BinkieHuckerback
- Joined
- Feb 16, 2021
- Messages
- 732
- Likes
- 1,124
In the UK it's Audi and BMW drivers one needs to fear.
... but @rdenney may.Rick "sticks mostly to dirt roads and trails, or back pavements that don't much go anywhere" Denney
^^Needs qualification^^Can someone please provide the exact formula for showing the trace a wheel's valve-stem would make while traveling in a straight line?
Graphical representation (Height/Time plot) would also be much appreciated: I am brain-locked.
From the perspective of a stationary viewer/VidCam, situated 3meters away from - 'wheel's valve-stem would make while traveling in a straight line' - from left to right.The trajectory of a wheel's valve stem as the wheel moves in a straight line will essentially form a cycloid. A cycloid is the curve traced by a point on the rim of a circular wheel as the wheel rolls without slipping along a straight line.
The parametric equations for a cycloid are given by:
x=r(t−sin(t))
y=r(1−cos(t))
Here, r is the radius of the wheel, and t is the parameter, which can be thought of as time. As the wheel rolls without slipping, t also represents the angle through which the wheel has rotated.
- ChatGPT
The cycloid equation above would be 'spherical cow in a vacuum' level approximation. If you want to account for viewing angle it will change things, but then we should probably also have the depth of tire, rim and however much of the valve stem we're accounting for to find the point we're looking for. Do we need to consider the deformation of the tire under load too?From the perspective of a stationary viewer/VidCam, situated 3meters away from - 'wheel's valve-stem would make while traveling in a straight line' - from left to right.
Does the formula change? Like a 'parallax' effect of a moving object or like that of a 'doppler' effect?
How many total miles do you put on your NightRider, during those four seasons?My commuter bike... Four seasons commuting
The past few years I have been averaging anywhere from 3500-5000 km per year on my bikes... 4-500 km per month from spring to fall, 250-300km per month during winter. During winter my mileage is limited by road conditions. I typically avoid riding a day or two after major snowfalls because of snow/ice accumulation on the roads. Niterider is the bike I use for commuting but I also have road bikes... I used to do group rides but now ride mostly solo.How many total miles do you put on your NightRider, during those four seasons?
I used average about 1200miles/year but in the last 18 months, I have become just another slacker on an eBike!
Did I miss this one before?Riders and drivers - of all sorts - feel that if a person likes the thrill-of-speed; then, they should take 'it' to the track.
Fine!
But a controlled environment - like a race track - does not have the exhilaration-of-the-unknown or that getting-away-with-it mentality...
IMHO: I've been there and done that - yawn!
I have 3 photos to post but I have no involvement.
Past, present, or future.
What you did is so cool!My mum needed a new bike so I bought her one
Motor | Specialized SL 1.1, custom lightweight motor |
Battery | Specialized SL1-320, fully integrated, 320Wh |
Sensible engineering - better power output and efficiency than the old arm-powered winch grinding stations.Hey, wait a second, what exactly is going on here?
I am big fan and have been watching every/any sailing event that has ever been aired anywhere!Sensible engineering - better power output and efficiency than the old arm-powered winch grinding stations.
