do linux or mac play music better than windows?
Mantra
Roma
Hi
Maybe it's a silly question , but sometime i use a mac with audirvana and seems for my ears it does play songs better than windows
I was reading a topic about linux vs windows what hi fi forum and seems there are several users that do report that linux or macos can play music better than windows
I used wasapi exclusive foobar2000 or musicbee under windows and on my external dac even asio , and the only program i know under macos is audirvana
I guess bit perfect it's bit perfect but maybe these operation system or player softwares could Eq under the hood and let play more tasty
are there some tests about it?
and what do you think ? Have you some feedbacks?
thanks
antcollinet
UK/Cheshire
They're all capable of bit perfect playback, or being set up to mess it up.
They are.
But ultimately if up/down conversions, or sample rate conversions, or volume control (and so on) are all implemented correctly, they're inaudibly imperfect. So even when not bit perfect, any one should be audibly identical to the other.
Subject of course - as you say - to not being messed up.
Mantra
Mantra
Roma
They are.
Hi
may i know what does it mean for mess it up?
windows 10 wasapi exclusive musicbee or foobar2k , what should i do more? windows speakers settings "Disable all enhancements" -> are these settings (screenshots) correct?
or is enough wasapi exclusive ?
is there a tutorial?
thanks
The safest is Windows via ASIO.
hi
but I use my laptop with the build in card and there is no asio driver for it
thanks
Shadrach
I've used Linux for 20 years or more. Every now and then I set up a windows machine for audio playback for one of my less computer savvy friends.
Both are equally capable of quality playback.
Both have a decent selection of music players.
Both are capable of bypassing the audio management stack which is often where problems lie.
The advantage of Linux is there are distributions that will run well on low powered machines and not take up much room on a drive. I found it easier to get linux to concentrate on the task at hand, audio playback, rather than wanting to run off on the internet to play with it's mates and tell the world about your business.:rolleyes:
Use what you are most comfortable with. Foobar for windows is still an excellent music player option, especially given it's free.
Mantra
Mantra
Roma
Hi
but is there a tutorial with screenshot to setup correctly windows ?
thanks
Shadrach
I'm sure there are a few if you search the internet for windows bit perfect playback for whatever windows OS you have.
I think Asio4All is still available.
StigErik
Norway
Asio4all is not going to solve anything, as its just a wrapper around the existing WDM drivers.
Berwhale
There's a thread about that...
ZolaIII
And most backward compatible regarding DAW's and VTS. OSX comes second and lot of work is being done on Linux to get there regarding VTS but still wouldn't really rely on it yet. In short JRiver WDM on Windows.
somebodyelse
Some examples:
* inappropriate resampling method - either setting a low quality one when plenty of processing power is available, or a high quality one that the hardware can't keep up with (only likely on very slow systems by current standards)
* bad gain staging, causing clipping somewhere in the signal path
* application doing something unexpected
* resampling or changing volume when bit-perfect playback is required (MQA, DoP, surround formats over spdif/toslink etc.)
Mantra
Mantra
Roma
Hi
thanks for the link ,but i guess a webpage with somescreenshots would be better , i have found a german webpage but i don't understand german
Hi
May I know if you use JRiver media player as music player and JRiver WDM is included in the installation?
and can i know what vst do you use? Foobar2k ,Musicbee and Aimp can use them
thanks
SSS
Germany
Hi
Hi
thanks
Hi,
I use Windows 10 Pro on my old Laptop with Audirvana player software. Connected an external DAC via USB. Audirvana support told that WASAPI is fully OK, no need for ASIO driver. There may be external DACs which provide their own ASIO driver, then this may be better. Remember that ASIO was made for bidirectional communication both recording and playback simultaneous. For music playin only this is not required. Anyway I would use an external hi quality DAC not the internal one.
wwenze
Everything is nice until DPC latency hits.
USB doesn't support DMA due to security reasons something something
ZolaIII
@Mantra you just enable WDM JRiver driver in JRiver and set it up to default Windows sound output so everything is directed trough JRiver DSP chain trough WDM driver. Which VTS you could use is more up to you and actual players/DAW capabilities. From PEQ to all pass to tube stage, other effects individual or all in one. There are VTS plugins with more effects in one and more all together than in good advanced DAW like Ozone Izotpe for example. Used lot of different one's in last 20 years and with both players and DAW's.
Vincent Kars
Cheked the calendar, yes it is 2024 indeed. Debates about difference in sound quality between OS sounds so very much 2010.
All OS do have their options to bypass the OS audio. Be is WASAPI/Exclusive, hogmode, HWx, etc.
As they all can be configured to deliver bit perfect output, they all sound the same
Audiofire
Denmark
