Fosi Audio ZA3 Amplifier Review
Rate this amplifier:
    Votes: 10 2.9%
    Votes: 54 15.7%
    Votes: 207 60.0%
    Votes: 74 21.4%
howard416
I believe with a review like that, the numbers are simply assigned arbitrarily.
If the amp works well in your use case, it's a good one for you, and if not, then it isn't.
gasolin75
Denmark
mav
I might want to use this amp to run a secondary set of monitors in my home studio. I want to control the power to my main monitors and this amp with a single power switch.
Can you (safely) control the power away from the device? And will the speakers be protected from loud bursts?
And how about the V3? I'm still undecided between both.
tinnitus
Germany
Hi MAV that will be possible, when switch also the 12Volt Trigger on. ;)
WillBrink
some considerations:
1) I think there are very few amps with balanced inputs at this price
2) the price/performance factor is scary. It would probably put it at the top of any ranking
3) I had a V3, taken for testing, and I admit that it was a really good amplifier, not at all intimidated even with quite large speakers. So this shouldn't be any less.
4) the only note: the system proposed by Fosi which makes it usable also as both a stereo and mono power amplifier, it seems fun, to experiment and play a bit, but leaves me a little perplexed: two or three potentiometers on the same line seem too many to me. I am afraid that the signal may have deteriorated in some way. I would prefer a pure power amp therefore without controls.
5) congratulations to Fosi for this line of products, which is essentially spot on for the price.
I am thinking same. $ for value should be it's own metric perhaps. What would compete with it for that $? I'm looking to do a desktop/office system, and that's perfect and $ fair. I just ordered one.
