Yulong Aquila II DAC and Headphone Amp Review
This is a review and detailed measurements of the Yulong Aquila II USB DAC and headphone amplifier. It was kindly purchased by a member and drop shipped to me for testing. It costs US $640.
The Auila II breaks the mold of rectangular boxes for desktop DACs with compound angles:
The volume control also navigates the menus by first pushing it in multiple times until you land on the on screen item to modify and then turning the dial. The display is IPS and has very fine resolution which I appreciated.
The back panel has the usual connectivity:
Best USB DAC Balanced with Headphone Amp Back Panel Inputs XLR RCA Review.jpg
The unit was plug and play with Windows over USB connection. Operationally it ran somewhat warm but no worse than other high performance DAC and amps.
Balanced DAC Audio Measurements
For the DAC portion I focused on performance of the XLR output only. Here is our dashboard:
Two years ago I would jump with joy at such low distortion and noise rating as reflected by the SINAD. But today, SINAD of 111 dB is not very competitive:
Noise by itself seems to be a bit of an issue:
YULONG Aquila II USB DAC headphone amplifier Dynamic Range Audio Measurements.png
This reflects just the same in IMD distortion versus level:
The DX3 Pro (dashed blue) is one third the price so having more noise than it is not very good.
There is some jitter that is caused by power supply noise:
Not remotely an audible issue though.
An option people wondering about has been the ASRC mode being on and off. This is exposed in Auila but as you see, it made no difference with USB as the source.
Linearity was very good:
There are only three filters exposed:
YULONG Aquila II USB DAC headphone amplifier Linearity Audio Measurements.png
I used the sharp one for the following test:
YULONG Aquila II USB DAC headphone amplifier THD+N vs Frequency Audio Measurements.png
Company measurements are a few dBs better than what I am getting (0.0002% versus 0.0006%). I don't know what explains the discrepancy.
Finally here is our multitone:
YULONG Aquila II USB DAC headphone amplifier Multitone Audio Measurements.png
Headphone Amplifier Measurements
Good bit of power is provided especially in balanced mode:
YULONG Aquila II USB DAC headphone amplifier Power into 300 ohm Audio Measurements.png
Alas, once again noise is higher than it should be. The volume control is analog though (but digitally controlled) so perhaps at lower settings it would show less noise.
Here is unbalanced performance into 33 ohm:
YULONG Aquila II USB DAC headphone amplifier Power into 33 ohm Audio Measurements.png
I did not have time to listen to it but I suspect it will sound good given the ample amount of power as long as you don't use an overly sensitive headphone/IEM.
Expectations is everything and at this price, I expect "instrument grade" measurement results and sadly we don't get it. Subjectively it will sound fine with its powerful headphone amp. So if you like its looks, it would make an OK purchase. It doesn't meet the bar for me though from engineering point of view so I can't recommend it.
Have to help my wife can more tomatoes but took a break to do this review. Shows you how much I value the money you all put in my pocket! So donate what you can using: https://www.audiosciencereview.com/forum/index.php?threads/how-to-support-audio-science-review.8150/
Martin
Cape Coral, FL
Thanks! That's somewhat of a disappointment. I like the looks but I listen with my ears, not my eyes. It doesn't have the ESS hump but then the intermodulation distortion is above that of the Topping DX7 Pro. Looks like it has less than half the power of the DX7 Pro, too. Unfortunate.
Martin
Veri
To be fair, it performs near the same as the previously measured Yulong DA10 (which received a lying-down pink panther). Aquila 2 is $640 while DA10 was $1000+. Imo, the mains noise when using XLR out is kinda problematic... and for an all-in-one the headphone outputs are also a little elevated in noise. So while quite good, not stellar.
PeteL
Their logo doesn't look like anything that looks like Yulong, what is Da Art?
restorer-john
Bandwidth maybe. Yours is 90KHz, theirs could be much lower and/or using a filter with artifacts at HF above the 30KHz on your plots.
PeteL
We are getting spoiled, having difficulties seing this as an unrecommended product. It's got a Sinad in the first tier, It looks good, It's a dac, a fairly powerful head amp and a preamp with balanced out AND AES/EBU in.("The back panel has the usual connectivity") is it THAT usual to get those features for this price?
Martin
Cape Coral, FL
If anyone wants it I’ll sell it for the $640 I have in it. I’ll throw in free shipping and eat the PayPal fees.
Martin
Matias
São Paulo, Brazil
Measures pretty good, it's just that the bar is set too high now.
Jimbob54
Im not sure if being a sound purchase is the same as a recommendation. I think Martin nailed it. Its not the DX7 pro. Is the Yulong a (relatively) new product? If it is significantly younger than the Topping then its something of a weak sister and shouldnt be the $600 DAC/amp recommendation
pozz
Слава Україні
Editor
Jimbob54
19 "dB" of dynamic range certainly "isn't very competitive" :)
He's a better technician than a typist, for sure. Lets just all blink whilst he changes it to 19 "bits" .
PeteL
input jitter shouldn't be an issue with USB. If anything this ARSC thing sould be tested with SPDIF/AES
Martin
Cape Coral, FL
I dunno...it measures pretty darned well. It's just...fugly.
I like it. Then again I like my Loxjie P20:
And yes, I know it’s an effects box. I like the way it looks but its sound is wearing on me.
Martin
