Target Room Response and Cinema X-curve
fas42
Australia
The power and cost of current technology makes this sort of thing a trivial exercise - all systems could be made to have the same curve to any degree of dB accuracy without too much fanfare. Trouble is, system "sound" doesn't then go away ...
garbulky
No, I think that is even worse phenomena than what we are talking about :). The testing was done by Harman using B&W 801 speakers. So not the planar tweeters that are super bright.
Having heard the latest 800 d3 speakers, this may be an issue right there!
NikotheNeko
I think I will design an app to produce equalization files. I can do it with simple Monte Carlo Simulations I'm sure.
Thankfully for me my father has done a huge amount of work with computer vision. It would be completely possible I think. I could also probably design a cheap unit that will eq the sound as a digital signal for when you are not playing music or recordings from a computer.
Eganmedia
I understood the purpose of the X curve was to compensate for the loss of high frequency energy in a large theater. The lecture I heard described that by implementing the X-Curve in smaller dubbing stages, mixes would be brighter than they otherwise would as mix engineers added high frequencies to offset the EQ curve. That additional high frequency boost is lost when the movie is played in a large theater with speakers at far greater listening distances than the speakers in the post-production mix facility. It was my understanding that playback rooms should have a flat response, and that most feature films have several versions of the final mix to accommodate various playback venues, including a version without the X-curve for home theater distribution. Was I mislead?
Chromatischism
Surprisingly two systems, #5 and #6, actually degraded the fidelity by garnering scores less than no EQ! This tells us that there is a right way to perform such equalization and a wrong way. Objective measurements tell us the potential reason for varying preference scores. The averaged frequency response across all 6 systems is shown in Slide 4. Notice that the two systems which underperformed no equalization both had rather flat frequency response.They also had responses that had substantial amount of dips/variations. The better performing systems on the other hand had smooth, sloped down responses. This runs counter to the common notion that flat frequency response must be right.
Slide 4: Listener preference rating strongly points to a frequency response that slopes down and is smooth.
Contributing to the poor performance of the worst system (in teal color and #6 in the previous graph) was a design weakness of the specific speaker used in the test. The B&W has a response dip around 2 KHz due to large disparity in the size of its drivers (the larger driver becomes too directional before the next smaller driver takes over impacting the tonal quality of the reflected sounds). That EQ system made things worse by applying a further dip in those frequencies causing a nearly 5 dB trough around 2 KHz. There is no science that backs having such a 5 dB dip is beneficial. Indeed research shows the complete opposite of needing to have smooth response. The poor subjective scores of this EQ system and B&W speaker confirm this understanding.
Going back to our X curve, the two systems at the bottom match it best by having a rather flat low to mid target frequency. The perceptual effect however was a negative one. Clearly then sticking with the notion of matching X curve is a bad idea.
The learning here is that we need to trust our ears and use a target response that is smooth but sloping down as we go from low to high frequencies.
Unfortunately the automated equalization in many mass market AVRs and processors do not allow any customization of the target response. In the case of the popular Audyssey for example, you need to opt for its Pro version to be able to customize its target response curve. The implementation in consumer AVRs without that is all or nothing. If the Pro version is available for your AVR, I highly suggest that you use it to modify the default response to be sloping down.
Great write-up, as usual. I'm guessing Audyssey is the violet or blue line. It looks like the familiar post-EQ curve with Dynamic EQ turned off. You may already know this, but for others here:
Audyssey works differently than other room EQ systems. Most of them will flatten the bass region, then apply a "house curve" as you describe here. Audyssey doesn't set a static house curve in the bass region, instead achieving flatness then relying on Dynamic EQ to adjust the low frequency boost based on the user's volume level. So the "house curve" on an Audyssey system is adjusted dynamically based on equal loudness research. It will end up with a sloping response very much like the dark blue or green lines on the graph at lower listening levels, and flattening out as you reach 0 MV – so it will produce a balanced sound at any level. That is why many evaluations of these systems fail to show it on an equal footing. They think by turning these options off they are making a "fair" comparison.
Other systems using static curves will either have vanishing bass at low levels, or overpowering bass at high levels. There is no way to achieve spectral balance at all levels without a self-adjusting curve.
