Room Measurement Tutorial for Dummies Part 1
Mal
Is it possible to install VirtualBox on a chromebook? That will leave your OS intact
Never heard of VirtualBox! Is that a windows thing? Chrome OS, basically, is Linux, and in developer mode you can issue Linux commands and *maybe* set up REW from there. Other possibilities are installing a standard Linux distro on the chromebox in dual boot mode or overwrite chrome os. I suspect it's all going to be hell on earth to get going! I spent a lifetime in scientific research, sys admin, programming... I wanna retire from all that! So I think, given I found a solution* for total idiots, I'll back away from from this thread.
* My "solution" was to play with the simple DSP in my KEF LSX control app until they sounded "good enough"... which took about five minutes and was about as hard as answering an email. For my passive computer speakers, I'll play with simple DSP extensions/apps on my chromebook until they sound as good as my KEFs... and if (as is likely...) that doesn't happen, buy the next most likely speaker. If I get bored with this line, if I can't find solution after a few goes, I'll use KEF LSX as my computer speakers and get KEF LSX II for my TV/Spotify, and retire completely from audio upgrading... maybe...
** Two first page videos on ChromeOS Flex have titles "ChromeOS Flex is a BAD operating system" and "ChromeOS Flex is a Nightmare". I might watch them for amusement, but I very much doubt I'll be going down that route... My main point in buying a chromebox was never to have to do the least amount of geeky stuff again. When tempted to go geek I have always decided to give up the temptation... I think this has always been the right decision... makes for an easy life...
Mal
REW will run painlessly on most Linux distro's, the latest Linux builds come with it's own Java built in, avoiding what use to be the main
problem some would face. I run it here on PCLinuxOS but if I'm going to do multich measurements I use my Windoz install. There's something not quite right there...."
"Something not quite right there" - sounds like pain to me!
Sal1950
The Chicago Crusher
Central Fl
Only if you do multich measurements. It just wasn't plug n play under linux.
It's probably just a configuration tweak of how the Linux install handles 5.1 or 7.1 files but I was
too lazy to fool with it when it was working in Doz automatically. Even that was a couple years back?
ArturoKiwi
Multi-platform Virtual Machine Manager
Germinal
Is there a topic on how to interpret the measurements? And what treatment one should use ?
Overseas
New dummy here :) Got the minidsp Umik-1, downloaded the RWE then got stuck, no surprise, eh ?
After reading some line on REW tutorials about SPL levels and the danger to fry the system, I decided to go easy and check Amir lessons, they seem friendly right from the beginning. New project in 2023...
Dennis_FL
Venice, FL
Here's a quick way of using REW but it is written to be used in Roon.
frki16
regarding microphone, is it equally good to use some other quality microphone instead of umik-1? I have access to Logitech's GROUP (video conference) microphone.
Bow_Wazoo
I measured my room today.
This profile came out of it.
(The bass shelf is mine)
I used the OMNITRONIC MIC MM-2USB (professionally mounted on a camera tripod). The sound is unrecognizable.
Probably needless to say...
holbob
Lincoln, UK
Hope you got a 5000watt amp or sub.
Andysu
Eq for dummies that made it with less than enough Peq bands , 20,038 Peq filter bands in 32 channel so can be used to address any speaker with manual or auto or manual step freq of the sine wave generator one at a time , yes that will take lots of hours m quick sweep and then it corrects it all be with 0dB ,m when of course mic placed near each Bass , HF horn one at a time , otherwise , dirac art is waste of time , what is point with cutting corners with Q bandwidth to lowering a series of freq bands that are pushing a certain freq area upwards or downwards ,
but i just have to bare with few Peq i have for outboard Eq until someone like , behringer makes 32 channel 20, 038 for around £300 which would sell like hot cakes ! i see everyone else showing off the REW and the freq is just as crocked as mine is , 20, 038 will be more than enough to get that , ,music or movie sounding way , ,more than way better , the rest of those auto Eq , no one will touch them
behringer FBQ 2460 has about just little over 600 filters but only 20 per channel A and channel B can be dialled in and programmed and has Q down to 1/60 that is very narrow
if daisy chaining channel A to B then 40 Peq per each speaker Bass or HF , but that isn't enough , ( furthermore the FBQ has some freq gaps so some bands sine wave spot or sweep will have missing gaps ) i don't think anyone want stacks of FBQ from floor to ceiling , so a new digital DSP 20,038 Peq in 3U frame with xlr balanced 32 channels , that's what i visualise , but doesn't yet exist for £300 , i shall be patient and wait
fragzone
This video is also a comprehensive and excellent tutorial on using miniDSP UMIK-1 with REW and exporting the correction to Equalizer APO.
