A VU Meter Amp/Speaker Selector Released by Fosi Audio
Fosi Audio
In response to an audiophile fan's request, Fosi Audio created a VU meter amplifier/speaker switcher-LC30, and now brought it to everyone. It's now available on mainstream shopping platforms. See the link https://fosiaudio.com/pages/amplifier-speaker-selector-lc30
Members from ASR can enjoy a 10% discount by redeeming this promo code: FALC3010
Fosi Audio will keep co-creating new HiFi gear with audiophiles, which makes them become of unmatched value. Do believe another amazing stuff is coming soon this month!;)
Doodski
If I may say so. :D It's dang beautiful and love the soft warm orange'ishy glow of the backlighting. Great stuff @ Fosi.
GXAlan
That looks really nice. Is there a specific position of the knob that is *calibrated* for 4 or 8 ohm loads like McIntosh does?
Edit: and what is the maximum current that can pass through the unit since the VU meters peak at 250W?
Doodski
Wowowow. $199.00 Canadian dollars at Amazon.ca
Mikig
Italia
well done Fosi!! It looks really nice, I looked at the page on your site and it seems like a really good component!!
DannyBoyNYC
No images of the back panel as far as I can see. Curious about the amplifier switching.
Mikig
Italia
anyway: congratulations to Fosi.
Very concrete production, beautiful stylistic signature, the family feeling with the "orange" that has become recognizable among the thousands of devices on sale today.
Search the catalog of the most modern electronics and use high-end components.
All at an always attractive price.
Well done, in such a complicated world, that of audio, made up of "noble" names and almost stainless traditions, which have resisted on the market for years, it was not a given to achieve these results.
Well done again!
EJ3
James Island, SC
Yes true. The newer class D amps are very powerful for sure and will exceed this models capability. Thanks for pointing that out.
As do some Class G amplifiers:
NAD 2200 Vintage Amplifier Review​
NAD 2200 stereo power amplifier power into 4 ohm Peak and Max audio measurements.png
Some times we run bridged mono or 2 ohm circuits, basically very close to doubling the watts.
Wow, we have one kilowatt of power coming out of this amp in short duration!
JeyElDee
As I posted on the other thread :
Bought one Fosi LC30 switch with VU-meters from Audiophonics. Seems to work fine but there are some reasons you might not want it.
When turned off, it automatically goes to input amp B and output speakers 2. You can keep using it when turned off that way but only in this configuration.
It does however remember the last inputs/outputs when turning it on. (you don't need power to use input B output 2, for all other configurations you need to power it on)
The VU meters are not buffered! Even turned off, VU meters keep on moving. One would think this is fine, but this means it does interfere in the signal path. It probably does not have a big impact but it might induce some distortion.
On the positive side, the remote did not interfere with my Topping D70s DAC.
The sensitivity of the meters actually is 250-300 watt-ish. That means you won't see much movement in normal use, unless you play loud or need a lot of power.
The sensitivigy-knob should be at max to give a more or less correct reading. Any lower setting and you won't see any reading at all. So the sensitivity knob is rather pointless.
Binding posts are ok but the holes are vertically. Diagonal would have been more easy.
So if you need a speaker/amp switch that can handle high power, it seems usable, but I would not use it in a critical listening environment.
If you want dancing VU-meters without using more than 25 watts, forget it.
Suggestions for improving would include a buffered stage that powers the meters, so any possible distortion (if any) caused by the components would be limited to a minimum and give the possibility for a better match with lower power setups by adding a "sensitivity switch" that eg can swap between the 250 Watt and eg a 25 Watt-scale. The extra cost would certainly be acceptable for such an improvement.