In addition, the good news is that we have much more customization at our fingertips today with Audyssey. We can turn that pesky midrange dip off with the smartphone app and even tailor the curve by hand. I find limiting the corrections to 300 Hz to be very beneficial, as the default Audyssey target tries to make my speakers too bright and harsh in the treble. A forum member at AVS even made a PC program that can take Audyssey measurements, allow the user to craft a custom curve, and load it back into the AVR.
You are absolutely right that lack of control was a major issue with these systems in the past, but some have made great improvements, by both the technology owners and users.
DeLub
The Netherlands
Fortunately there are systems with the right response curve as in the JBL Synthesis equalization in Figure 6 (not surprisingly, from Harman which performed the EQ blind tests above). The bright green is the measured response. It almost completely hides the target/desired response (a good thing since it is showing tight compliance with the target response). If you look carefully, you can see that it slopes down about 5 dB from 100 Hz to 20 KHz. That should be the starting point for your equalization efforts.
This is a slope of about 0.7dB per octave. Is the roll-off at the bottom due to the capabilities of the speaker? If so, would this mean that when you add a decent sub into the mix, the target should be a 7dB drop from 20Hz to 20kHz?
And how does this compare to Oratory saying Olive et al. found that a speaker should have a downward slope of 1.0 dB?
Le Concombre
I don't dig at all the recommendation : "Whatever you do, do not, I repeat do not follow the X-curve for your home system."
It's even quite fascinating that it is provoked by the one exemple of calibration that we can duplicate and comply to. And it works just great with movies, as intended
My X Curve is not much more that a steeper (30 Hz) Linkwitz Riley applied to a BK (in red).
BTW 1 : I switch between set of filters tailored after different "targets" to fit the recordings
BTW2 : I don't apply any correction centred above # 350 Hz. Treble roll off then happens to be very consistent with BK, Harman Audio Test System and X curve adapted for small theaters
  • Courbe ISO X smaller theaters.txt
Tom Danley
No I don't think so, that is what I recall and can also testify getting the highs through a perf screen is a tough job ruling our "flat response" with the number of drivers they had to work with. Better it is to have a nice smooth kink free roll off than to have the system down with a blown hf. If I recall right, the comercial theater hf roll off was more severe than the home listening curve.
The explanation for the roll off now may be partly tied to the increase in recording "brightness" when CD's first came out, before the loudness wars there was the "sound better than records war" which combined with early filters etc could lead to expensive bright but icky sounding CD players.
Alternately, the general consensus about the listening based roll off now is that this is AT the listening position and as such is the sum of the direct sound and room sound which due to decreasing directivity with decreasing frequency, makes for a rising low end from a speaker that started out flat.
The squishy part is the folks that mix down and crreate our recordings, for the most part all have different monitors and gear as well as rooms and personal taste.
Best,
Tom
pedrob
A fascinating and informative discussion.
Is it then necessary to assume that all or most releases have a perfectly flat response? If they do not and they already have an incorporated curve, then are we in fact doubling up by adding the curve to our systems?
A flat response could mean we are hearing the recording as it was intended. Perhaps it all depends on the response of studio monitors?
tuga
Oxford, England
With respect to this topic, majority of people tend have similar tastes. Multiple companies have done this research and arrived at the same conclusion.
Regardless, this is something that I insist should be done to taste. This is what is great about DSP/EQ. There is no specific speaker "sound" that you must live with. You can change the curve and listen. Or have multiple one to select from depending on the music.
This research was based on a tiny sample but shows massive variance:
tuga
Oxford, England
As far as I know, monopoles and dipoles with flat on-axis anechoic response will all produce a bass-to-treble downwards tilt in room.
And I think that onmis tend to produce some level of tilt in anechoic conditions.
krabapple
Fortunately there is considerable activity in SMPTE and AES organizations to revise the production standard to hopefully bring it up to the state of the art in understanding of room acoustics.Until then, we really have no target "standard" to aim at in calibrating our home systems
Written in 2016. Are we there yet? Have the SMPTE or AES released such standards?
Newman
This topic has nothing to do with ‘releases’. Why do you see a connection?
This topic is about why a correction curve that was used in movie theatres (as a quick-and-dirty way of getting the overall frequency response to sound balanced, and which was all about being quick, not especially accurate) is completely wrong to try using at home with your home AVR that has some kind of room correction tool built in.
pedrob
I took room to be a room at home and as it is unusual to consider a cinema to be a room. So as far as I'm concerned there is a connection.
I only want one curve as switching according source is rubbish.
