- Joined
- May 4, 2022
- Messages
- 507
- Likes
- 557
Dithering is used to address that. (Dither is an intentionally applied from of noise used to randomize quantization error.)This does not alter the quantisation noise already embedded in the input signal.
A lifetime in business suggest the accountants have more say than the engineers!I think that's exactly why ASR exisits.
That dithering can only be applied at the time of quantisation - IE during the ADC For the original digital file. Any shaping done by a DAC is only shaping the quantisation noise IT is creating as part of its DSP. Once noise is added within the bandwidth of a signal it cannot be subsequently removed.Dithering is used to address that.
Me tooI hope as customers, we can also have some say (with help from ASR)
Looking for a solution to an existing problem implies a problem exists and isn't solved satisfactorily. Nearly everything discussed in this thread is a solution looking for a problem, not the other way around.Sorry for my ignorance. Does it mean that we can only discuss an actual problem or issue but not how to improve the current solution for an existing problem?
I believe that is an incorrect assumption. If you have a reference that supports that contention, I'll look at it. But, I found numerous references that state the opposite.That dithering can only be applied at the time of quantisation - IE during the ADC For the original digital file.
That's fine.Again - I’m done here.
Yep - intense navel gazing !Looking for a solution to an existing problem implies a problem exists and isn't solved satisfactorily. Nearly everything discussed in this thread is a solution looking for a problem, not the other way around.
And I'm suggesting that the problem is most likely in how you evaluate equipment, not in the equipment itself. Until you learn how to properly compare two devices for real audio differences, you'll be stuck in a loop, looking for solutions to imaginary problems.I am not satisfied with the DAC's internal oversampling and trying to look for a different solution.
I agreed the highlighted part. To me (again my personal experience), I am not satisfied with the DAC's internal oversampling and trying to look for a different solution.
As a prerequisite, I believe that I need to find out more how the existing DAC works in order to find a different approach to the solution.
Something to get you started:And I'm suggesting that the problem is most likely in how you evaluate equipment, not in the equipment itself. Until you learn how to properly compare two devices for real audio differences, you'll be stuck in a loop, looking for solutions to imaginary problems.
I guess you never used a particularly good lens then..
But yeah we're not there technologywise that we can capture and display images in all dimensions that exceeds our eyes capabilities, so I am talking about theory mostly, and also me working in 3D I see it from that "perfect" perspective as well. But the digital sampling theorem still very much applies just the same and it's all constrained by our human senses, which is what I have been trying to explain and compare.
Anyways, I don't really have neither the time or every to keep on with this conversation, I have explained my point of view that I still fully stand by and the person I was mostly talking to seem to have understood it so
Yes diffraction is a thing, but you still don't seem to understand the point of my post. Never mind, have nice day etc.27.6 Limits of Resolution: The Rayleigh Criterion – College Physics
pressbooks.online.ucf.edu
The majority of the article describes reasons for oversampling in ADC. Then, in this last paragraph, it says that the term "oversampling" is also used to describe a process in DA conversion. I don't see any basis to conclude that the reasons described earlier apply here too? It's rather clear that the main reason for oversampling in the context of DA conversion is to allow for less complex analog reconstruction filter.
In the context of DACs this only means that you can take 16/44k input, convert it to "low bit-depth/high sampling-frequency" format and still retain the 96 dB SNR (in 0-22k band) of the original 16-bit input. You won't get more than 96 dB SNR (in 0-22k band) even if you convert to "high bit-depth/high sampling-frequency". You can't magically recover information that was lost when 16/44k file was created.Delta-sigma (ΔΣ; or sigma-delta, ΣΔ) modulation is an oversampling method for encoding signals into low bit depth digital signals at a very high sample-frequency as part of the process of delta-sigma analog-to-digital converters (ADCs) and digital-to-analog converters (DACs).
Rather you interpret those references as stating the opposite. How about an example instead of reference?I believe that is an incorrect assumption. If you have a reference that supports that contention, I'll look at it. But, I found numerous references that state the opposite.
Please provide your interpretation of the references or, better yet, a scientific paper that supports antcollinet's contention "That dithering can only be applied at the time of quantisation - IE during the ADC For the original digital file."Rather you interpret those references as stating the opposite.
Dither can (and should) be applied any time quantization error is introduced, usually when fitting a result with more bits of precision into a smaller sample size.Please provide your interpretation of the references or, better yet, a scientific paper that supports antcollinet's contention "That dithering can only be applied at the time of quantisation - IE during the ADC For the original digital file."
I believe he said more than that, both in the message you quoted and in earlier messages.antcollinet's contention "That dithering can only be applied at the time of quantisation - IE during the ADC For the original digital file."
The next sentence after above quote says:"Also, since the quantization noise is spread over a wider region with respect to the original signal bandwidth, an improvement in the signal-to-noise ratio is also achieved. By doubling the original sampling rate (K = 2), an improvement of 3 dB is obtained, and by making K = 4, an improvement of 6 dB is obtained..."
"One-Bit Dithering in Delta-Sigma Modulator-Based D/A Conversion"
https://en.wikipedia.org/wiki/Delta-sigma_modulation :
"Noise shaping: moving noise to higher frequencies above the signal of interest, so they can be easily removed with low-pass filtering."
This one is strange. It doesn't seem to be related to audio. In fact the DAC is part of a microcontroller for "Motor Control, Industrial and Metering Applications". They describe how to obtain more than 256 levels from 8-bit DAC and they call it increasing resolution to 12-bit. In the audio-world we know that an 8-bit file can have any number of levels and we still call it an 8-bit file. So I'm rather confused and I'm not sure how it relates to the current discussion."This app note describes a method to increase the 8-bit DAC resolution to 12-bit effective resolution using a DAC amplitude dithering method..."
Do we know how many bits are employed by the delta-sigma modulator in modern DAC chips?
He did, but I believe the confusion was based on the portion I quoted. Specifically, I interpreted the statement "That dithering can only be applied at the time of quantisation - IE during the ADC For the original digital file" (emphasis added) to mean he asserts that dithering only can be applied during ADC, and cannot be applied during DAC. That is incorrect. The references I cited were to support that position.I believe he said more than that, both in the message you quoted and in earlier messages.
Delta-Sigma modulators are used in audio DACs. E.g.,These describe inner-workings of Delta-Sigma converters.
Again, that reference was cited to support the position that dithering can be applied in a DAC.This one is strange. It doesn't seem to be related to audio.
The eye roll because I am thinking (sorry if you have a different interpretation of if). By the way, what do you think of the meaning of "the eye roll'? I just want to be in sync with you guys if possible.
I overlooked responding to this last comment. Your interpretation is inconsistent with the evidence. See section 4.1 of "Designing and Evaluating a Delta-Sigma DAC for Hi-Fi Audio" (https://liu.diva-portal.org/smash/get/diva2:1745070/FULLTEXT01.pdf). Specifically, that section describes noise shaping in the DAC, and Figure 4.1 shows the resulting reduction in quantization noise in the audio spectrum (fs/2). Those results correlate with the various other references I cited explaining how noise shaping is used to shift quantization noise to a higher frequency so that it then can be filtered out. Here are the relevant passages:So my interpretation is that yes, the dither and the quantisation applied in ADC determine the noise level in the input signal. Any further operations/requantizations of the signal can only increase that level, they cannot reduce it.
