HighImpactAV
- Joined
- Mar 2, 2020
- Messages
- 113
- Likes
- 232
I recently purchased some more smoke detectors and found that they emit an 85 dB signal (at 10 ft) at 3200 Hz. You can read more in The Audibility of Smoke Alarms in Residential Homes. You can use the smoke detector to set REW or Omnimic with a fair bit of accuracy. This is because smoke detectors must conform to ANSI, UL, and NFPA standards.
Open REW's SPL Meter, click "Calibrate," and select "Use an external signal." Make sure you are set to A Weighting (all weightings are actually about the same at 3200 Hz) and Slow. Hold the microphone 1 ft from the smoke detector and press the test button. The signal will go in short bursts so you need to keep an eye on the SPL meter in REW and adjust until the peaks read 105 dB (calculated using this calculator). If you are 10 ft away it will read 85 dB. Click "Finished" in REW when you are done setting the SPL Meter.
In Omnimic, click the SPL/Spectrum tab and set response weighting to "A" Curve. Set the damping to Slow. Press the test button on the smoke alarm and adjust the microphone sensitivity slider to make sure you aren't overloading the input. Hold the microphone 1 ft from the smoke detector. Go to Config > Adjust and set the microphone trim until it reads 105 dB.