It does raise an interesting question. What room is best for Blu Ray discs, or do they have a different curve?
krabapple
It would be if all 'sources' (and by this I mean software -- music, movie soundtracks-- not Bluray vs DVD vs streaming) were mixed and mastered the same.
In practice we are at the mercy of vast disparities in this area. This is why Floyd Toole has given three cheers for tone controls.
Newman
Your comments make no sense, Pedro.
Quoting the OP: Whatever you do, do not, I repeat do not follow the X-curve for your home system.
Quoting the OP: no such target curve exists at all for music. That unfortunately is the end of the journey for that type of content.
??? Like I just quoted the OP, no such curve exists at all for music. So, what curve are you asking us to compare "Blu-ray's curve" to?
Quoting the OP: ...and each production different yet again from another room/facility. Tonally then we can never know what we are hearing in our room is what was heard when the music was produced. Don't even dream about approximating the live scenario prior to the recording...
I am not aware of any such thing as a Blu-ray curve.... no more than a DVD curve, a CD curve, or an LP curve, if by 'curve' we mean 'target room response ungated frequency response curve at the listener seat (or average of seats)'.
I don't think movie soundtrack mastering is done with any inbuilt correction curve, if by 'correction curve' we mean a mix that sounds great coming out of reference-grade monitors is then subjected to an additional curve, and this is imprinted into the home theatre movie distribution masters (BD, DVD, download, or stream).
The only 'correction curves' are being applied in the sound system of the listening venues, be they cinemas or home theatres, for the sole purpose of trying to get the room to sound right (for the home, and with dubious success above the bass) or consistent (for the cinema). None of these correction curves are trying to unwrap a non-flat frequency response that was imposed onto the original disc/whatever.
cheers
Andysu
'Glory' i embrace the x-curve on my true reference DOLBY STEREO™ with Lucasfilm Ltd THX sound system.
acoustaman
Why are we only looking at Spectrum responses and not Transfer functions? If you have a flat transfer function in a system it reproduces the spectrum balance of whatever content is put through the system and will correlate well to the system that mastered the material.
acoustaman
There Is No "There" in Audio
By Amir Majidimehr
[Note: this article is slightly revised version originally published in the Widescreen Review Magazine.]
Readers of Widescreen Review Magazine no doubt are familiar with video calibration and its importance in getting proper images from their display. Using specific test patterns which were used to calibrate the production equipment, we are able to match the same standard and hence, achieve a picture that is close if not perceptually the same as what the talent and production crew saw. The only limit is the capabilities of our display, not the existence of a method to get there.
While many think otherwise, such a standard does not exist for audio. Other than setting levels with a simple SPL meter (which in itself generates approximate results), there is no method to match the sound that was heard in the production of movie soundtracks or music. We can guess, make assumptions, etc. but at the end of the day there is nothing remotely like video calibration when it comes to audio. Audio for the lack of a better word is "broken" as an architecture. It has always been and continues to be so. Both for music and video/movies. Yes, strong statements but all true as you will see in this article. Fortunately there is some help here from an unexpected direction but before we get there, let's examine the problem.
Frequency Response
The frequency response of a system is akin to color and grayscale of video. Change the frequency response enough and the timbre, or the tonal quality of the audio changes immediately and readily. Nowhere this is more obvious than the performance of our speaker and impact of the room on the same. While an amplifier can have ruler flat frequency response, even the best rooms can't remotely approach the same.
Even if the speaker has decent frequency response once you put it in a room, all bets are off. The low frequencies specifically are heavily influenced by the room and hence radically change the response of the speaker to anything but neutral. Figure 1 is an example this, showing the "raw" (unequalized) measurement of my Revel speaker in my personal theater. This is an excellently designed speaker yet has no choice but to have its response varied by more than 20 dB once placed in my room.
Figure 1: Measured response of the left channel speaker showing large variation in frequency response (1/12 octave smoothing).
As a good friend is fond of saying,"this is just physics."You could almost put any speaker in there and the low frequency variations will persist in a similar manner.
Perceptually 10 dB SPL is perceived as twice as loud so 20 dB SPL differential represents more than 4X in loudness variation. The variation is frequency specific and hence manifests itself as tonal change from flat response. If a note hits a peak it will sound much louder than if it lands in the valley. The impact will be coloration of the sound. Worse yet, if you move in the room or put the speaker in a different room, you get different colorations yet again.
