4.4 pentaconn to 3.5
TechEnthusiast
Can you use a 4.4 pentaconn to a 3.5 mm connection out of the Zen Can to use as a preamp? The adapter I found on amazon is 4 pin balanced on both ends.
https://www.amazon.com/Geekria-Balanced-Gold-Plated-NW-ZX300A-TA-ZH1ES/dp/B075165H2M
Can I use that and run standard 3.5 (3 pole) to my powered desktop speakers? I assume the Zen would switch outputs when inserting/removing the headphone connection on the front of the unit.
solderdude
The Neitherlands
Nope, not using this adapter. You end up shorting the -L and -R output amplifiers on the Pentaconn side.
The good news is that Pentacon can be used for this but you need a special converter.
Pentacon L+ to 3.5mm L+ (tip to tip)
Pentacon R+ (second ring from tip) to 3.5mm ring.
Pentacon Sleeve to 3.5mm sleeve (common/ground)
The L- (first ring from tip) and R- (3rd ring from tip) MUST be left open (not connected)
T
TechEnthusiast
I do not understand that. The adapter will not work because it is not the correct type for that amp or for my desired application.
So would this damage the amp?.........or just not work?
raif71
I supposed you're hoping the above feature on the link you provided would solve your problem, @TechEnthusiast ?
T
TechEnthusiast
There is a possibility that Zen Can will be damaged, see what @solderdude wrote.
Yes, I know what he wrote, unfortunately I did not understand exactly what was meant. I was hoping that he could simplify the answer for me. The description on Amazon indicates that it will work. What @raif71 quoted earlier was straight from the feature set on the Amazon description in the link I provided in my original post.
raif71
I just read customers' reviews, not very encouraging. :confused:
T
TechEnthusiast
Yeah, I did see that, but then I read others ....that's why I posted here to find out.
solderdude
The Neitherlands
This adapter will be shorting (create a short-circuit) between 2 of the 4 output circuits inside the amplifier.
A balanced amplifier has 4 amplifiers needed for 2 channels. You are basically connecting (tying together) 2 amplifier outputs.
Technically only the signals that are stereo will be shorted. Mono signals won't be a problem.
The amplifier certainly is NOT designed to be used this way.
Depending on whether or not the amplifier is short circuit protected it might cause problems such as excessive heat in 2 of the 4 amplifiers.
The fact that you can but connectors in it that mechanically fit does not mean it works problem free.
Of course you can use it this way and there will be stereo sound I would not recommend to use it. It is not designed for this.
The connector is designed to convert Pentaconn to a (also not standard) 3.5mm TRRS balanced connector.
Only very few headphones do have balanced 3.5mm TRRS connectors. Most have 2.5mm TRRS connectors.
Of course many folks with wired headphones that include a microphone and remote will have a 3.5mm TRRS adapter that will fit but 1 of the 4 amplifiers will provide ground and the other one will be pumping sound in the mic/remote.
So the answer is you SHOULD NOT use this connector because it is NOT suited for your application, but you will hear music.
It could be somewhat distorted, the amp could run hotter, it could be damaged (a well designed amp should be short circuit protected) it could work problem free but certainly is not intended for your use case. Regardless what the seller says.
T
TechEnthusiast
Thank you for the clarification. I appreciate you checking back.
How can they advertise this for years and get away with it. Below is a bullet point of features that specifically lured me:
  • 4.4 mm M to 3.5 mm F convert adapter lets your 4.4mm output devices work with 3.5mm NOT ONLY balanced BUT ALSO the stereo headphones, earphones.
I did see some of the negative reviews but like all things on Amazon you have to read through all of them and these specifically mentioned ifi products:
4.0 out of 5 stars Works but don’t try for balanced audio.
Reviewed in the United States on October 28, 2020
Size: 4.4 mm Male to 3.5mm FemaleVerified Purchase
Attempted to use this for balanced output on Ifi zen dac... didn’t work obviously lol but works as an adapter.
