terfenol-D
- Joined
- Nov 11, 2020
- Messages
- 34
- Likes
- 15
I am replacing my NAD C658. I was going to replace it with an Anthem STR but passed on that. Instead I am going with a preamp with no room correction and would like to add a minidsp product for integration of sub and speakers. My questions are:
- MiniDSP 2x4HD vs MiniDSP Flex. If I would like to use Dirac I pretty much have to go with the MiniDSP flex correct?
- RCA vs Balanced. I'm not really sure which way to go here. My pre has both balanced and RCA outputs. My sub only has an RCA input. My preamp outputs 16v balanced. Will that fry the Minidsp Flex which indicates it has a maximum of 4v input? Similar question on going from minidsp balanced output to RCA input on my sub?
- Can the MiniDSP flex be used in only room correction mode? IE - turn off the volume control so that volume can be controlled by the preamp I am going with? If not, would I just set the miniDSP to max volume and then hide the remote?
