GM3
- Joined
- Nov 26, 2022
- Messages
- 154
- Likes
- 178
Ok scratch my previous response... ChatGPT does a lot better:It is quite easy to demonstrate the current lack of comprehension.
Using this promt:
Code:Create an image showing the line drawing on a page of paper that would result from the following sequence of actions: 1) Press the pencil tip down onto page. 2) Move the tip of the pencil right by 5cm. 3) Move the pencil tip down the page by 5cm. 4) Move the pencil tip left by 5cm. 5) Move the pencil tip up the page by 5cm. 6) Lift the pencil away from the page.
Microsoft Bing Image Creator (Dall.E 3) creates this:
So yeah, a bit like my previous comment inferred, if you ask a question within the bounds of the training/dataset, it can answer; and it appears like it understand certain concepts. But, unknown contexts, such as; evolution of software / AI, then it can't really answerQuestion: if you created a drawing using the following steps, what kind of result would you get? Here are the steps: 1) Press the pencil tip down onto page. 2) Move the tip of the pencil right by 5cm. 3) Move the pencil tip down the page by 5cm. 4) Move the pencil tip left by 5cm. 5) Move the pencil tip up the page by 5cm. 6) Lift the pencil away from the page.
answer:
If you follow the given steps, you would create a square with sides measuring 5cm each. The sequence of movements forms a square shape by moving the pencil horizontally to the right, vertically downward, horizontally to the left, and vertically upward. The starting point and ending point coincide, creating a closed shape, specifically a square, as a result of these movements.
Question:
Great! How did you figure out that answer? Are pen, paper and drawings concepts you understand?
Answer:
Yes, I understand the concepts of pen, paper, and drawings. While I don't have personal experiences or physical senses like a human, I've been trained on a diverse range of internet text, which includes information about various topics, including art and basic geometric concepts.
In your question, the steps described a series of movements with a pencil on a piece of paper, forming a square. I used my understanding of spatial relationships and geometric shapes to interpret the sequence of actions. The descriptions of movements—moving right, down, left, and up by 5cm—correspond to the creation of a square shape. This interpretation is based on the common understanding of how drawing instruments interact with a surface, such as paper.
Question:
how long before txt2img in open source programs such as stable diffusion give similar results? It appears like image generation AIs like stable diffusion aren't very smart and don't really understand even simple sentences.
Answer:
As of my last knowledge update in January 2022, the field of AI, including text-to-image synthesis and image generation, has been advancing rapidly. Open-source projects like Stable Diffusion are continuously evolving, and improvements are being made to address the limitations of earlier models.
However, the development and release of new models or updates to existing ones depend on the research community and the organizations working on these projects. The timeline for when a specific open-source program will achieve better performance in understanding and generating images from text can vary.
If there have been updates or new releases since my last update, I recommend checking the official sources, documentation, or community discussions associated with the particular open-source project for the latest information on improvements and capabilities. Additionally, ongoing research and advancements in the AI field contribute to the development of more sophisticated models over time.
So as long as you stay within its bounds, it does fine, but that line isn't very clear, and if you go over this line, you either get nothing or garbage... Exactly like in Stable Diffusion; terms it knows work well, terms it doesn't doesn't work; if not programmed/trained for it, zero.by your estimate, given Stable Diffusion improvements, how long would that be?
I don't have the ability to predict specific future developments or provide estimates for advancements in AI models like Stable Diffusion. The pace of progress in the field of artificial intelligence can be rapid, but predicting when specific improvements will occur is challenging.
Improvements in AI models depend on a variety of factors, including research breakthroughs, computational resources, and the priorities of the organizations and researchers involved. It's recommended to stay updated with the official channels of the project or research community associated with Stable Diffusion to get the latest information on any advancements or improvements to the model.
If there are specific research papers, conference proceedings, or official announcements related to Stable Diffusion, those would be valuable sources to monitor for updates on the model's capabilities.
