Davide
Hi everyone,
I finally made my two DIY subwoofers operational, made in the following way:
Driver:
- Scan Speak 30W/4558T00
Box:
- Acoustic suspension design (Vas/Vb=3.1)
- 30mm MDF walls + 19mm internal bracing
- 463mm baffle width (perfectly cubic shape)
- 60 litres net internal volume (very very well sealed)
- Stuffing with Visaton Polyester Whool (approximately 105 grams)
- Resulting Vb = 67 litres
- 3 x Rubber feet (diameter 40 mm, height 10 mm)
Amplifier:
- Hypex NC502MP amplifier (external)
I sized the internal volume with the spreadsheet provided by Scan Speak.
I made it 60 liters, increasing the apparent liter to 67 with stuffing (always calculating this with the spreadsheet they provided).
See below:
The subwoofers are placed roughly in the center of a 6.7 meter wall, and 1.2 meters apart (not optimal, I know, but that's what I can do). The other side of the wall is 4.2 meters, while the height is 3.2 meters).
Now I performed some quick measurements to see the response, and this is the result, complete with modes estimated by REW.
Up to 45Hz everything is fine, further down there is this drastic drop in both subwoofers.
From the simulation I should have obtained a gentler roll off, around 12dB per octave.
I don't know if I'm dealing with a room-cancelling effect, or if there's something wrong with the design.
In theory an acoustic suspension shouldn't drop that steeply.
Furthermore, the final Fs should be right at 34Hz, where there is that big drop...
I'm thinking that the rubber feet have a dampening effect on those frequencies.
Or is my microphone faulty?
What do you tell me?
PS. no DSP was applied. This is raw response.
Driver:
Box:
Amplifier:
See below:
