Receiver NAD C 720BEE
DanielT
Sweden - Слава Україні
I took some pictures of a NAD C 720BEE I bought yesterday. It lacks a remote control, but I will get one, a remote control that is.The model of remote control is NAD SR5. It says Zone 2 on my NAD. I suspect that there are different types of NAD SR5. Am I right about that? Anyone who knows?
Anyway, It works as it should. Sounds ok. For those who are interested, the schedule/service manual is here:
I will mainly use it as a pre amp. I'm a little curious if sub out is active even in pre amp mode. I'll probably notice that later today.:)
Electrolytic capacitors in the power supply. 15000 uF, 50 V.
Edit:
However, this NAD as integrated with subwoffer, hm. With the right type of speakers, it can probably get decent Hifi from it too.:)
I can take the opportunity to ask that. Is it possible to split the sub out so can can drive two active subwoffers? The signal strength sub out then becomes ... hm ... I do not know.
In any case, it is an excellent extra amplifier / receiver. If you do not want to go "all the way" and buy a vintage 70's reciver, I recommend this. There is still "gunpowder" left in it ..:)
Personally regarding my view of Hifi and appearance. In terms of appearance, it is beaten by many vintage amp / receiver. But being a NAD, I do not think it is too ugly (compared to much other old NAD).:)
Edit 2:
Aha, Zone 2 was about Record Out. Whatever it is.:)
DanielT
DanielT
I took some more pictures.:)
DSJR
Suffolk Coastal, UK
Good luck :)
By this time, we stocked only the separates (amp, tuner, CD player) and I don't readily remember the receivers of this era. I thought all of them were rather better than the cheapskate bland grey looks but wasn't aware so much of the 'eye-fi' vibe that dominates almost all the hobby side of music reproduction domestically (maybe pro's too, but I'm giving benefit of the doubt here :) )
DanielT
DanielT
Thanks!:)
Then you can do "the old school Hifi". Right now I'm fixing to an FM antenna.:)
It works well the NAD. Flexible with pre out. I now run NAD (as pre amp) together with:
DanielT
DanielT
Okay, game on. Provided not too large listening room, normal listening volume, speakers at least 87 dB sensitivity (preferably a few dB more but it should probably go perfectly ok anyway), absolutely no demanding music. Little normal pop ... Sure.. lets go. Throw in any other amp.:)
Not because this NAD is anything out of the ordinary. Which is the thing, it's not weird this NAD. Just a normal sensible amp only.:)
Edit:
Or to be a little more on the safe side. I can throw in my HK 670. No monster but ..+/- 75 amps.. :)
Doodski
Edit:
Hehe. I did a couple of rough calcs and that HK at 2 Ohms would need +/- 150 VDC rails @ 75A and would be outputting ~7955 WRMS peak.
Cough cough... Somebody is fudging the numbers here...lol
I checked and the power supply has +/- 50V rails at best.
DanielT
DanielT
DanielT
DanielT
Ahhh... it is a mark 2 version with +/-48VDC rails... so same calcs apply.
Wait .... I do not know the version I have ... Must check it out. Brings it out tomorrow.:)
Ha, NAD 720BEE, the amp part, is this. By the way:
Amir:
"Personally, I think 67 watts is not enough for home listening. Today's speakers have become smaller in size and shrunk in efficiency, needing fair bit of power to get them to produce proper dynamics."
Well lets se..The interesting thing if we use NAD 720BEE in the test is of course how far do you get with so few W ?!:)
Edit:
Note it is possible that we hear the difference. I have no preference or desire for either one or the other, hearing difference or not that is. . I am just curious.:)
If W and /of the amp quality is not enough, I know it and it's good to know, but what I mean is that I will not be sad if that is the case.
Edit
Today I can not open up the catalogs from HK but there you can read pm what they call "High instantanius current capability". How long time it lasts this instantanius I do not know.:)
Jungstar
Did you notice it runs much better as a power amp in Amirs review on page 2....
DanielT
DanielT
Yep, and I've tried that. In fact, I've run a combo with NAD C 720BEE as a pure power amp together with the DAC Topping E30 (which has volume/gain control). Works really well with a pair of 87 dB sensitive speakers. :)
I have that solution now in the bedroom.
DanielT
DanielT
Addition,
The NAD C 720BEE is, in my eyes, a good amp. Nice watts, reasonable low distortion and so on BUT it is quite large, physically large, in relation to the watts, the power it can deliver. That even compared to other class AB amplifiers
NAD C 720BEE is probably too young to be considered vintage. If vintage receivers are defined based on the looks. I'm thinking typical 70's receiver now. It doesn't have that kind of look. The looks, a matter of taste, of course, but an advantage is the second-hand. The price of a NAD C 720BEE is then probably relatively low. In fully working condition I imagine you could pick one up for around $80, maybe $90.:)
3m3rson
The NAD C720BEE Stereo Receiver is my daily driver with an all analog signal path (no DAC/ADC). Tonally neutral, runs cool for a Class A/B amp, and dead silent if quality interconnects and clean power are used. Great connectivity features with 5 RCA inputs plus a TAPE LOOP/ZONE 2 that I use as an optional effects loop when the source warrants it and also to feed my outdoor patio amp a different source from the NAD’s preamp section. I use the SUB OUT as well, which in combination with a passive Hi-Pass Filter on the PRE OUT/AMP IN, leaves the 50W continuous (110W dynamic @ 8 ohm) / channel amp section plenty of room to work. It has a respectable AM/FM (RDS) tuner. Being a mid-1990s product it won’t need service for another decade. Made in China.
Older NAD remote controls work with this machine. The Zone 2 remote is not that helpful it only allows you to change the source.
There is also the NAD C725BEE. This unit is much the same but with an RS-232 connection for AMX/Crestron control.
It is a tremendous value at ~$200 used that you won’t need to upgrade until you got > $10K invested in other parts of your system. If I were to start a little company and produce affordable analog stereo receivers, I would model it after this NAD with the only addition being a decent phono pre-amp built in.
DanielT
DanielT
If you just accept its physical size and appearance, it's a banger its functions and the power it delivers. :D
I personally think it is much better to buy a used amp and thus have a decent amount of money left over in the wallet to spend on the speakers. Speakers, there it really makes a difference.:)
__
Regarding a new amp, or power amp, this is the only one I can think of now because the price for the nice watts is so good:
sfg
The C720BEE came out in 2004. I bought mine in 2006. It came with two remote controls: SR 5 and ZR 3 (see attached photos)
Strengths: provides low distortion peak power, handles low impedance loads well, features toroidal power transformer, very good FM reception, runs cool.
Weaknesses: no phono preamp, remote volume control increments are rather coarse (goes from too low to too loud in one step), physically large.
I still have mine, but not using it.
