z390 xtreme audio
poublu
i want to buy the hd800 s and i want to have good audio and to let them have the best soundstage possible i was looking to buy an amp dac and i liked the rnhp but i couldnt find a dac
i dont know if i plug the amp to my mobo be okay (the mobo has a dac but it has an amp tooand i dont know if it is a problem) and my ocd is going crazy
so because i really cant take this hahahah
is my mobo the z390 xtreme (this is a link if you want to see the sound specs just scroll down https://www.gigabyte.com/Motherboard/Z390-AORUS-XTREME-rev-10#kf )
good to drive the hd 800 s good and have a good soundstage and if not could someone suggest a good dac (dac only not with an amp) to go with the rnhp
sorry for my grammar i have dislexia and its kinda hard for me
thanks for reading
peder2tm
I don't think you need a dac. Your mobo has a sabre dac and there is also an amp included.
I also have an aourus motherboard but only with Realtek dac, but it measures quite well and I think the amp is pretty good as well. Enough to drive my hd650 to very loud levels. Wait until you get the headphones and if you then think you need an amp get the jds labs atom.
Veri
Entirely agree. Either use mobo, or amp it with jds atom if necessary. It should suffice :)
P
poublu
wont the mobos amp aplify the sound if i add an external amp and if it does wont that afect the sound
using mobo dac<mobos amp<external amp< hd 800s
Roen
See if your mobo can get your HD800S loud enough. If so, then you don't need an amp.