Very good video thankyou. Bookmarked for future reference.
Quite interesting to see he didn't EQ up any dips because of potential issues with amplifier headroom, is this normal practice?
Mikig
Italia
Ci sono poche cose più trasformative nell'audio che imparare come funziona l'acustica della stanza. Non guardi mai più nessuno sistema allo stesso modo. Come passare dalla fotografia cinematografica al digitale, le misurazioni ti danno un feedback immediato su ciò che sta facendo il tuo sistema. Anche se scegli di non apportare modifiche al sistema, eseguire misurazioni può far progredire la tua conoscenza dell'audio. Quindi spero che tutti voi che leggete questo post cercheranno di misurare la vostra stanza.
La mia promessa a te in cambio è di darti il modo più semplice e infallibile al mondo per eseguire le misurazioni della stanza. E fallo in un modo che ti ottenga risultati professionali con una capacità sostanziale di andare più in profondità che vuoi.
Ci sono una serie di video e guide online su come farlo, ma secondo me, usano tutti l'approccio sbagliato. Vale a dire, cercano di mostrarti in una volta sola come fare tutto. Il problema è che una serie di cose possono andare male lungo la strada che portano al fallimento e all'arrento. Il mio approccio può sembrare strano, ma per favore fidati di me. È il modo migliore per farlo ed è in realtà quello che ho fatto io stesso per imparare a usare lo strumento. E viene dal vedere così tante persone cercare di prendere il morso completo e fallire.
Procedura guidata di equalizzatore della stanza
Lo strumento preferito è un programma per computer chiamato Room EQ Wizard o REW in breve. Purtroppo non c'è un wizard nel programma. Una volta imparato a usare il programma, è potente e veloce da usare. Fino a quel punto, però, il programma può sembrare impenetrabile anche se sei esperto di computer e conosci le misurazioni. Le insidie sono l'interfaccia utente non standard, l'uso di un gergo tecnico pesante ("tukey window" qualcuno?) che mi ha persino fatto non sapere quale fine fosse finita. È stato solo attraverso una sperimentazione significativa e la creazione di "controlli" in cui sapevo quale doveva essere il risultato, sono riuscito a capire come funziona il programma. Il percorso che ti mostrerò qui ti impedirà di affrontare queste difficoltà.
0. Il primo passo è scaricare il programma. Una volta dovevi registrarti in un forum per ottenerlo, ma ora ha un proprio sito web. Il download è senza problemi, senza spam, non spazzatura. http://www.roomeqwizard.com/
REW è scritto in "java", il che significa che è piuttosto portatile e funziona su Mac e Windows. Il roveniente è che è scritto in Java, il che significa che la cosa stupida (Java che è) si siederà sullo sfondo e ti infastidirà per sempre per aggiornarlo, e aprirà il tuo computer a lacune di sicurezza. Lo abilito e lo disabilito come ne ho bisogno. Suggerisco per ora di lasciarlo abilitato fino a quando non si supera il programma. Qualche giorno di utilizzo non è doloroso.
Questo è TUTTO ciò di cui hai bisogno per questa parte del tutorial per quanto riguarda hardware e software! Sì, mi hai sentito bene. Non è necessario acquistare un microfono. Non collegherai nemmeno il tuo laptop al tuo sistema audio. Tutto quello che voglio che tu faccia è eseguire il programma e, soprattutto, imparare i passaggi per generare toni di prova e misurare la risposta. Il suono sarà prodotto dagli altoparlanti del tuo laptop. E le misurazioni eseguite utilizzando il suo microfono incorporato.
No, queste non saranno le vere misure della tua stanza poiché gli altoparlanti del tuo laptop fanno schifo e il microfono fa schifo quasi altrettanto. Il motivo per cui voglio che tu inizi in questo modo è che la parte più difficile di questo è usare il programma. L'ultima cosa di cui abbiamo bisogno è aggiungere altri bit che possono anche causare problemi propri. La maggior parte dei computer ha un microfono e altoparlanti funzionanti, quindi siamo a già per i test. Una volta che siamo a nostro agio con questo passaggio, possiamo passare all'aggiunta di hardware e a fare misurazioni reali.
1. Installare REW ed eseguirlo. La mia versione controlla sempre le nuove versioni all'avvio. Annullalo se lo vedi e lascia che il programma inizi. Dovresti vedere questa schermata:
2. Ignora tutto tranne l'unico pulsante in alto a sinistra che ho evidenziato in giallo chiamato "Misura". Premi quel pulsante. REW apparirà un messaggio di errore che si lamenta della calibrazione. Ignoralo! E digli di "continuare comunque".
Dovresti quindi vedere questa finestra pop-up:
Ignora tutto tranne i due misuratori VU a destra. Ci sono due numeri in basso e l'indicatore rosso sui grafici a barre. Vedi se i numeri stanno ballando un po' su e giù. Fischia o urla nel portatile e vedi se saltano molto in alto. Se hai usato il tuo portatile per skype o qualsiasi altra cosa che usi il microfono, dovresti essere a posto qui.
Se non vedi i misuratori VU cambiare, il microfono del tuo computer non funziona. Fermati qui. Non fare nient'altro finché non lo capisci. Per gli utenti Windows, vai al pannello di controllo audio, seleziona il microfono e assicurati che non sia impostato per disattivare l'audio o che il suo livello sia a zero. Molti portatili hanno un tasto funzione che disattiva e disattiva l'audio del microfono. Controlla di non aver attivato l'asilenziamento in questo modo.
3. Supponendo che tu stia vedendo i livelli cambiare con il suono, il passo successivo è premere il pulsante a sinistra che dice "Controlla i livelli". Dovresti sentire un suono sischiante come la radio FM senza stazione. Quelli di voi che usano gli AVR, dovrebbero avere familiarità con questo tono di prova per calibrare i livelli degli altoparlanti. Questo suona solo per pochi secondi durante i quali i misuratori VU dovrebbero sparare molto in alto.
Se non viene riprodotto nulla, allora hai un problema di riproduzione nel tuo computer. Avvia il tuo lettore multimediale preferito e fallo riprodurre un po' di musica sul tuo laptop. Se hai cambiato l'uscita predefinita in DAC USB, ecc. devi sconfiggerli in modo che la musica esca dagli altoparlanti del laptop. Una volta lì, allora REW dovrebbe funzionare allo stesso modo e il rumore di prova a banda larga dovrebbe essere riprodotto premendo di nuovo Check Levels.
REW riferirà quindi su un livello in verde, giallo o rosso. Questa è la quantità di spazio di testa che hai in dB SPL. A REW piace avere circa 10 dB SPL di spazio per la testa. Qualsiasi cosa più bassa e REW si lamenta con un valore SPL rosso:
Usa il campo di testo chiamato "Livello (db FS)" e premi il pulsante giù su di esso e continua a testare fino a quando il livello non mostra il verde. Puoi vedere il mio impostato a -25.0 in questa istantanea.
Se il tuo microfono o sistema non funziona, cosa che avresti dovuto prendere prima, vedrai qualcosa del genere:
Questo è fondamentalmente "zero digitale" con il programma incapace di catturare nulla. Nel mio caso, il mio microfono era impostato per disattivare l'audio.
Ecco un livello OK:
Si noti che tutto quello che dovevo fare era abbassare il db SPL di un paio di tacche.
Ahimè, questo esercizio può essere inutile. Il tono di prova che REW usa qui è diverso da quello che usa per effettuare le sue misurazioni reali. Il motivo per passare attraverso questo è perché i controlli per regolare i livelli sono gli stessi quando facciamo le misurazioni effettive. E questo passaggio aiuta a risolvere ulteriormente la risoluzione dei problemi se le basi non funzionano bene.
5. Ora che i controlli di base sono fatti, siamo pronti per la nostra prima misurazione. Che emozione!:DPrima di poterlo fare, devi compilare i due campi di testo che avevo evidenziato nell'interfaccia utente. Quella è la gamma di frequenza delle misurazioni. Vuole conoscere le frequenze di inizio e di arresto. Metti 20 per la prima scatola e 20000 per la seconda. Ora premi il pulsante "Avvia misura".
All'inizio probabilmente non senti nulla anche se il programma sembra fare qualcosa. Questo perché gli altoparlanti del tuo laptop non possono riprodurre 20 Hz. Dopo un po', la frequenza diventa abbastanza alta da iniziare a sentire un tono che sta cambiando in tono. Cambia rapidamente di frequenza fino a 20 Khz. Per le stesse ragioni del basso e del tuo udito, probabilmente non sentirai nemmeno l'ultima parte di questa spazzata. Va bene così. Stiamo solo imparando a conoscere il sistema.
Durante questa misurazione, REW pubblica un messaggio "headroom" e un numero SPL che cambiava molto come quando stavi controllando i livelli. Ancora una volta, se questo numero entra in valori in rosso, il tuo segnale è troppo caldo. Allo stesso modo blu significa che i tuoi livelli sono troppo bassi. Usa il controllo Livelli per cambiare i livelli o il livello dell'altoparlante nel tuo PC se non riesci ad aumentarlo abbastanza in REW.
REW sembra soddisfatto dei numeri da 10 a 20. Mi piace farlo il più vicino possibile a 10 in modo che le misure che faccio siano ben al di sopra del pavimento del rumore della stanza. Per questo test qualsiasi cosa in verde va bene perché stiamo solo giocando. Ma quando arriva il momento di fare misure reali, questo diventa importante.
Ahimè, la regolazione dei livelli in questa modalità può essere noiosa perché ogni volta che REW ha finito con la misurazione, torna all'interfaccia principale del programma con la nuova misurazione catturata:
Se i tuoi livelli erano sbagliati, ignora ciò che vedi e fai di nuovo clic su "Misura" e torna alla finestra di misurazione e regola i livelli. Continua a farlo finché non ottieni livelli soddisfacenti.
6. Congratulazioni. Hai appena fatto la tua prima misurazione della stanza! O dovrei dire le capacità dell'altoparlante e del microfono del tuo laptop. Dovresti vedere due cose qui. Uno è la tua misurazione in una finestra molto più piccola a sinistra. Ma anche una versione molto ampliata a destra come si vede nella mia. Se vedi il piccolo grafico a sinistra ma non a destra, allora usa la barra di scorrimento a sinistra del grande grafico e vai su e giù e dovresti essere in grado di trovarlo.
L'asse X (orizzontale) è la frequenza. L'asse Y (verticale) è il "livello SPL" di riproduzione. L'ho messo tra virgolette perché i numeri assoluti lì sono completamente sbagliati. Avevamo potuto impostare il nostro microfono e il livello dell'altoparlante su qualsiasi cosa e cambiare quei numeri. La buona notizia è che questo non ha importanza!!! Nelle misurazioni acustiche, ci preoccupiamo solo della forma delle cose, cioè dei valori relativi. Ci interessa che a diciamo 50 Hz, abbiamo avuto un picco che era 10 db più alto che a 1 Khz. Non ci interessa quale fosse il valore effettivo misurato in nessuno dei due punti.
