Many of the listeners at ASR have switched to Class D amps as they are typically lighter and can be a good value. Class AB power amps have a long history of doing a great job but many would rather not have to deal with a 70-90lb amp if we can get the same performance or better with a lighter class D design. Ultimately, you buy whatever your preference is. However, we would be leaving out too much information if we didn't at least consider Class D.
ATI makes great amps. In both class AB and class D formats but they are not inexpensive. Monoprice sells premium AB amps that are built by ATI and another group of class D amps as well, at a lower price point. Worth considering if you absolutely want class AB.
Based on your Infinite speakers with a sensitivity of 90dB, you can exceed 105dB at a distance of 10' with approx. 200W of power per channel. I can't imagine wanting to be in the room at that level for long but that calculation offers an idea of what would be plenty of power for your room.
1. If you desire an AB 5 channel amp I would suggest the Monolith 5x200. It will be in stock at $1599.99 in May 2024.
https://www.monoprice.com/product?p_id=15593
I have the Monolith 7x200 version and it's a beast at 92lbs. It can handle anything thrown at it and it stays relatively cool even after 90 minutes of home theater fun. The 5 channel weighs 78 pounds so I hope you work out. I had to basically slowly roll my 92lb beast into a bottom shelf.
2. If you want to try the new class D amps. I would consider one of the options below.
Option A. The new Boxem Audio A 5518/N5 which offers five NCx500 channels with up to 600W per channel into your 4ohm speakers. It sells for $2311. You would need to be sure it's located in an area with good ventilation. It offers the ability to turn off automatically when no music is detected for 10 minutes. It can be purchased with SpeakON connectors for the best connection available or with nice binding posts for about $220 more.
1 channel 700 W HiFi power amplifier, Hypex NcoreX technology. Designed and proudly built in Luxembourg.
boxem-audio.eu
Option B. If you want a cooler running Class D setup you might consider purchasing a Purifi design.
Buckeye offers a stereo Purifi and a 3 channel. The two could be used together to meet your 5 channel needs,
Buckeye Amps utilizes the most advanced audio amplifier technologies available. Authorized seller for Hypex and Purifi Class D amplifiers. Based in the US. Free shipping and worldwide service!
www.buckeyeamp.com
www.buckeyeamp.com
The cases aren't much to look at but they will certainly do the job. The total for both amps would be $2525.
The Purifi offers 425W into 4 ohms - so more than you will ever need.
Option C. There are also older Hypex version amps available as well like the Buckeye NC502MP 6 channel for $1625. It weighs 16lbs instead of 78Lbs like the Monolith 5x200. The specs are still good for the NC502MP but given a choice I like the Purifi. But it's also more money.
www.buckeyeamp.com
Pick your poison. You have lots of options.