Now let's go back to our goal of replicating the sound that was heard in the production of the movies or music we bought. For starters, let's agree that they are likely to be using a different set of speaker than we are. With thousands upon thousands of consumer speaker brands and models, the odds of a listener using the same speaker that was used to produce said content is next to zero. Even if you did try to match the brand and model of speaker, you still can't get there since there is no one speaker that is used in production of content.
So right away we start with the large variations in the speaker frequency response that must be dealt with or we get a different sound. Add to it the impact of the room and there is no way on earth, sans some controlling mechanism, that you can hear the same thing was heard during the production stage.
As I hinted in the beginning of this article, we do have some tools to deal with this problem. For example, we could resort to acoustic room treatments to lower the impact on low frequencies. In this article I will focus on another tool which is electronic equalization. I have covered their use in previous articles with respect to optimization of low frequency response. Here, I am expanding that concept to the full frequency response of the speaker and room in what we call a target curve.
Target Response Curve
The target response curve is the measurement that we like to achieve post equalize of the system. In real life I can never fully achieve it. But it is a "target" and with any target, the closer I get to it, the better I have achieved the goal. And the goal again is to hear what was heard in the production of content.
In theory then, if we all agreed on one curve and managed to get our systems to deliver that, then we would be hearing the same timbre (other aspects such as spaciousness and such are beyond this means and outside of the scope of this article).
Take care of the easy part, no such target curve exists at all for music. That unfortunately is the end of the journey for that type of content. Any frequency response could have existed in the production of music. And each production different yet again from another room/facility. Tonally then we can never know what we are hearing in our room is what was heard when the music was produced. Don't even dream about approximating the live scenario prior to the recording as that adds huge number of variables of its own. We are so far away from achieving that reality that any notion of thinking we can, falls in the realm of fantasy. But let me come back to that a bit later and talk about movie sound for now where there are some standards.
Cinema X-Curve Target Response
The standard practice for movie sound production is the "X Curve" (from the letter "X" in Experimental) which was determined and codified in ISO 2969 and SMPTE S202 specifications in early 1970s. Figure 2 shows what its target response looks like.
Figure 2: Target curve used in production of movie sound. Dotted lines show allowed deviations.
Measurement is performed using pink noise as the source signal and the frequency response is gathered at 1/3 octave resolution. This has the effect of heavily smoothing the response variations. While there are problems with such coarse measurements, it does allow one to see the overall tonal response of the system.
The X Curve looks kind of odd, no? It is hard to fathom why you would want to start to roll off your high frequencies at 2 KHz. The curve's origins is an experiment that shows such a differential between near field production monitors and that of a large theater. I will be covering this in much more detail later but for now, we have years of research post the creation of X curve telling us what good sound is in a room and that graph is not it.Whatever you do, do not, I repeat do not follow the X-curve for your home system.
Realizing the problem in practice, the X-curve has been messaged in various ways both in the form of allowing for margin of error as shown in Figure 2, and different drooping response at 2 KHz. Such variations means that even if the original concept was right, you still have no prayer of achieving the same thing that was heard because so much leeway is allowed.
Let's remember that the X curve like all such responses is a target curve. The reality is different as I menionted. The Audio Engineering Society paper, A Survey Study Of In-Situ Stereo And Multi-Channel Monitoring Conditions, shows how far out of compliance production systems can be. The paper has measurements of 250 Genelec speakers used in professional control rooms. Their composite statistics are shown in Figure 3. The poor X curve shown in solid black line is lost in a sea of wide variations no matter which statistical measure you use.
Figure 3: Distribution of in-room responses of 372 factory calibrated 3-way Genelec loudspeakers in 164 professional control rooms.
In reality the problem is much worse than it seems. The standard calls for measurements using 1/3 octave smoothing as you see in the Genelec data. Variations in room response in low frequencies require accuracy down to a single Hertz. No way can you average this to 1/3 octave and hope to get a view that perceptually matches what we hear. Optimization of low frequencies needs to occur at no more than 1/12 octave smoothing (hence the use of that smoothing in my measurement in Figure 1). A measurement with such light filtering would have shown much more variations than seen in Figure 3.
Don't think that is an isolated problem for Genelec speakers. Figure 4 shows the measurements of a number of Dolby certified dubbing theaters from another study.
Figure 4: Survey of 20 Dolby certified dubbing theaters showing wide variation in response.
