Broken Wing
- Joined
- Jul 24, 2022
- Messages
- 7
- Likes
- 3
Hi all, first post I just received a Ladder Bach preamp direct from Shenzhen which sounds absolutely amazing! It really puts every instrument in it's place and opened up the sound where the textures are far more sperate. Just what I wanted, a bit of "warmth" with max detail.
My setup is miniDSP FLEX Digital I/O - external DAC - Ladder Bach - Crown XLS 1002. I've had the Bach in this setup set at max volume, 60, and control the volume with the miniDSP to retain use of PEQ and SUB control. Now I was just adjusting the preamp volume directly with no music playing and you can distinctly hear a pop/click come THROUGH the speakers, not the normal relay clicks, at only one spot on the dial between 56 and 57. I don't hear any change in the sound of the music when music is playing, but if the music is low enough you still hear the pop. Should I be worried enough to exchange it?
Side questions, in this setup is it best to set the Bach preamp to it's max volume? Or set it back a few notches? I'm not sure if there's any difference in sound or device longevity.
Thanks in advance
Thanks in advance
