Constant Beamwidth Transducer (CBT) Speakers
sarumbear
Seems fully buzzword compliant! :D
Also it seems it is not yet utilised in a live environment other than demos. Interesting use of array technology.
abdo123
Brussels, Belgium
For a line array, the result is a cylinder. It takes a square array to do a point source.
Are square arrays used in Hi-Fi applications? Feel free to share designs that you're aware off.
Directivity control is an elusive goal for most people here.
Bjorn
Norway
Some weeks ago the CBT36s got a new owner. I set up the speakers at a friend's apartment. We used the miniDSP Flex as a DSP and 4-channel amplification with Hypex UcD modules.
Tried different placements first with measurements. The speakers generally don't change much above Schroeder and also quite little above 150 Hz because it avoids the floor bounce. But obviously the lower frequencies will vary with placement.
Ended up having the speakers fairly close to the TV. The right speaker was moved further to the left than what the picture below shows.
The speakers were intially set up with a flat response. After placement was found, we added some shelving to get a response falling towards the treble.
The response on each speaker with 1/12 oct. smoothing was like the following.
I need to investigate later what's happening between 600 Hz and 1 KHz (the dip). It may be the table with all the stuff on it that's causing it. But overall, this is a very good frequency response in such a small room with no acoustical treatment. That's the result of a good speaker design that has a very uniform directivity, avoids floor reflections and minimizes ceiling reflections.
Next step now is to do some acoustical treatment. An absorber will be placed in the ceiling between the speakers and listening postion and one absorber on side wall will be added. After that, some more tuning with DSP and add some presets the owner can change between. Later, a subwoofer will be added.
Anyway, thought this could be of interest of some. While the CBT36s aren't without flaws, it's truly a remarkable speaker IMO.
Newman
Great report @Bjorn. I doubt that an absorber is needed on the ceiling, since the CBT has a 30-degree vertical beamwidth and one would expect ceiling reflections to only come into play at listening distances over 4m with a 2.4m ceiling, or 5m with a 3m ceiling.
cheers
Bjorn
Norway
cheers
Thanks. A ceiling absorber will improve further. There's still flutter echo going between the floor and ceiling with the CBT. Plus, the absorber will work low enough in frequency to shorten the decay and tighten up the lower midrange and bass. Very audible!
Rick Sykora
Rick Sykora
Stow, Ohio USA
Some weeks ago the CBT36s got a new owner. I set up the speakers at a friend's apartment. We used the miniDSP Flex as a DSP and 4-channel amplification with Hypex UcD modules....
...Anyway, thought this could be of interest of some. While the CBT36s aren't without flaws, it's truly a remarkable speaker IMO.
So, which speakers are replacing the CBT36s?
HarmonicTHD
Question: How does it avoid floor bounce ? Could you explain please?
Bjorn
Norway
Ah thanks. So they make use of the inevitable. Interesting. Does it work consistently as not all floor bounces are equal? Or should one avoid carpets etc ?
I believe it works up till the frequency where the drivers sum and don't create comb filtering. So basically up 10-16 kHz area, depending on driver size that's being used. The lows will be dominated by the room and room modes.
A thin carpet will not effect this and could be used. However, a carpet is a very bandlimited treatment.
HarmonicTHD
Thanks. Carpet was just an example of the differing floor types. But I get it. And sure it is irrelevant below the Schroeder frequency.
Bjorn
Norway
Was something like this ever measured anechoically? (Or with Klippel?). How do you adjust for the combfilter effects between the drivers?
Th removal of lobing and comb filtering is basically what the CBT technology is about. And why it's not like a tradional line array. If you're not familiar with the technology you can read AES papers or some are also shared in the videos below. In short, it's done with a combination of a shading system and the curving. It works up to about 1/4 wavelength spacing between the tweeters. Meaning comb filtering will kick in high in frequency at some point, but primarily in near field and it probably isn't audible when small drivers with close spacing is used.
The prototype you saw was only measured in near field, which is very close to anechoic down to a certain frequency.
Rick Sykora
Rick Sykora
Stow, Ohio USA
See the first post in this thread for CBT research and measurements.
sarumbear
j_j
Audio Luminary
My kitchen or my listening room.
cheers
If you put the array directly adjacent to the ceiling, you can almost double the length of the array via the ceiling images, if you're pointing the array straight ahead along the ceiling.
laetoli37
I have many speakers since I'm into designing them. We (me and Don Keele) are also working on a new CBT speaker.
Are you guys also looking at low profile center speaker for acoustics transparent application? Something straight instead of curved like the JBL Pro series.