5.0 out of 5 stars Balanced Extension
Reviewed in Germany on October 11, 2020
Use the 4,4mm to 3,5mm + 3,5mm to 2,5mm adapter with a 4-pin 3,5mm extension to connect my HD800 on the couch to the ifi Zen Can on the TV low board. Folds great, plugs have a perfect fit quality and fit firmly.
Very good quality
5.0 out of 5 stars Very good quality
Reviewed in Germany on August 18, 2020
I use this adapter to connect my balanced cable headphones to the balanced input of a Hifi Zen Dac. The difference between connecting to the balanced input or the normal input is quite big, the audio quality as well as the volume is much higher. The termination of the adapter is quite good. The 35mm jack of the headphone goes in and out a bit loud but it's nothing to worry about.
With the overall rating of 4.1 on Amazon with more than 400 reviews I figured it was worth a try.
Again thanks @solderdude for informing me. Do you happen to know where I can find the output connector that will work for me?
DosThou
Rules of thumb:
Balanced amp to non-balanced (3.5mm) headphones/speakers with an adapter: NO
Unbalanced amp to balanced (4.4mm, 2.5mm) headphones with an adapter: OK
Balanced amp to RCA: OK (you should do this if your powered speakers have RCA input instead, won't be optimal but at least it won't short your amp)
solderdude
The Neitherlands
I don't have any balanced amps nor headphones with Pentaconn plugs so never had to look for this.
Should I ever need to I would buy a pentaconn connector and make the needed cable.
Technically pentaconn is the only headphone connector that can actually be used balanced and single ended.
Well... aside from 4 pin XLR where the ground connection is also connected.
Most likely some cable makers will sell something like what you need but don't know one.
wasnotwasnotwas
As a very simple rule as others have said, don't ever try and convert a balanced source to unbalanced amp/transducer. There are exceptions that if you are 100% sure are wired correctly will work. But sounds like you or I aren't competent to verify that. So don't try.
NTK
US East
If you really really want to drive your powered speakers with the rear output of your Zen Can, one possibility is to use a iFi IEMatch after the 4.4 mm to 3.5 mm adapter (assuming it is a true TRRS to TRRS balance-to-balance adapter). The IEMatch will let you drive your SE load with balanced output.
The IEMatch was designed for very sensitive IEM's and has a minimum 12 dB (0.25x) signal attenuation. Your Zen Can is capable of very high output, so it should be able to drive your powered speakers to sufficient levels even with the 12 dB attenuation. However, the danger is that if you forget readjusting the volume/gain settings when you switch back to headphones from speakers, you may blow your headphones and/or ears.
[Edit] I still wouldn't recommend it. The IEMatch, as a 16 Ω load, will draw quite a bit of power from the Zen Can (1 W at 4 V RMS output from the Zen Can, and 1 V RMS to your powered speakers).
Olivergiangvu
Vietnam
Very good quality
Hi,
Just come across the forum and found this thread.
I have the same need as you as I'm considering buying the ifi Zen Stack to drive both my Headphones and my Powered Speaker.
Simply curious what would end up your final solution on this?
Thanks!
Olivergiangvu
Vietnam
Rules of thumb:
So, in the case of the ifi Zen Can, if I use the Adapter 4.4 pentagon to two mono RCA then connect to the Powered Speaker that can work without creating any short to the Amp, right?
If those speakers only have 3.5 aux input, then I hook the two mono RCA to another adapter to make it 2 3.5 mm mono signal. Is it still fine?
solderdude
The Neitherlands
It depends on how the adapter is wired.
When an adapter goes from 4.4mm to 2xRCA then it is very likely the adapter cable uses the unbalanced 'option' which is possible with Pentaconn connectors.
When it uses the balanced outputs of the Pentaconn and you connect the output to separate active speakers that are not connected via a 3-pin mains plug then most likely that will work fine too.
I can't see inside the adapter nor measure it so would have to guess as to what it does. Adds sometimes state untruths.
Olivergiangvu
Vietnam
So, if I go with the iFi IEMatch, the switch on the that can help to convert to SE 3.5 mm completely without short the Amp?
The only downside that you warned is that if add more load to the Zen Can so it can affect the power it drives out to the speaker, right? In case if the powered speakers have Amp build in, is that going to be a problem anymore?
