Should not be a problem.More on topic, would Dirac be able to calibrate a 3 speaker stereo system? Kind of a Dirac noob still.
The simple "matrix" method of L+R = Center means left-only and right-only signals are also sent to the center speaker (attenuated). And of the "center" audio still goes to the left & right speakers. It's not "correct" but it's simple, clean, and predictable.
The old ProLogic 'movie mode steering" does unpredictable things with regular stereo. More advanced DSP methods are likely to also be unpredictable.
There are no dumb questions ;-)My understanding was RME ADI-2 DAC had only two independent channels, how would the C be assigned then? Please excuse my dumb questions.
FWIW -- the only "Dynaco" processing trick I know of was Hafler's "derived rear channel" (using out of phase signals), which has been discussed elsewhere on these august fora.You might want to do a search for "Dynaco Derived Center Channel". It's primitive, but it's cheap. I like it. Some people don't. Jim
I feel very honored, thank you.@KSTR, I am very grateful for your detailed answer and for your excellent contribution, in general, to ASR. If ever you have any other information pertaining to this subject, I am thoroughly interested. Many thanks again!
A little off topic but the improvement in clarity from Dirac is so big that I imagine if your budget for a stereo is 1000 or less, you would be better off with half your budget going to Dirac and the other half going to cheaper speakers versus just getting 1000 dollar speakers which might be a little better than the 500 dollar speakers.
I think I would rank the improvement on par with 2 subwoofers instead of 1.
So I just realized that I think I can just add a 3rd powered speaker to my setup by having my MiniDSP DDRC24 output both the left and right channel to a 3rd output on the MiniDSP at the same time for a physical center channel.
Still, there‘s no way to get the positioning for it decent because the TV is blocking where the 3rd speaker should be. Also no space for a third subwoofer to passthrough to the speaker to make it full range. Maybe one day I’ll get a bigger place to live and I’ll be able to set something cool up!
My TV actually has an option to output to Optical while playing on the built in TV speakers still so I kind of have an option already for 3 channel stereo….
This is not a proper center, not even close.
it’s fun but it’s basically the same as having both optical and TV internal speakers working at the same time.
Do you think it’d be worth adding a powered and centered sound bar with both the left and right channels playing on it at the same time Dirac corrected? Or should I give up on the dream till I get a better place to live and stick with my nice stereo setup?
I feel like the ghetto physical center would be worse than my very nice stereo illusion center.
True for TV watching maybe, but for music playback?i think you should get an AVR with dolby pro logic because the point of having a center channel is so people sitting anywhere in the room horizontally have a proper center.
of course, this forum doesn't have the "embarrassed" emojum for me to use in reply, so this'll have to do.
Trinaural is not a replacement for actual 3-channel content. It's a 3-speaker projection mechanism for 2-channel content, and IHMO a better one than standard stereo. And proper trifield is even better than trinaural."true" 3 channel stereo will not work on a extract center channel basis. a signal inbetween the center and left speaker will be played by both of them for example.
These equations refer on the time-domain stream, the actual voltages present? If so, they only produce gross nonlinear distortion!something like this
CS=(L+R)-root of (L-R)*(L-R)
LS=L-R (while negative values are not allowed; are 0)
RS=R-L (while negative values are not allowed; are 0)
If it follows the matrixing rules layed out it may work, as far as working along trinaural procces is the goal.What do you think of my idea of getting a sound bar outputting combined left and right channel to act as my center for stereo content?
