Crossover MKP Capacitors
Birdy
Brazil
I use two different 33 uF MKP capacitors in series to make 16.5 uF. One is a DIYaudio Silver cap and the other an old Solen Chataeu Rough(?) Does using them in series have negative consequences? Would it make an audible difference to use just one MKP capacitor? The sound is good and does this compensate for the high purchase costs of a new one? any help is welcome...
SIY
Alfred, NY
No and highly unlikely, respectively. Now go enjoy your speakers. :)
egellings
You could possibly have a pinch more ESR (Equivalent Series Resistance) with two caps in series, but I think the effect of that would be microscopic. I highly doubt you'd hear a difference due to that slight (a few milli-ohms) increase.
Birdy
Birdy
Brazil
Yes, I've thought about it, in practice the higher resistance might reduce the output of my dome midrange a bit. This could have even helped balance the output between the drivers. I don't know how the (small) quality differences between the two MKP capacitors work out. Thanks!
egellings
Playback volume level differences will be microscopic as well with such a tiny addition of ESR.
