for should sound at least as good as the CD player
Don’t need / Don’t care about:
Balanced outputs
Headphone amp
Remote control
Volume control
Do care about:
Sound quality
Reliability: I live in Argentina. I will buy the DAC in the US and pick it up in an upcoming trip so it is very important that I plug it in when I get back home and works: it wouldn’t be possible for me to send it back for repair or replacement
Availability: needs to be easy to buy online in the US
USB: preferably yes although I have no plans to use it at least in the initial set up I have in mind
Thanks a lot!
raistlin65
Grand Rapids, MI
Topping E30, Schiit Modi 3+, and Monoprice Liquid Spark all have USB and optical input and are less than $150.
All have been independently measured here at ASR. They are so accurate that they are easily arguable to be noise and distortion-free within the range of human hearing. So you won't get higher fidelity sound reproduction unless you upgrade your ears.
T
theotherme
Thanks
Lupin
Maybe we should have a sticky.
Best DAC under/around $100.
Best DAC under/around $200.
And so on.
Updated every time there’s a new review.
And what defines "best"?
SINAD score?
Feature set?
Form factor?
Price to SINAD ratio score?
Whatever else you can think of?
All these points have a different level of importance to people so there is not simply one "best" IMHO
SINAD score is not interesting as with current technology in 2021 even a $100 can be by all means audibly transparent.
Yorkshire Mouth
God's County - Yorkshire
I think there are several DACs (and headphone amps) whose measurements mean they're 'effectively transparent' (I believe that's Amir's choice of phrase).
So just sticky a list of those, in price-rank order (cheapest first) with features in parentheses afterwards.
Example:
Topping E30 $129.99 (USB/Coax/optical in - RCA out - external power supply)
SMSL SU-9 $439.99 (USB/Coax/optical in - balanced out - internal power supply)
Etc.
Link to the review on the item.
It's just an idea.
The current database table is very welcome, but boy is it slow & clunky.
Stephen
I've been using two Soncoz LA-QXD1 for some time now and I am happy with them.
aandres_gm
Germany
Comprá el más barato, hermano. Topping E30, Schiit Modi 3+. Si solo vas a usar la salida RCA, no necesitas gastar más de $150.
T
theotherme
Thank you all for the advice. I have another question. My Rotel 1072 CD player has a Burr Brown PCM1732 DAC inside. I am guessing the chip must be 20 years old or so. Datasheet here if someone is interested https://datasheetspdf.com/pdf-file/37269/Burr-BrownCorporation/PCM1732/1
Is it reasonable to expect same or better sound quality from either the Modi 3+ or the Topping E30 and my CD player or are we talking about different leagues here? Assuming everything else stays the same, of course.
Thanks again
eddantes
Do you really think you will be able to hear the difference?
Buy a known well performing DAC (two listed above are good examples) and revel in the "phsychoacoustic satisfaction" of "knowing" it's good, even if you can't "detect" if it's better.
T
theotherme
Well, If I can't tell the difference, great, that's what I am looking for. I ask because I also have this DAC hooked up https://www.amazon.com/Orei-DA21X-P...00F4ORTZ6/ref=cm_cr_arp_d_product_top?ie=UTF8 (Orei DA21x DAC $17) and there is a very noticeable SQ difference. I'd be very unhappy if the new ones sounds like it. Cheers
Ron Texas
Check the reviews. Look at the Topping D30. It's an oldie and it's simple. No distracting display. Mechanical on/off and input switches, about $100.
FrantzM
No lo pienses demasiado.
Escuche lo que dijo esta persona!
billdylan
Thanks again
There are some problems surfacing about the CS chip that has recently replaced the AK used in the Topping E30...My advice ...stay clear..
Joe Smith
I think the Liquid Spark DAC is no longer available...probably a chip issue. I was kind of interested in that one. Still happy for now with my Modi 3 from Schiit, don't really need higher than 24/192 for the time being. It's very simple to use, robust and sounds good. The 3+ adds the different USB processing but that wasn't enough of a reason for me to upgrade....
enricoclaudio
Houston, TX - USA
