There is nothing holy about the signal
Is the signal holy?
  • Yes it is
    Votes: 18 16.5%
  • No it isn't
    Votes: 84 77.1%
  • Undecided / No opinion
    Votes: 7 6.4%
Philbo King
Or all live music just sounds wrong to what the musicians intended?
A lot of times is exactly what happens. Touring musicians are often faced with suboptimal house sound systems operated by a DJ/Kareoke maven running at 110 dB. I can count on one hand the number of concerts and club shows I've seen where it sounded 'right'. It's just reality; all musicians can do is try for their best performance, with no idea how it sounds in the house.
kemmler3D
San Francisco
I've been to a decent number of concerts in the past 20 years or so. I think the number of venues I've been to where the sound was noticeably good, and not absurdly loud, I could count on one hand. I've been to more shows where all you can hear is a 40hz drone with maybe some cymbals on top.
Philbo King
Yes... I submit FOH mix engineers should have to pass an FCC test or something before they're allowed to feed signal to subwoofer stacks. It is the *most* abused element of live mixes in my experience. I find no logical reason that my liver and spleen should jump 3/4" each time the kick drum thumps when I'm sitting over 100 feet from stage.
ahofer
New York City
I've never been to a Rock concert with good sound. The Beacon, in NYC, came closest. Madison Square Garden and most stadiums are excruciating.
danadam
Alan Parsons' quip, " an audiophile is someone who uses music to listen to gear" is one oft quoted.
I believe it wasn't his "quip" but rather a comment on slashdot:
under his interview (from wayback machine):
As reported here:
DMill
I had a college roommate with over 200 cassette tapes of Grateful Dead concerts of varying quality. Strangely some of the poorer recordings were still very listenable. In some cases, there almost was a little magic in the performance. The band was just on that night. I believe my grades suffered a bit that year.
MattHooper
Seeing this my mind warps the thread title to There Is Nothing Holy About The Grateful Dead.
I've tried to listen to some of them, tried watching some of their performances. I'll never get the appeal, much less the fanaticism.
JSmith
Algol Perseus
clickbaity title
I'd suggest the signal may be considered holy to some when listening to this;
:cool:
JSmith
Killingbeans
Bjerringbro, Denmark.
Me neither. It's like they wrote the book on vanilla. I guess the straightforwardness speaks to a lot of people. I'm just not one of them.
boxerfan88
For some time now, I have noticed that both groups of audiophiles - subjectivists and objectivists - share the same belief: that the signal should be kept uncorrupted. Purity is all important.
I used to be aligned to this principle. My past approach was to keep the original signal uncorrupted from file to DAC.
I ended up installing all sorts of VST's and rejecting most of them on grounds of taste, so I have only kept a few. The important feature of my system is that I can turn everything off with a few clicks and everything is restored to unmolested signal.
So my questions for ASR are: do you think signal integrity is important? Do you avoid all manipulation to the signal? If you did manipulate your signal, how did you choose your target curve? Do you think there is a role for preference when it comes to signal manipulation?
Over the past 2 years, I have been learning (reading, videos) a lot about what goes on in the music production side. Gosh, the number of mixing/mastering plugins and analog signal manipulation hardware the recorded signal goes through is amazingly high.
Then it dawned on me, if the music production side manipulates the signal like crazy in the name of creativity, why not I manipulate the signal a little bit on the playback side to overcome playback side issues (room-speaker interface)? This worked out quite well, and I managed to overcome somewhat that pesky +16dB 43Hz room mode, and that honky upper bass caused by speaker placement/SBIR. This made music listening so enjoyable in my room, and my thinking shifted away from "keeping signal uncorrupted" to "manipulate signal in whatever way needed to overcome playback side issues". I am now firmly on this side.
After the above was achieved, I then went on to experiment with various plugins (tube plugin, reel plugin, vinyl plugin, etc...) to color the sound just for the fun of it. All this can be reversed with a few clicks of the mouse.
I am now in the camp of "adulterating" the signal on the playback side to fit my needs. ;)
Blumlein 88
I kind of like their music. It is sort of a jamming session. The only rock-like music that is suitable for background music. I usually listen to music or not. But the Grateful Dead is okay for background. Never understood the fanaticism either. Like Widespread Panic.
Jaxjax
The recording is the only artefact, we can only aspire to reproduce that file as accurately as possible.
True...
but what if only 50% of one's recording collections are listenable to them but the ability to change that to 75% + with non accuracy measures. Wouldn't that be the way to go ?
Joe
Newman
American Beauty. Don't quibble. Just get it. :cool:
cheers
Justdafactsmaam
it makes no difference to us what happened in recording we can't change that. We start with the finished product and try not to wreck it too much from that point on.
High fidelity means fidelity to the recording, not some event in a studio or even a live performance. A mic doesn't hear like people nor is it in the same place as some notional person present at the recording. I mic up drums and put a mic six inches over the ride cymbal - no-one will ever listen to a ride cymbal from that position.
