300w Pure class A Monoblock search!
Lew3vans
Hi
Never posted before. But I am in the search for a set of pure class a Monoblocks with a wattage output of 300w into 8ohms….. I cannot seem to find a useful site to help my search filters!
Does anyone know of any that don’t cost the earth?
Budgetary speaking in the region of £1500 each.
Hopefully you guys can help me find my endgame amps!!
Thanks
Lew
fpitas
Northern Virginia, USA
I hope you have an air conditioner specifically for the amps. They'll be like room heaters, each burning off about 1,200W.
L
Lew3vans
So… reading between the lines… it doesn’t exist?
fpitas
It very well may. It will be beastly expensive and frankly, a modern class D will probably sound better. And that's coming from a guy who uses a class A amp for his horns.
eddantes
Probably does... but what's the point? The earth is getting warmer as it is anyways....
fpitas
1.2kW of heatsink will be impressive.
L
Lew3vans
I appreciate the replies!
Before I was looking at the Emotiva A1 - which I guess is a bit of a trade off as a class AB - any thoughts on something like that?
fpitas
My 25W output J2 dissipates 200W, and without a fan those heatsinks get hot. Your 300W amp will need proportionately more heatsinking and/or fans.
fpitas
You can check and see if Amir measured the Emotiva. I still think you're best off with a modern class D.
Vini darko
Dorset England
Hi welcome to asr. Good luck finding anything in that price range that isn't dodgy aliexpress stuff from China. Try going 10x plus on money and you may possibly find something. Maybe old tube amps from a cinema could do it for cheap if you can find some for sale.
MoreWatts
The Mojave Desert
L
Lew3vans
Fair point!
I have a lot to learn!
But I did find this bad boy which you may appreciate (£16,500.00 a piece though)….
fpitas
fpitas
Maybe, although I can't imagine what an old cinema class A push-pull tube amp goes for now.
JayGilb
West-Central Wisconsin
The Perreaux 750 is a class A/AB hybrid that might fit your request. It's 750 watts, not 300.
The Perreaux 350 is also a class A/AB that is in a stereo chassis.
antcollinet
UK/Cheshire
Hi
Thanks
Lew
Absolutely no chance.
If you could find one (which I doubt) you'd be looking at (probably multiple) 10Ks
fpitas
The budget of 1500 seems to suggest that some legs are being pulled or am I being too sensitive?
Peace.
Well, maybe. Powerful class As are like hen's teeth. Hot, expensive hen's teeth.
