watchnerd
Doesn't work like that - high quality level reproduction takes one beyond the point of what being aware, continuously, of the "faults" in the recording - they don't go away, they are still all there, but your mind discards them as being "irrelevant" to the message of the recording. Of course, one can choose to force your mind to notice the faults, but it's not easy ...
Maybe that's how it works in your particular mind...
But as someone who works as a volunteer recording engineer for the local symphony and jazz society, I don't agree in the slightest. For one, I've been trained to listen into the mix for flaws.
Second, I listen on monitor systems, including at home, which aren't designed to make things sound euphonic. The ultimate goal is to see if a mix 'translates' between systems, i.e. sounds mostly the same and 'right'.
Third, all recordings are acts of artifice. People underestimate how much the mix has been manipulated by engineers. A good engineer can add "audiophile" traits to a recording entirely through manipulation. You can also add these via PEQ and AU plugins at playback time. Here are some examples:
Want to move the soundstage forward? Add +2.0 db, Fc 1600 Hz, Q 1.00
Want to move the soundstage backward? Add -2.0 db, Fc 1600 Hz, Q 1.00
Want more warmth? +2 dB, Fc 220, Q 1.50
Want more detail? +2 dB, Fc 8000, Q2.50
Want more hall ambience? Pick your favorite reverb plugin
Want to make it sound like tubes? Load up the Softube AU plugin
etc
etc
Your "system synergy" is entirely capable of being manipulated at the source level, whether in the original recording or at playback time using DSP.
And, while our mind can play tricks on us, what I'm talking about is objectively real -- capable of being measured with microphones.
There is no Allegory of the Cave in recorded music. There is no "Platonic form" of the piano hiding within a recording, because how a piano sounds on a recording is a combination of venue, microphones, mix, mastering, etc.
When you say "synergy" what you really mean are a set of preferences that you happen to like. Cool, we all have those. But don't pretend it's some higher truth that is universal.
