I think there are two things that are at play here possibly:
1. Difference in the two rooms. The show location was in a presidential suite which was a massive room with very tall ceilings. Mine is in an open/loft space so perhaps I can't pressurize it like one can in a closed room.
2. Horn drivers. I hear the same "power" when I play the JBL M2 speakers. Their efficiency allows them to play loud and when well done, very clean sound.
Thank you for the reply.
Big room - that makes a difference.
Opinion:
Small room at high SPL seems to, let's call it "overload". The reflected sound (delayed) intensity is at such a high level that it conflicts with what should be the quiet (if there is any) between the notes, so, dynamic contrast is compromised, and gets worse as the direct gets louder, past the 'too loud for the room" level.
I can have a taste of that problem here. I'm not certain of the source of the irritation. It could be my ears, as they can do odd things with "too loud" sounds (not specifically the stereo).
But, drop the level a dB or two and things become normal loud listenable again.
Opinion in Search of a Fact to Misconstrue:
Small room and large room may attenuate the higher frequencies differently, which may affect the spectrum of the reflected energy disproportionately in comparison with a small room. Too much higher frequency coming back at you may increase irritation.
It took a while to find a reference for this, but here goes:
http://www.sengpielaudio.com/calculator-air.htm
"ISO 9613-1:1993 specifies an analytical method of calculating the attenuation of sound as a result of atmospheric absorption for a variety of meteorological conditions. For pure-tone sounds, attenuation due to atmospheric absorption is specified in terms of an attenuation
coefficient as a function of the frequency of the sound from 50 Hz to 10 kHz (no ultrasound), the temperature (−20 °C to +50 °C), the relative humidity (10 % to 100 %) and pressure (101325 Pa = 101.325 kPa) of the air. Formulae are also given for wider ranges and for other than pure tones − only audible sound 20 Hz to 20000 Hz."
Example of frequency dependent attenuation with distance:
Denver can be a low-humidity place, above is this afternoon's reading. That could increase the attenuating effect if that is something you heard.
Horns...
I don't but would like to have some quality horn time. The tweeters on the stacks for the Rocking Teen Combo were compression drivers (crossed at 1200Hz), and the mid cabinets were deeply recessed JBL 12" with at least some measure of directivity.
Opinion:
So, again, the direct has some contrasting SPL advantage over the reflected in terms of relative dynamics of the direct and delayed reflected sound.
Experience:
For sure, the band sound was crap in the practice space, but good in a club (I ran the PA), and the major difference was room size... A big room can swallow a lot of sound energy.