Tentare di ottenere livelli SPL accurati è il più grande errore che gli utenti di REW fanno! Non cadere in quella trappola. Non ci sono informazioni utili lì dentro. Ottenere livelli accurati è possibile, ma richiede un ampio lavoro di detective e configurazione senza valore netto. Ottieni un misuratore SPL se vuoi calibrare il tuo sistema.
Tornando alle nostre misurazioni, puoi vedere la risposta del mio portatile qui sopra con la TV in riproduzione in background e il limite di 10 KHz. Come previsto, gli altoparlanti del mio portatile non giocano al di sotto dei 300 Hz. E la risposta ad alta frequenza è stata scattata dopo circa 7 o 8 Khz. Questo tipo di informazioni non è rivelatore? Avresti potuto indovinare questi limiti semplicemente guardando il tuo portatile o riproducendo musica?
Mentre continui a fare misurazioni, REW impila ognuna di esse a sinistra. Cliccando su uno di essi, vedi quel grafico.
6. Ora è il momento di sentirsi a proprio agio con il programma. Fai un'altra misurazione, ma questa volta passa la mano sul microfono o sugli altoparlanti e vedi come cambia il grafico.
Per vedere tutte le misure contemporaneamente per confrontarle, fai clic sul pulsante che dice "TUTTE SPL". Vedi un elenco di caselle di controllo in basso. Fare clic su e off su di essi e i grafici appaiono e scompaiono. Il colore del grafico corrisponde alle liste di misurazione a sinistra. A proposito, clicca su dove si trova la data e digita quello che vuoi. Ho messo il nome della misura come "altoparlante coperto a mano". C'è anche una casella bianca per tutti i commenti che vuoi aggiungere.
Per eliminare una misurazione clicca sulla "x" rossa sulla barra di misurazione a sinistra. Vai avanti, eliminali tutti e poi fai una nuova misurazione. Mettiti a tuo agio con l'interfaccia.
Clicca sul pulsante in alto a destra che dice "Limiti". Cambia il numero sinistro e destro e questo cambierebbe la gamma di frequenze viste. Se vuoi vedere solo i bassi, imposta il basso a 20 Hz e l'alto a 200 Hz. Questo non mostrerà molto ora data la limitazione del laptop, ma è essenziale quando sarà il momento. L'impostazione superiore e inferiore a sinistra regola l'alto e il basso del display. Ancora una volta, ignora il secondo set a destra.
Vai al menu File e fai clic su Salva. Ciò che REW salva è l'intera serie di misurazioni mostrate nella barra verticale sinistra, non singole!
Questo è tutto ciò che voglio che tu faccia in questa lezione. Il resto è un po' più facile. Hai problemi? Fai domande qui. Facciamo in modo che tutti finiscano questa parte prima di andare avanti.
Parte 2:http://www.audiosciencereview.com/forum/index.php? threads/room-measurement-tutorial-for-dummies-part-2.5/
Good morning Amirm,
thanks for the tutorial that I started following. The initial screen is different, but I did the test with a Mac microphone. Here is the result...
Should I worry already?? :)
djigibao
Good morning Amirm,
Change settings like in this picture down then put te results again (graph settings can be 1/3 or 1/6):
brass
London, UK
the program can seem impenetrable even if you are computer savvy and know about measurements.
Yes. Relatable. Appreciate the hand-holding approach. REW current version is V5.31, 23rd March 2024.
The pop up window after step #2 has changed. Drastically.
"You should then see this pop up window:"
Would it be viable to update the guide to match the current interface? Cheers
Blew
Sydney, Australia
That would be a never-ending job.
Does REW make significant changes to the interface that often that it's not worth bothering documenting?