Clearly there is no consensus on the subject of accuracy/fidelity. I look forward to JJ’s presentation on the subject of accuracy on January 31st.
egellings
Sorry for the clickbaity title but I thought it was time for another ASR bun-fight ;)
For some time now, I have noticed that both groups of audiophiles - subjectivists and objectivists - share the same belief: that the signal should be kept uncorrupted. Purity is all important. The only distinguishing feature between the two groups is the approach. Subjectivists believe their cables, power conditioners, cable elevators, DAC's, and analog systems keep the signal clean. The whole purpose of an analog system is to prevent the signal getting corrupted by digital. The intention of power tweaks is to keep power "clean" because they think they can hear "dirty power". Objectivists believe that the lower the distortion/SINAD, the better. Speakers are selected for low measurable distortion. The whole point of this engineering exercise is to keep distortion and nonlinearities as low as possible, preferably pushed into inaudible limits. There is certainly a large contingent of very vocal ASR members who say that the system is there to reproduce what the artist intended, and nothing more. So you can see, both are the same yet both are different.
However, there are two major aspects to sound reproduction that everyone agrees has a major impact on the sound: (1) the recording, and (2) the speaker/room interface.
The recording: this is the result of a bunch of subjective decisions made by the artist and the mixing engineer on their monitoring system, which is different to your home audio system - i.e. Toole's "circle of confusion". Take a look at the VST plugins offered by only one company, and realize there are thousands more offered by other companies. All these VST plugins manipulate the signal - compressors, expanders, EQ, harmonic distortion generators, emulators for tube sound, vinyl sound, tape sound, reverb VST's, and so on. Some recordings are completely artificial constructs that never existed in reality, e.g. all electronic music. Some recordings of less talented singers have been "autocorrected" to make them sing in tune. Even recordings of live acoustic instruments have been manipulated. I listen almost exclusively to classical music, and I can tell you that recordings sound crazy different from label to label, and even with the same label. Just compare Deutsche Grammofon from the 80's and 90's and current recordings, even though the recordings are digital. They have changed something in their workflow that makes the recordings sound different.
The speaker/room interface: despite the best intentions of speaker designers, the moment the speaker is placed in the room, the response is changed. I think that nearly all of us here on ASR agree that some type of room correction is necessary, preferably with DSP. And if you correct with DSP, you will need a target curve. Here is an older thread on ASR about target curves:
I have tried all these target curves, and they all sound different. All are purportedly supported by science. Some of these curves were arrived at by hypothesizing what the speaker's room response would look like if a speaker that measured flat under anechoic conditions were placed in a room. Some others are based on preference studies, e.g. the Harman curve. Even the Harman curve has three bands, "more bass", "less bass", and "Harman curve lovers". These bands are split into different demographics - younger men and older women respectively for the first two groups, and the largest group being "Harman curve lovers".
I suspect that whether we admit it or not, many of us pick the target curve that we like based on what sounds best to us. So here is the rub: the moment we pick a target curve, we are manipulating the signal to our preference. Even if we choose a speaker that has a certain target curve with no digital signal manipulation, we have still chosen a target curve that we prefer.
Another point of data: valve amps and turntables distort the signal and measure objectively worse. Yet there are many people, myself included, who think that they sound pleasant. Why? My hypothesis was that people just like some additional distortion, so I performed an experiment on distortion - thread here. I deliberately added distortion to the signal, and asked people if they prefer "A or B", without revealing what the intervention was. Nearly all the people I tested preferred some distortion. As I emphasized in that thread repeatedly, this was not a scientific test given that it was performed under uncontrolled conditions with only one system, but the trend seemed significant.
And yet another data point: in another thread, @ppataki recommended I try Pultec EQ to improve subjective bass slam. I downloaded a VST and tried it. It works by boosting bass followed by a little undershoot, i.e. it effectively modifies the target curve. It is still early days in my testing, but I like it very much. I need to throw more music at it to see if it still holds up after a few weeks of listening, but here is another example where signal manipulation has increased my enjoyment of the system.
Conclusion. My system is an unholy hodgepodge where I have manipulated the signal to an extent that would horrify both objectivists and subjectivists. It started by realizing that recordings all sound different, and Toole's circle of confusion meant that my system wasn't reproducing what the artist intended anyway. I began correcting the system with the intention of making the circle of confusion smaller, before I realized that this intervention by itself was manipulating the signal to my preference. So why not go further. I ended up installing all sorts of VST's and rejecting most of them on grounds of taste, so I have only kept a few. The important feature of my system is that I can turn everything off with a few clicks and everything is restored to unmolested signal, with the exception of the target curve that I can not avoid because it is baked into the system.
If you conclude that it is OK to manipulate the signal to your preference, the very uncomfortable corollary is this: there are no standards in audio, nor can there ever be. All the preference scores in spinorama.org are moot. We are back to the Wild West where anything goes. I myself am uncomfortable with this because as a scientist at heart and by profession, I can not accept a universe of disorder and chaos.
If you are going for accurate reproduction of an audio signal, then going for best SINAD and flat frequency response is the approach to use. If you want sound that pleases your nun-handles, and dead-flat F.R. isn't cutting it, then a smiley-faced equalizer might be for you.
