Yoku-San
I guess you have to activate the option to connect with two devices in the 1More App.
Yeah - hidden in the app settings! It worksI guess you have to activate the option to connect with two devices in the 1More App.
Ah thanks! Solves my problem, I hope...Yeah - hidden in the app settings! It works
Just got these, before seeing the ASR review, and here's not only a good review but in the comments an eq setting for the app that I like a lot! Thanks! These are a very good value. Just big enough for my head and ears so they're quite comfortable (the light weight definitely helps). Only quibbles so far are that the ANC is either on or off with no middle ground and the volume can only be controlled with the physical buttons not in-app. I think these will be more than fine for my occasional need for wireless ANC cans.After some listening with the "Yoku-San" preset I switched back to "ASR" as it was better and more neutral sounding. However, it also sounded a little bit boring. Therefore I tuned it a little bit and created the preset "Yo 2" which is still quite neutral but a little more fun to listen to. I guess I will stick with this for the future after having used it for the last two days. Try it out, here it is:
The values for this preset are:
-2.5;-1.5;0;-2;0;+1;+0.5;+0.5;0;-1
They are my first bluetooth headphones with ANC and LDAC. They get a relaxed panther from me, as they are perfect for listening to a few tunes when digesting a good meal.So now that it has custom eq, if the cups fit your ears better these would merit a golfing panther?
I've been using the burn-in too. Figure it can't hurt and it costs nothing. The phases get longer. Phase 3, which I'm about 2/3 into, is over 60 hours.I received mine a couple of days ago and so far my take is very good value. I was looing for an ANC BT LDAC HP for when I sit on the deck or patio. I need to cancel out the noise from a fountain my HOA installed in the lake/pond behind my house. Since it's still cold here, I haven't been able to test if they are effective for the fountain yet. However, they do work well to deal with the fan noise of my basement office space heater. Sound quality is quite good, especially considering the price. The EQ settings posted above are an excellent place to start. I then adjusted for my personal hearing weak points.
I found this interesting feature in the app - a programmed "Smart burn-in". Half way through the 12 hour process (or maybe just phase 1?), I do not notice a difference from brand new.
Found them, 10€ a pair:Where do we get replacement cushions? It's always a good idea to put two new sets into a drawer somewhere i think.
Not a good idea. Even in the drawer they will get old and maybe unusable when you need them. Happened to me with a pair of AT cushions.
Bought them, so i will have to see.Not a good idea. Even in the drawer they will get old and maybe unusable when you need them. Happened to me with a pair of AT cushions.
They say with age your nose muscles atrophy, i can't smell anything.They smell quite strong. Hope this will not last long...
I have a very good nose, but they stinkThey say with age your nose muscles atrophy, i can't smell anything.
For long portions of the burn-in there was no audible sound. Don't know if that's intentional or if the frequencies were inaudible or what, but regardless I heard no difference between pre and post burn in. I just used them a bit on a short flight. Noise cancelling is good enough, but about an hour is all I can do before my ears get hot. I also don't like that there's no volume indicator or control on the app and the volume control on the headphones isn't finely stepped. Still, a good value overall.Got my eye on these. If they drop to the right price at some point I'll pull the trigger...
"Smart Burn In" LOL. OK...I'd be real interested in detailed measurements taken from brand new and then post burn in to see if there are any notable differences.