These variations are certainly audible so even in the context of professional application of X curve the mission is failed. It is very unlikely that any two theaters would sound the same. Or even sound good due to forced use of 1/3 octave filtering.
Fortunately there is considerable activity in SMPTE and AES organizations to revise the production standard to hopefully bring it up to the state of the art in understanding of room acoustics.Until then, we really have no target "standard" to aim at in calibrating our home systems and certainly not one when it comes to X curve.
Preferred Target Response
Let's inject some common sense here. The ultimate goal is to have an enjoyable system. If we can achieve that, then perhaps it is not the end of the world that it does not match what the talent heard when they produced the content. It is a remarkable thing but we can actually tell when something sounds good even lacking a reference. You do that all the time when you audition speakers. You have no reference to compare those speakers to yet you are able to evaluate if what you hear is "right" or not. Dr. Toole says it best in his must-have book,Sound Reproduction Loudspeakers and Rooms:
"Descriptors like pleasantness and preference must therefore be considered as ranking in importance with accuracy and fidelity. This may seem like a dangerous path to take, risking the corruption of all that is revered in the purity of an original live performance. Fortunately, it turns out that when given the opportunity to judge without bias, human listeners are excellent detectors of artifacts and distortions; they are remarkably trustworthy guardians of what is good. Having only a vague concept of what might be correct, listeners recognize what is wrong. An absence of problems becomes a measure of excellence."
There is a great manifestation of this in the AES paper,The Subjective and Objective Evaluation of Room Correction Products, by Dr. Olive et al. This is a double blind preference study of room equalization systems as shown in Slide 1. The paper is a few years old so some of the equipment is dated. But the data still remains valid with respect to listener preference and target curve we may want to use for our playback systems.
Slide 1: Room equalization equipment tested for listener preference.
The listening room is shown in slide 2 although the speaker used for this test was the B&W 802N. Levels were matched across all equipment to 0.1 dB. Eight (8) trained listeners participated in the testing. "No Equalization" was a control and reference.
Slide 2: Listening room used by Olive et al. to evaluate listener preference for room equalization.
How did each system do? Slide 3 shows their overall rankings. We see three systems that outperformed doing nothing (#4 "No EQ") which is good news as far as our ability to better the system sound using electronic equalization.
Slide 3: Preference rating of the room equalization systems. We see two (#5 and #6) actually performing worse than no equalization!
Figure 5 shows the user interface of the Audyssey Pro software and the default target response choices available. Note the checkbox "mid-range compensation." This is the reason there is a dip in the target graphs in red. Despite Audyssey's recommendation to the contrary, my strong recommendation is to leave this checkbox off. Or as a minimum, perform the calibration test twice and listen with or without and see which one you like better.
Figure 5: Audyssey MultEQ Pro target response graph selection and design. Note the flat response in low to mid frequencies and the dip in mid-range.
Figure 6: JBL Synthesis "ARCOS" room equalization target curve shown in gray dashed line. The light dark green is prior to application of the response curve/EQ and the bright green is post equalization measurement.
Summary
So as you see, we are driving blind to some extent in audio. We have no yardstick as we have in video to calibrate our systems. Instead, we need to start with the best practices in the industry and a target curve which slopes down. From there let your ears be the guide. Play some content and if the bass is too strong, it likely is. Reduce the slope some. Don't let anyone shame you into sticking with some reference as is commonly done in online forums. What sounds good is the right answer.
References
A Survey Study Of In-Situ Stereo And Multi-Channel Monitoring Conditions,Aki V. Mäkivirta and Christophe Anet, Genelec OY, AES Convention 111, November 2001
The Subjective and Objective Evaluation of Room Correction Products,Sean E. Olive, John Jackson, Allan Devantier, David Hunt, and Sean M. Hess, Harman International R&D Presentation
The Subjective and Objective Evaluation of Room Correction Products, Olive, Sean; Jackson, John; Devantier, Allan; Hunt, David, AES Convention 127, October 2009
A New Draught[draft] Proposal for the Calibration of Sound in Cinema Rooms,Philip Newell, AES Technical Committee paper, January 2012
Sound Reproduction: The Acoustics and Psychoacoustics of Loudspeakers and Rooms,Dr. Floyd Toole, 2008 [book]
Were the systems that produced the responses in Figure 4. calibrated to the same level? Another interpretation of the graphed results would be that listeners prefer louder systems regardless of spectral content assuming they are not offset in magnitude for dsplay clarity.
