Awesome! Out of curiosity, are there circumstances where you prefer just keeping the SP off and listening traditionally? Or is the SP engaged all the time now?
So far I have only found one track where the other mage was a bit too big. There is an interesting adaptation process. At first it’s just utter amazement. Then a brief period of wondering if it will grow old and feel like a gimmick. Then comes acclimation. Once acclimated conventional stereo becomes difficult to listen to. It sounds very wrong on a number of parameters. Not just the very poor imaging. The BACCH eliminates a couple sources of listener fatigue. At this point IMO any assault on the state of the art in two channel audio requires a BACCH SP.Awesome! Out of curiosity, are there circumstances where you prefer just keeping the SP off and listening traditionally? Or is the SP engaged all the time now?
If you can ever upgrade to the head tracking version it makes a big differenceI agree. I only have the "poverty" u-BACCH VST for Windows, and it has been a game changer. It is the 4th most important intervention I have made to my system, behind room, speakers, and Acourate.
$6K including the Mac MiniWhat’s the entry cost for the head tracking version?
I already have a Mac Mini through.$6K including the Mac Mini
Then it’s $5kI already have a Mac Mini through.
Since I rotated my Genelec Ones/ W371a arrangement in my listening room, the measurements are a bit worse (but the room is much nicer). But BACCH is back to delivering an obvious improvement again. You should give it a go!What’s the entry cost for the head tracking version?
That’s interesting. What were the old and new measurements? What changes did you make in the room?Since I rotated my Genelec Ones/ W371a arrangement in my listening room, the measurements are a bit worse (but the room is much nicer). But BACCH is back to delivering an obvious improvement again. You should give it a go!
And BACCH room correction filter with head tracking is on its way. So things will only get betterOriginally, speakers either side of piano with sofa about 1m away from bay window (rear). This obstructed the door. Now speakers on prev side wall, with piano rt side wall, bay window left and sofa up against opposing wall. So less symmetry and sofa not ideally placed. Measurements from BACCH similar to previously but GLM definitely worse for rt side than before (rt is 1st image). Prev, both left and right were flat.View attachment 329197View attachment 329198
Does crosstalk cancellation work only at the listening point or also over a large area?
The sweet spot is for one listener only but you can have one or two sitting behind or infront of the listener. In any event, the sweet spot is more stable where you can nod, turn and even lean about few inches to the sides and the image remain stable compared to conventional stereo.You then get a very narrow sweet spot.
The is no crosstalk between microphones. The crosstalk XTC deals with is “interaural crosstalk”, i.e., sound from the left and right loudspeakers being heard by the opposite ear.There is only the original "crosstalk" between the microphones/ recording techniques
You can do it for free which is more precise. there are also other options some free and some was sold for as little as $10.If it hits my budget zone I will buy and try!
Comparing this and a typical approach to correcting a speaker is a little apples-and-oranges. If it's using head tracking and custom HRTFs then I think it's plausible the high frequency performance is good. And I don't think we need measurements to accept that this would make a big impact on the sound. Crosstalk cancellation would inherently be a pretty drastic change to the sound, whether or not it worked.I believe, like Toole, that correction cannot fix speaker issues. Correction is best limited to below Schroeder to fix room issues.
If physics apply, BACCH‘s crosstalk removal for speakers must become less effective as the frequency increases and wavelengths shorten.
What in Toole/Harman conventional wisdom has been thrown out the window?
- Confirmation bias
- The importance of Measurements
- Blind testing
- Rich
Hi Paul,Two stereo microphones do not exactly function the same as a person's ears do in a live music setting. That's why I used "crosstalk" in parentheses.
