Mr. Haelscheir
- Joined
- Mar 16, 2023
- Messages
- 111
- Likes
- 86
I recently acquired a MOTU M2 to facilitate sample-synced averaged headphone measurements with my in-ear microphones (see https://www.farnell.com/datasheets/1653468.pdf and https://www.head-fi.org/threads/mez...eadphone-official-thread.959445/post-17743502 (post #5,152)).
I was originally using the Axagon ADA-17 to capture the signal from the two unbalanced microphones (3.5 mm TRS), my separately sending the sine sweeps to my FiiO K9 Pro ESS. When resting my hand on a grounded surface, the noise floor seen on REW's input monitor can get as low as -70 dBFS, the microphone being sensitive to the faintest breaths, reaching 0 dBFS for a moderate to hard blow headphone playback on the order of 105 dBA. This was when setting the input volume control to 0.25 with the Java driver, which was the default which I was previously unaware of. See below for what the signal from a few gentle to hard blows on the microphone look like:
After changing the volume control to 1.00, the noise floor with my hand on a grounded surface rises to -45 dBFS, and the same quiet breaths occupy a larger span of the dBFS scale. That volume control setting does have me concerned for the validity of my distortion measurements and EQ judgments in https://www.head-fi.org/threads/mez...eadphone-official-thread.959445/post-17743506 (post #5,153).
For connection to the MOTU M2, I used a female 3.5 mm TRS to dual 1/4" TS adapter, particularly https://www.amazon.ca/Gold-Plated-Audiowave-Female-Splitter-Shelled/dp/B07PRV735V/, my plugging the TS ends into the respective mic/line/guitar XLR/TRS combo jacks. I am noticing here that on max preamp gain (this appears to scale linearly with the noise floor plotted on REW's input monitor) and the input volume control set to 1.00 with the Java driver, while holding the microphone in one hand, placing my other on top of the MOTU M2's chassis drops the noise floor from -40 dBFS to -60 dBFS, whereby when blowing as hard as possible on the microphone such that the MOTU M2's input meter is maxed (it so happens to not be detecting clipping), this only brings the signal up to -10 dBFS. See below for an example of the limited dynamic range and the preceding drop in noise floor from contacting a grounded surface:
I am trying to understand how the MOTU M2 could seem so insensitive to these microphones compared to the consumer-grade Axagon ADA-17. The electret condenser microphones per the linked documentation have an output impedance of 2.2 kΩ, which shouldn't be an issue as the MOTU M2 for TS and TRS inputs for both line and instrument inputs automatically sets its input impedance to 1 MΩ. I was wondering if the female 3.5 mm to dual 1/4" adapter might be defective (3.5 mm socket possibly not gripping enough), but I figured that what could be plausible is that these two devices' ADCs have different reference voltages, if that is even possible. As such, the Axagon ADA-17 for the same input voltage range is reporting a much larger range in the dBFS scale than is the MOTU M2.
Thus, is there any way to adjust the MOTU M2's reference voltage or configure the input or order to attain a sensitivity comparable to the Axagon ADA-17 for these microphones? Else, if dynamic resolution is already comparable, is there a way for REW to "zoom into" the signal more than the default volume control (or when using the MOTU M2 ASIO driver where there doesn't seem to be any volume control) while having measurements at least accurately represent the relative SPL relations for distortion measurements and EQ? If I cannot obtain a comparable dynamic range useful for headphone distortion measurements, then this MOTU M2 as of yet would be of no use to me, whereby I will have to stick to singular 4M-length measurements taken with the Axagon ADA-17.
