Bob from Florida
- Joined
- Aug 20, 2020
- Messages
- 1,334
- Likes
- 1,230
- Thread Starter
- #281
Here is a question for those of you switching styli on AT VM95's or similar. Are the replacement styli the same overhang?
Yep, overhang the same, I have (rebodied VM) C, EN and ML. I wonder whether they all have the same compliance..?Here is a question for those of you switching styli on AT VM95's or similar. Are the replacement styli the same overhang?
Two things to do to run the script. First, get a test record. Second, get the script working on IOS.The MC R loading only affect the level, nothing else. See “ Fun with Vinyl measurements”.
It would be interesting to see a frequency response plot of the Hana if you can run the Script for it.
Kind of hard to see what is wrong without a comparison.
JP and User can help with the script installation , Clearaudio test record CA TRS-1007 can be bought, CBS STR-100 is not as good but still a valid test reference. Could be your best Hifi investment ever.
If you are looking for a fix, I recommend Steve Leung of VAS. He retipped my Hana ML and Hana SL.I know it's hard to tell without a reference. However, it is supposed to be a nude Microline on a square shank. Image 2 is probably the clearest of what I think is wrong. The area in the back is missing the back part of the shank and what's missing extends to the tip of diamond. The "square" shank has 3 sides of a square but the back side is not the 4th side but 2 additional sides angling in towards the center. Doesn't look like any drawing or picture I've seen of Microlines.
You already had your Hana's re-tipped! Seems like you just got them. You must be spinning a lot of records.If you are looking for a fix, I recommend Steve Leung of VAS. He retipped my Hana ML and Hana SL.
Phono Cartridge Repair & Retipping Service | VAS Audio
VAS offers professional phono cartridge repair and retipping services for those in need of a rebuild.vasnyinc.com
The secret is that I had them retipped when I purchased them. I purchased both cartridge bodies for $50 - $100 each with broken styli and had them retipped for a substantially reduced cost from buying them new.You already had your Hana's re-tipped! Seems like you just got them. You must be spinning a lot of records.
Finally got around to mounting my Denon 103 on the Sorane 17 gram headshell. Just a few album sides so far, but it reenforced my previous opinion that this is a great cartridge. I now have 4 cartridges mounted - Hana SL, Clearaudio Maestro 2, AT VM95SH, and Denon 103. To be honest, I think I could live with any of them long term. At present, I am liking the Hana and AT the best - more testing to be sure and these are not large differences between any of them.
received recently yet another blue note reissue LP made by Optimal and while the LP sounds mostly fine the first track on one side has a bit of distortion that sounds like scratching sounds.
is this long line in the picture that looks like needle scratches "non-fill"?
so annoying to receive LPs like this. so far I had to return everything I ordered from Optimal / GZ .
the one blue note Poets made in the US is absolutely fine. also everything I ordered from Verve AS Series . but the stuff made in Europe.. 6 returns out of 8.
Look like crap , send it backreceived recently yet another blue note reissue LP made by Optimal and while the LP sounds mostly fine the first track on one side has a bit of distortion that sounds like scratching sounds.
